Classifieds » Engines, Accessories and other Mechanicals » FS: GFB Blow Off Valve SOLD
ke382TG
FS: GFB Blow Off Valve SOLD Wed, 12 January 2005 02:22 Go to next message
I have one GFB Blow Off Valve for sale, it is currently fitted to my car. It looks exactly the same as the one in the pic below but mine is blue instead of red.
Works perfectly, excellent condition (one minor rub mark about 2mm diameter on the blue anodised section), quite loud when venting, adjustable spring preload on the piston. I also have the steel weld-on fitting to go with it (I never used it becuase my piping is aluminium).
Reason for selling: I am going back to plumb-back.
NOTE: will consider swap for similar style BOV in plumb-back type, as long as it is in the same good condition Very Happy
Price: $100 + postage. Negotiable. COD or Pick-up only
Cheers.
Oh yeah, Thorpie says it sounds "fully sic"
http://forums.toymods.org.au/index.php?t=getfile&id=9022
Attachment: GFB BOV.jpg
(Size: 5.13KB, Downloaded 147 time(s))
[Updated on: Fri, 21 January 2005 01:11]
ke382TG
Re: FS: GFB Blow Off Valve Sun, 16 January 2005 22:16 Go to previous messageGo to next message
Bump.
celica28
Re: FS: GFB Blow Off Valve Mon, 17 January 2005 02:00 Go to previous messageGo to next message
Shane,
Have a chat to Mitch as he mentioned he wanted to join the Blow Off Gang over the weekend.
ke382TG
Re: FS: GFB Blow Off Valve Mon, 17 January 2005 03:43 Go to previous messageGo to next message
I will have a chat to him and cut him a deal if interested Smile
ta23
Re: FS: GFB Blow Off Valve Mon, 17 January 2005 08:11 Go to previous messageGo to next message
Interested, where abouts are you located?
When you say "adjustable spring preload on the piston" does that mean you can adjust the sound it makes by twisting it?
ke382TG
Re: FS: GFB Blow Off Valve Mon, 17 January 2005 22:49 Go to previous messageGo to next message
Located in Canberra.
The adjustable spring pre-load acts upon the piston, more tension makes it harder to open i.e. more boost to open it is required.
It does not change the sound of it though, unless you wind up too much spring tension and it does not open at all Laughing Then you get the flutttering sound of compressor surge that so many dim-wits think is their BOV Laughing
[Updated on: Mon, 17 January 2005 22:50]
ta23
Re: FS: GFB Blow Off Valve Tue, 18 January 2005 04:28 Go to previous messageGo to next message
OK cool, so the spring tension is just adjusted by twisting a certain section of the BOV
ke382TG
Re: FS: GFB Blow Off Valve Tue, 18 January 2005 05:40 Go to previous messageGo to next message
correct.
In the small pic in the first post you can see that the nipple to which you fit the vaccuum hose is threaded. This is what adjusts the spring pre-load on the piston.
ta23
Re: FS: GFB Blow Off Valve Wed, 19 January 2005 22:07 Go to previous message
PM sent
Previous Topic:supra g/box
Next Topic:FS:SC12 Super Charger,GT-Z Bonnet, 4AFE Extractors
Current Time: Thu Oct 22 10:50:17 UTC 2026
Total time taken to generate the page: 0.005803108215332 seconds
