Toymods » Tech & Conversions » Starting a long sitting engine
Kyosho
Wollongong
Starting a long sitting engine Fri, 14 January 2005 06:33 Go to next message
Hey people...
I might be able to get my hands on a car that has been sitting in a well protected area for around 2-3 years...
In that time the engine has not been started...
Now I know I will need a new battery, new fuel (After draining what ever is in tank)
But I want to know, how can I get everything "safe"? Should I put petrol into the cylinders and wind the motor over by hand?
I've heard of valve stem seals getting brittle, should oil or something be put on them befor starting to try and soften them?
Would new plugs and leads be advisable?
Re: Starting a long sitting engine Fri, 14 January 2005 06:39 Go to previous messageGo to next message
Some people suggest squirting a little bit of oil in the cylinders. Other people just suggest cranking it over for a little bit without the spark plugs.
The valve stem seals have probably hardened, but they should soften up a little over time through heat cycling.
M.J.H
Re: Starting a long sitting engine Fri, 14 January 2005 06:43 Go to previous messageGo to next message
The best thing to do is drain the oil and fit a oil filter as well.Put a cap full at the most of oil down the cylinders and wind the motor over by hand a few times to oil up the bores.
Remove the rocker cover and fill with new oil while covering the cam,rockers and chain etc in oil then refitt rocker cover.
As you said new plugs and points if needed.
If it's got a elec pump then pump up the fuel first or if not the use a bottle with fresh fuel so it doesn't have to drag it from the tank.
Then hopefully when all is done it should go first time.Good luck.
What sort of car and engine btw?
Kyosho
Wollongong
Re: Starting a long sitting engine Fri, 14 January 2005 06:46 Go to previous messageGo to next message
justcallmefrank wrote on Fri, 14 January 2005 17:39
So there isn't much I can do for the valve stem seals then?
What about other things to check first?
Re: Starting a long sitting engine Fri, 14 January 2005 06:47 Go to previous messageGo to next message
Not that I know of, I'm just regurgitating what people have told me, my engine hasn't been started in years.
Kyosho
Wollongong
Re: Starting a long sitting engine Fri, 14 January 2005 06:50 Go to previous messageGo to next message
M.J.H wrote on Fri, 14 January 2005 17:43
Thanks for all that...
The car is a *A70 Supra...
Unsure of which engine, hence the *...
I want the MA70...
I was told by a friend that there is a *A70 Supra near his mates place in a full securo car park, and they use the car park, and they know the car hasn't been moved in at least 2 years... They are going to leave a note on the car to see if the owner wants to sell...
I'm hoping its Auto (Even though I prefer manuals, but it's a work ethics thing)
Kyosho
Wollongong
Re: Starting a long sitting engine Fri, 14 January 2005 06:52 Go to previous messageGo to next message
justcallmefrank wrote on Fri, 14 January 2005 17:47
You should now go out with M.J.H. info and start your engine! LOL
Thanks for the help guys...
Re: Starting a long sitting engine Fri, 14 January 2005 06:55 Go to previous messageGo to next message
Kyosho wrote on Fri, 14 January 2005 14:52
I'm working on it! Smile http://iamfrank.ath.cx/14012005/images/14012005%20 008.jpg
Kyosho
Wollongong
Re: Starting a long sitting engine Fri, 14 January 2005 07:07 Go to previous messageGo to next message
justcallmefrank wrote on Fri, 14 January 2005 17:55
Oh that looks nice...
Go and hurry up... Razz
WiLo
wollongong NSW
Re: Starting a long sitting engine Sat, 15 January 2005 09:36 Go to previous message
Kyosho wrote on Fri, 14 January 2005 17:50
I want the MA70...
the person that told you that must be a champion for telling you about that dont you think kyosho:P
havent spoken to the guy yet but will more then likely see him tomorrow
Previous Topic:ST 184 celica- power steering in a Camry
Next Topic:Igniter input characteristics
Current Time: Tue Oct 27 11:42:16 UTC 2026
Total time taken to generate the page: 0.057893991470337 seconds
