Toymods » Tech & Conversions » Negative camber on a KE20
closer
Negative camber on a KE20 Wed, 12 January 2005 11:03 Go to next message
anyone know how i can acheive this ?? custom strut tops or something of the like. has anyone dont it who can offer some advice ??
ive got my struts converted to coilover height adjustable so they are the ones i wanna use.
shan
Re: Negative camber on a KE20 Wed, 12 January 2005 11:07 Go to previous messageGo to next message
each cm you move the strut top in = 1 deg neg camber.. or thereabouts
clubagreenie
1st street on the right
Re: Negative camber on a KE20 Wed, 12 January 2005 13:26 Go to previous messageGo to next message
Geometricly speaking isn't 1mm in a meter 1/2 a degree?
Re: Negative camber on a KE20 Wed, 12 January 2005 20:41 Go to previous messageGo to next message
not exactly..
if you have a circle with circumference = 360cm, then 1cm = 1 deg.
2*Pi*r = 360
r = 360/(2*Pi)
r = 57cm.
the length of the strut is approx 50-60cm, so each cm you move the top or bottom is approx 1deg camber Smile
clubagreenie
Re: Negative camber on a KE20 Wed, 12 January 2005 21:58 Go to previous message
That's quite interesting and if I'd thought about it I would have realised. I was referencing off detail on roofing squares and levels that has exactly what I first posted (not disputing you 'cause it's plainly correct) just what was stuck in my mind. What would you say they are refering to? Because I recently pitched a roof off the squares angles and it was ok?
Previous Topic:lowering block fitment
Next Topic:log manifold questions
Current Time: Fri Nov 20 15:51:13 UTC 2026
Total time taken to generate the page: 0.004558801651001 seconds
