Toymods » Tech & Conversions » keep snaping balancer key?
mikes86
goldy coast
keep snaping balancer key? Sat, 15 January 2005 00:23 Go to next message
Hey about 4 months ago i snapped the key that holds the harmonic balance and crank shaft timing gear in my rwd 4age, and last night it did it again! Mad, what would be the reason for this? could there be to much play in the key way,or my cranck shaft needs to be balanced or something?
mike
Re: keep snaping balancer key? Sat, 15 January 2005 00:36 Go to previous messageGo to next message
too muich play in keyway and/or key is wrong size
mikes86
goldy coast
Re: keep snaping balancer key? Sat, 15 January 2005 06:10 Go to previous messageGo to next message
yeh thought so ill get it sorted anyways just i hope it doesnt do it again because its a serious pain in the dot
improvedae86
Re: keep snaping balancer key? Sat, 15 January 2005 06:21 Go to previous messageGo to next message
Harmonic distortion caused by crankshaft flex ? what is it happening at 11.000 rpm , sounds like the pulley keyway might be shagged out , or its not going to full distance on the crank . Does the pulley line up correctly when installed ?
mikes86
goldy coast
Re: keep snaping balancer key? Sat, 15 January 2005 07:05 Go to previous messageGo to next message
improvedae86 wrote on Sat, 15 January 2005 17:21
no 1st time it happend was at 6000 rpm this time was at max 4000 rpm,also the pulley lines up how it should so i dont think it is that. Another thing i notice when the engine was running before it broke at a 850-1000rpm idle the balancer had a slight wobble nothing crazy but when rev'd higher it would straighten up, would this slight wobble slowly break down the key and balancer?
allencr
tallahassee FL usOFa
Re: keep snaping balancer key? Mon, 17 January 2005 03:49 Go to previous messageGo to next message
sure, any wobble is going to load it more then something that is running smooth & true.
how long was before the first time????? how long after it was installed, for a timing belt or something?
the key only does and is only capable of a small percentage of the holding power necessary, so it needs torque & good surfaces. it has to be installed right.
i think the thing came loose at first because of a poor install, and the 2nd time because the surface of the hub and the timming gear/pully weren't smooth & flat. a right hand thread & rough surfaces & low torque arent going to last long.
mikes86
goldy coast
Re: keep snaping balancer key? Mon, 17 January 2005 08:45 Go to previous messageGo to next message
i half pulled it apart yesterday to have a better look and the actual key is still good only abit worped im guessin from when the balancer snapped off, after pulling another harmonic balncer n holder bolt straight off another engine ive notice that the bolt is different to the 1st two that have stuffed up i know the last bolt i used was off a 7me..? but was exacly the same as the bolt that was in there.
so im guessing that the bolt was to fault this time maybe thats y the head snaped off it and the stud is still inside my crank shaft Confused
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: keep snaping balancer key? Mon, 17 January 2005 10:22 Go to previous messageGo to next message
The same thing happened to mine quite a while ago now, but I was lucky enough (I guess) to have the key sheared & also the threads on the bolt completely work away, so the crank itself was very much reusable. The pulley was pretty rooted too.
I've heard that the original single piece bolt (1 piece bolt & big washer) had something to do with this problem, & toyota changed the design to a 2 piece bolt & seperate washer in an attempt to rectify the prob. If you buy a new bolt from toyota it will be of the newer 2 piece design. The washer doesn't come off the bolt but it is loose & free to rotate. How this would affect things I have no idea. Maybe something to do with preloading the key at the assembly stage....
Probably the best (and of course hardest/most expensive) solution to the problem is to get rid of the stupid tiny little half moon key & key way slot & have the keyway in your crank machined out to take a proper full length key, which would put up with alot more stress without failing. It does of course mean pulling the crank out, which wouldn't be worth doing just for that reason I reckon, but if you're ever getting a 4AGE rebuilt it's definitely worth having done, and would only add around $80 to your total rebuild costs. It seemed a rather insignificant cost to me when I was getting my current motor rebuilt for 4AGTE use.
[Updated on: Mon, 17 January 2005 10:25]
mikes86
goldy coast
Re: keep snaping balancer key? Mon, 17 January 2005 10:37 Go to previous messageGo to next message
oh k so the origonal bolt the 1 piece was no good? the one i have now is the 2 piece, so this should help?
BigWorm
Turramurra, Sydney.
Re: keep snaping balancer key? Mon, 17 January 2005 22:52 Go to previous messageGo to next message
Yep, that's what I've heard.
mikes86
goldy coast
Re: keep snaping balancer key? Tue, 18 January 2005 12:25 Go to previous messageGo to next message
oh ok should be all good then this time.... Smile on another note would anyone be able to give me a rough price on some nevo balancers for a 4age i was thinking while its off i might aswell throw on a better one Very Happy
dingaling
tas
Re: keep snaping balancer key? Tue, 18 January 2005 13:16 Go to previous messageGo to next message
I had a simualr problem. My pulley was wobbeling quite bad when i got the car, when i took it off to inspect, the key was sheared in half, the keyway in the crank itself was worn to the point of the keyway unable to slot in straight. Buaght a new crank pulley and made my own key out of case hardened steel and made sure it would stay in place. Also tightened the it RIGHT up to specs, obviously the previous person to remove it did not tighten it up enough.
Also abit of a design flaw in my opinion is having the thread the wrong way around, so instead of that big bolt tightening with the engine spinning, it has the opposite effect of working it's way loose.
Starfire
Re: keep snaping balancer key? Wed, 19 January 2005 02:14 Go to previous messageGo to next message
If the keyway has broken it is possible that the pulley has worn down the crank snout by spinning on it and therefore will be too loose.
The crank pulley should have a reasonably tight fit with the crank and the key.
I would suggest that if you change it you should pick up new keys and a new crank bold from toyota. Itll only cost you $10 or so.
mikes86
goldy coast
Re: keep snaping balancer key? Wed, 19 January 2005 10:50 Go to previous message
ok my next question how would i go about extracting the balancer bolt stud out of my crank shaft? i was thinking an easy out but its impossible to drill through the stud Mad
mike
Previous Topic:03-70LE automatic, A4...? exact type missing
Next Topic:Sprinter Handbrake Cable
Current Time: Wed Nov 18 09:17:08 UTC 2026
Total time taken to generate the page: 0.011188983917236 seconds
