Toymods » Tech & Conversions » subaru stud pattern
4DaDrift
subaru stud pattern Wed, 12 January 2005 15:37 Go to next message
wondering what stud pattern modern subarus have
the wheels im looking at are 15 by 6 with a 55 offset if that helps anyone
cant find any markings stating what 5 spoke stud pattern tehy are unfortunatelly
desire to know if they fit on a sv21
Re: subaru stud pattern Wed, 12 January 2005 19:38 Go to previous messageGo to next message
I'm pretty sure they DO have 5x100 and will fit a camry/FWD celica.
4DaDrift
Re: subaru stud pattern Thu, 13 January 2005 00:59 Go to previous messageGo to next message
sweet as thanks m8
Re: subaru stud pattern Thu, 13 January 2005 01:01 Go to previous messageGo to next message
Isn't that offset a little massive for a SV21?
bbaacchhyy
Re: subaru stud pattern Thu, 13 January 2005 01:49 Go to previous messageGo to next message
justcallmefrank wrote on Thu, 13 January 2005 11:31
Std is 45P
Well then wouldn't a 20mm reduction in track be illegal?
st184 sillycar
Re: subaru stud pattern Thu, 13 January 2005 01:58 Go to previous messageGo to next message
I think so. Can't remember the maximum track change, it's only about 10 or 15mm from memory - but don't take my word for it!
I looked at countless 5x100 hub rims for my Celica - and all you can bloody get is +45 or +48 offset for WRX. It's a Gay poofter stud-pattern widt teh aidz. I gave up in the end.
They wouldn't clear my struts with that offset - I needed +34 -> +38, and just couldn't get hold of any decent looking ones.
Good luck Hombre'
[Updated on: Thu, 13 January 2005 01:59]
MIKGTR
Re: subaru stud pattern Thu, 13 January 2005 20:31 Go to previous messageGo to next message
Sorry I'm confused, do WRX wheels have the right offset for a fwd Celica???
matt86sx
Gold Coast, QLD
Re: subaru stud pattern Thu, 13 January 2005 22:43 Go to previous messageGo to next message
No the offsets are different, although they definitely share the same 5x100 stud pattern.
All FWD Celica offsets are +39. (I assume SV21's have the same) If the WRX rims have a +55 offset as stated then the rims will be sitting 16mm (55-39) further inwards than normal. This will:
a) reduce track width by 32mm (16x2), which may turn out to be illegal (it is in QLD anyway)
b) bring the inner sidewall of the tyre closer to the struts, possibly even rubbing on them. If the rim is wider then the original then this increases the chances of this happening as well.
c) look gay because the wheels are sitting futher inwards and not filling the guards like they did before.
The easy way out of this is to fit wheel spacers to make up the offset difference, but you'd have to check on the legalities of them. (Again, illegal in QLD)
Still, it can be done - I have seen an ST184 running around with WRX rims on it, no idea what size/width rims they were though.
Matt
Dust
Re: subaru stud pattern Fri, 14 January 2005 02:41 Go to previous messageGo to next message
spacers are illegal in qld? our celica has em, they were put on by the tyre shop, hmmmmmmm.
There a copy of this law somewhere?
matt86sx
Gold Coast, QLD
Re: subaru stud pattern Fri, 14 January 2005 02:59 Go to previous messageGo to next message
Yep, it's in the "All About Modifications to Motor Vehicles" booklet from QLD Transport, page 17. Check link below:
http://www.transport.qld.gov.au/qt/driver.nsf/file s/images/$file/Vehicle-Modifications.pdf
It's also where I got the track info as well, p19 states that reducing the track width (which fitting rims with an increased offset will do) is not permitted, but may be increased by up to 26mm (ie 13mm per side).
Matt
syncro
ireland
Re: subaru stud pattern Fri, 14 January 2005 06:35 Go to previous message
golf or corrado vr6 has et33 or et35 i think, the bbs ones i got for my golf had 7.5x17 et33 stamped on them and they were for a corrado vr6 and 5x100 pcd
audi tt wheels should be suitable too or mk4 gti
Previous Topic:7MGE Head Gasket repair- pics provided, advice please...
Next Topic:Lexus ES300 (1992) - Stalling when running AC
Current Time: Thu Oct 15 08:52:06 UTC 2026
Total time taken to generate the page: 0.0078678131103516 seconds
