Toymods » Tech & Conversions » How to turn my car into a 1/2 cut?
How to turn my car into a 1/2 cut? Thu, 13 January 2005 23:14 Go to next message
Hi all, I have a ra28 shell in my garage that I plan to use for projects like my 3sgte engine conversion and next brake upgrade etc. I want to turn into a 1/2 cut so it takes up less room and is easier to work on.
How do you think its best to cut it in half?
I have an angle grider, but not sure how this will go getting through chassie rails etc.
Joel
Skip
Re: How to turn my car into a 1/2 cut? Thu, 13 January 2005 23:18 Go to previous messageGo to next message
Gas axe?
lumpy
Adelaide, SA
Re: How to turn my car into a 1/2 cut? Thu, 13 January 2005 23:24 Go to previous messageGo to next message
Angle grinder works OK - just have a few metal cutting disks and take it slowly, don't ush the blade too hard. I cut up the remains of an ma70 half-cut into small pieces with a 4.5 inch angle grinder. Surprisingly easy, and didn't take long at all.
Chassis rails are usually not that thick, strength comes from their box shape construction.
STR8 2.8
Re: How to turn my car into a 1/2 cut? Thu, 13 January 2005 23:26 Go to previous messageGo to next message
yeh get an oxy cutter. itll take you two seconds
Re: How to turn my car into a 1/2 cut? Thu, 13 January 2005 23:32 Go to previous messageGo to next message
I might have a go with the angle grider and if not go out and see if I can hire an oxy cutter?
Purple_Beasty
New Zealand
Re: How to turn my car into a 1/2 cut? Thu, 13 January 2005 23:49 Go to previous messageGo to next message
Its a little rough, but an axe will get through what you can't cut with an angle grinder.
Callum
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 03:12 Go to previous messageGo to next message
plasma cutter? might be messy and hot, but very quick
Toobs
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:03 Go to previous messageGo to next message
Most of the half cuts I have seen have been chopped with an oxy / gas axe.
They generally cut through the middle of the front pillars and through the floorpan at the middle of the front doorsills.
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:05 Go to previous messageGo to next message
Yeah I could imagine an oxy would be quite easy. I am going to push out the front windscreen this weekend and cut through the front pillars with the angle grinder which should be real easy.
Then have a go at the floor and see what happens Smile
Kyosho
Wollongong
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:16 Go to previous messageGo to next message
I am amazed no one has mentioned to pull out the fuel lines first...
If you hit one of those and there are vapours in it, it could be pretty bad... Make sure the fuel tank is completely empty as well...
And unplug all the wires so that you don't cut through wiring looms
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:21 Go to previous messageGo to next message
Ahh yeah good point. The fuel tank is already out of it, and no engine in there.. But suppose fuel or vapours could still be sitting in the lines.
I'll undo and remove these first!
Joel
Kyosho
Wollongong
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:30 Go to previous messageGo to next message
TurboRA28 wrote on Fri, 14 January 2005 15:21
Joel
If the tank is out, the motors out...
Why not just pull out the other parts you need (Brakes, crossmembers) properly, and sell the shell off?
WOuldn't it be easier? Some one might have a need for the car shell and other bits and pieces
alex_ta22
Newcastle, Hunter Valley
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:33 Go to previous messageGo to next message
Kyosho wrote on Fri, 14 January 2005 15:30
Joel
I think he is using it to dummy fit engine conversions and brake upgrades to
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:35 Go to previous messageGo to next message
Thats right, its so I can build up my new engine and brake setup and not take my RA28 off the road. Once its all done in the dummy car I can move it all over quickly Smile
Kyosho
Wollongong
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 04:38 Go to previous messageGo to next message
TurboRA28 wrote on Fri, 14 January 2005 15:35
Ahh I see now... I thought you were using the shell as a donor car... It's all clear now... LOL
Jayem
Finland
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 05:35 Go to previous messageGo to next message
http://www.hhtuonti.fi/tuotteet/sahkotyokalut/SKD2902VV.jpg
Handy and less noise than angle grinder. With proper blade you can cut chassis rails.
Corona RT142
Campbelltown
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 05:39 Go to previous messageGo to next message
be a man use a hack saw Rolling Eyes
lumpy
Adelaide, SA
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 06:04 Go to previous messageGo to next message
The half cut I bought was chopped through the pillars with a big arse angle grinder. They also went straight through the damn windscreen and left the bottom half of it in the car. I was picking bits of glass out of my knees for days after pulling the dash/remaining interior out. Crying or Very Sad
Jayem
Finland
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 06:10 Go to previous messageGo to next message
I have turned CE-70 and SV-21 into three pieces by only using hack saw, shears and iron bar. Laughing
[Updated on: Fri, 14 January 2005 06:13]
bah - that car is so rusty you could chop it with a steak knife!!
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 06:16 Go to previous messageGo to next message
Haha thats true Witzl.. Will need to get those wheels and steering box to you.
Joel
jcmunga
adelaide
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 07:01 Go to previous messageGo to next message
why would you kill an ra28, there already hard to find and your gonna chop one in half, why not use an ra23, same front and theres shit loads of them around
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 07:06 Go to previous messageGo to next message
THE WITZL wrote on Fri, 14 January 2005 14:10
I'd say thats why Smile
V8_MA61
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 11:20 Go to previous messageGo to next message
dont do it with a 4" grinder...borrow a 9" off someone, but be careful as they are bloody dangerous...
brett_celicacoupe
townsville NQLD
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 12:17 Go to previous messageGo to next message
i have cut a 69' corona into 4 pices with simply a wood chisel and a hammer Shocked . its not as slow as u think, get a bit of technique happenin an u will fly through it. the chisel i had was only like 15mm wide too.
brett
V8_MA61
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 12:18 Go to previous messageGo to next message
brett_celicacoupe wrote on Fri, 14 January 2005 22:17
brett
i bet that was a lot harder and longer than it'd take with about 2500watts and a 9" cutting disc Razz
Corona RT142
Campbelltown
Re: How to turn my car into a 1/2 cut? Fri, 14 January 2005 23:02 Go to previous messageGo to next message
but not nearly half the fun, get the chisel out and take out the rage
CLG
Perth, Western Australia
Re: How to turn my car into a 1/2 cut? Sat, 15 January 2005 05:20 Go to previous messageGo to next message
Stop fucking about boys, just go and get a 9" angle grinder - will do the job in about 30 seconds.
Re: How to turn my car into a 1/2 cut? Sat, 15 January 2005 07:29 Go to previous messageGo to next message
Done Smile took around 1 hour or so with a 4 inch grinder.
I'm actually now thinking to turn the rear half into a trailer.. How cool would that be, a RA28 trailer Smile
Joel
jesseT18
Castle Hill, Sydney
Re: How to turn my car into a 1/2 cut? Sat, 15 January 2005 07:42 Go to previous messageGo to next message
hahah DO IT!
quest
u.s.a. south
Re: How to turn my car into a 1/2 cut? Sat, 15 January 2005 21:45 Go to previous messageGo to next message
I've cut up alot of cars (among other things) with that type saw pictured above. We call em a 'sawzall'. A good $2 14tpi blade will run thru a car like a hot knife thru butter
HyDrA
Adelaide, SA
Re: How to turn my car into a 1/2 cut? Sat, 15 January 2005 23:28 Go to previous message
Plasma cutter Evil or Very Mad Evil or Very Mad
Previous Topic:VVTi values/settings for 4AGE-20v SilverTop
Next Topic:Targa Top
Current Time: Fri Nov 20 08:12:20 UTC 2026
Total time taken to generate the page: 0.10720205307007 seconds
