Toymods » General Car Talk » Any easy way to remove alternator whine?
Phrostbyte
Frankston, Victoria
Any easy way to remove alternator whine? Thu, 13 January 2005 23:34 Go to next message
Hey there,
Recently (all of a sudden) I've started to experience alternator whine coming from my subbies and speakers powered by the amp at the back. Ruling out the most obvious thing I rewired the speaker wires down the opposite side of the car to the power wire, but to no luck...
I was told there was some sort of filter you could buy, and at the moment have no money, is there any way I can make myself a filter out of anything? Or does anyone know any other methods to obliderate the alternator whine (other than removing my alternator hahahahahaha Laughing).
Thanks.
Dale_ta22
Forster NSW
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 02:26 Go to previous messageGo to next message
An alternator noise suppressor, I think they are called. Couldn't say how well they work though, nor how much they are worth.
fade-e
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 02:47 Go to previous messageGo to next message
iv found that this is usually caused by an electrical leak somewhere... especially if it didnt happen previously and then just started
why would it just start? something has changed somewhere
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 03:23 Go to previous messageGo to next message
Most cars come stock with suppressors fitted to noisy things in the engine bay like alternators, igniters, etc etc.
These suppressors however start braking down and drying out with heat so they will not last for ever.
You could try replacing the factory fitted items or simply add another to the alternator or whatever is causing the noise.
styler
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 07:05 Go to previous messageGo to next message
[Updated on: Fri, 14 January 2005 07:11]
styler
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 07:09 Go to previous messageGo to next message
there is a thread : stereo whine / noise FAQ
installation problems - connections bad / wrong ie ground loop
- crosstalk induced from power wires
- standard supressors (condensors) bad
gradual / sudden problems - connections have loosened
- condensors have gone bad
<edit> yeah had a mixup
noise filters are put in the power circuit so depending
on what amperage your circuit is you will be able to get
the correct filter. 10amp, 20amp, 30 amp, 40amp are common
and 30 amp is about $35. i doubt you could build one for that
if at all.
noise filters are a band aid to cover the real problem,
some wont even be able to supress the noise as i found out
[Updated on: Sat, 15 January 2005 03:48]
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 08:05 Go to previous messageGo to next message
styler wrote on Fri, 14 January 2005 17:09
noise supressors are put in the power circuit so depending
the correct supressor. 10amp, 20amp, 30 amp, 40amp are common
if at all.
noise supressors are a band aid to cover the real problem,
Noise suppressors suppress noise. They are fitted to the device that is creating the noise.
Noise filters go in line with your audio devices to help prevent noise entering the circuit.
Get it right
Gazza53
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 09:02 Go to previous messageGo to next message
The output of the alternator is actually rectified AC.
The supressor filter reduces some of the noise, left over after the diodes have done their bit.
If replacement of the supressor doesn't fix the problem then it is time for a new or rebuilt alternator.
rthy
Melbourne - NthSubs
Re: Any easy way to remove alternator whine? Fri, 14 January 2005 09:48 Go to previous messageGo to next message
remove ur sub
styler
Re: Any easy way to remove alternator whine? Sat, 15 January 2005 04:23 Go to previous message
indeed lol, mixup edited Very Happy
Previous Topic:My 86 stolen ADELAIDE
Next Topic:ae82 fuel pump
Current Time: Sat Nov 21 18:47:16 UTC 2026
Total time taken to generate the page: 0.0048489570617676 seconds
