Toymods » Tech & Conversions » URGENT : Info required 3SGTE (ST165)
RWDboy
URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:35 Go to next message
Need a bit of info regarding ST165s. Seems that it's a little tricky to get hold of ST165 engines these days (surprise) but finding a 185 engine isn't half bad. The only question is, aren't they mounted on different angles, would this cause issues with fitting a 185 engine into a 165?
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:37 Go to previous messageGo to next message
Oh, and I suspect that using the 165 external parts (ie everything but block and head) is the way to go in terms of ease of fitting.
warrior
Sydney / NSW
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:38 Go to previous messageGo to next message
nah mate they mount on the same angle. and fit straight in. the difference is in the cooler. I am not too sure but you may have to run your ST165 cooler or put a scoop on the bonnet.
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:43 Go to previous messageGo to next message
you 100% on that?
Senor_2
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:44 Go to previous messageGo to next message
I know of a place that should still have a complete ST165 engine for sale in Sydney if u need one.
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:46 Go to previous messageGo to next message
senor -> pm me the details (name of business, approx location and phone number plz?)
warrior
Sydney / NSW
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:47 Go to previous messageGo to next message
there is one on the forums for sale Stephen. it is running the ST165 intercooler, cause ST185 is air-air, no bonnet scoop and engine sits fine.
http://forums.toymods.org.au/index.php?t=msg&t h=56111&rid=5064&S=38f2932ef80cd3c087e5368 407bcf2dc
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:52 Go to previous messageGo to next message
The ST185 can have water-air if you have the grp a model...don't forget that!
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:57 Go to previous messageGo to next message
you have pm warrior
warrior
Sydney / NSW
and so does the st205...but where do u get grpA or ST205 without having to give away your 1st born child
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 01:59 Go to previous messageGo to next message
lol - yeah I realise this - just mentioning Smile
Does anyone know if there are any internal differences between the 165 and the 185 motor (ie pistons/cams etc?).
Senor_2
Sent u a PM FWDboy
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 02:01 Go to previous messageGo to next message
cheers!
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 02:24 Go to previous messageGo to next message
I hear the 185 has a different compression ratio - is this true?
davedave
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 02:29 Go to previous messageGo to next message
Doesn't mention compression ratios, but has a bunch of other useful info
http://gtfour.supras.org.nz/3sgte%20table.htm
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 02:38 Go to previous messageGo to next message
I think it's 8.8:1 for the St185, and 8.5:1 for the 165 (and co-incidentally the 205 too)
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 02:42 Go to previous messageGo to next message
So I need definite confirmation, has anyone who has PHYSICALLY themselves put the ST185 engine into a ST162 or ST165 tell me that the blocks (externally) match up no problems?
RWDboy
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 02:46 Go to previous messageGo to next message
And that the standard ST165 ECU doesn't have any issues with the higher compression ratio (don't most 3SGTEs have a knock sensor?)
warrior
Sydney / NSW
Re: URGENT : Info required 3SGTE (ST165) Wed, 12 January 2005 05:32 Go to previous message
you have a PM re-shipping
Previous Topic:TA22 steering
Next Topic:3sgte head gasket question
Current Time: Fri Nov 20 11:36:12 UTC 2026
Total time taken to generate the page: 0.0083549022674561 seconds
