Toymods » Tech & Conversions » Top Feed Injectors
acreese
Top Feed Injectors Thu, 13 January 2005 07:41 Go to next message
Hello
i am looking for some information regarding top feed injectors.
they must be compatible with the Gen1 3SGE (13.8 ohms) and flow
~380+ cc/min.
What injectors do people know of that will meet these criteria?
Target power is 150Kw
What cars/engines do they come from.
I have searched, and as far as i can find I can't seem to get above 315cc Sad in a toyota engine.
315cc min is not enough for 150Kw is it? @ 80% duty.
Any help would be greatly appreciated.
Adam
Re: Top Feed Injectors Thu, 13 January 2005 08:28 Go to previous messageGo to next message
http://www.toysport.com/webpages/Techinfo/Referenc es/injectors.htm
and
http://www.z31.com/software/injector.pl
MS-75
Re: Top Feed Injectors Thu, 13 January 2005 22:53 Go to previous message
Crunching the numbers, I calculate you getting 380cc flow out of 315's if you bump the rail pressure up from 38psi (usual toyota flow rate test pressure if I remenber correctly) to 55-56 psi. Any of the Bosch pumps will do this no worries.
Sean
Previous Topic:overheating but not???
Next Topic:balance tube for twin sides
Current Time: Thu Oct 15 10:44:52 UTC 2026
Total time taken to generate the page: 0.0040850639343262 seconds
