Toymods » Tech & Conversions » Mark II questions....
alterd
Chch, NZ
January 2005
Mark II questions.... Wed, 12 January 2005 01:08 Go to next message
Hi there,
just trying to find some suspension/brake options for my car, 1986 JDM GX71 Mark II GT twin-turbo hardtop. I have searched and havnt found much on the 'net except for *X83 upgrades, would it be the same? or the same as *a70 or *Z20?? . Its got IRS with coils which aren't wrapped around the shocks and no TEMS. Im wanting to lower and firm up the suspension etc, and as far as brakes I just need more stopping power (I have read the thread on z32 upgrades, any chance of this fitting?)
any ideas or advise greatly appreciated...
Re: Mark II questions.... Wed, 12 January 2005 01:26 Go to previous messageGo to next message
Z32 stuff should fit as you should be running the same gear as the MX73.
As for suspension, custom springs (or rewound kings/lovells), and some Tokico HP shocks, with new poly-urethane bushes and she should handle.
Off the shelf Kings are too soft.
Trust me on that one.
Re: Mark II questions.... Wed, 12 January 2005 01:59 Go to previous messageGo to next message
I was just thinking that my springs aren't quite what I want. do they have to be higher rate from the factory, or can something be done to my existing kings to increase the rate? (hopeful stab in the dark here)
Re: Mark II questions.... Wed, 12 January 2005 02:00 Go to previous messageGo to next message
No higher rate from factory (unless you ask them to do it)
I plan to get all mine rewound, have the car lowered, and get it stiffer in the next few weeks.
Re: Mark II questions.... Wed, 12 January 2005 02:12 Go to previous messageGo to next message
Chat to your local suspension gurus about what might be the right spring rate for your car and intended purpose.
Measure the installed height of your springs (to the nearest 5mm) whilst in the car at usual load.
Take out spring.
Take spring to local friendly springworks. Ask them to make spring to specified rate and desired installed height* and to the same dimensions as the spring you are holding in your hand.
Return later that afternoon, pay $80-90 per pair and install your custom springs.
*For struts, movement ratio is 1:1, so a reduction in installed height by x mm will result in the same reduction in ride height. Otherwise you'll need to multiply the desired reduction in ride height by your movement factor.
Re: Mark II questions.... Wed, 12 January 2005 02:14 Go to previous messageGo to next message
and be stuck with a pair of ma61 king springs Razz
bbaacchhyy
Re: Mark II questions.... Wed, 12 January 2005 02:16 Go to previous messageGo to next message
gianttomato wrote on Wed, 12 January 2005 12:42
Take out spring.
GT is right, except I've never seen a pair of custom wound/rated springs for that price !!! Anyway, follow his advice Very Happy
They might chop a coil out of them and rewind them at an appropriate height, but I'd sell them! Smile
Brown's here in Thomastown do >600 lb/in for $95, <600 for $85, and coilover style springs for around $60.
[Updated on: Wed, 12 January 2005 02:18]
Previous Topic:87 celica auto to manual conversion
Next Topic:some advise will go down well (ra 65 hints)
Current Time: Fri Nov 20 12:37:24 UTC 2026
Total time taken to generate the page: 0.0054409503936768 seconds
