Toymods » Tech & Conversions » fuel pressure regulator???
mx83toy
fuel pressure regulator??? Mon, 21 October 2002 13:45 Go to next message
i don't understand the pupose/workings of these to much, i had some one tell me they help with the tuning of the a/r ratios???
Purple_Beasty
New Zealand
Re: fuel pressure regulator??? Mon, 21 October 2002 18:32 Go to previous messageGo to next message
Basically if you increase pressure (with an adjustable reguator) you can get more fuel flow through your injectors. Very handy if you are borderline on needing an upgrade. Main problem is unlike properly tuning your computer your fuel supply will increase at ALL engine speeds/loads, so it is a very primative tuning tool.
Hopefully someone else can give a little more detail of the benefits/drawbacks.
Purple_Beasty
New Zealand
Re: fuel pressure regulator??? Mon, 21 October 2002 18:33 Go to previous messageGo to next message
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: fuel pressure regulator??? Tue, 22 October 2002 13:10 Go to previous message
They actually come standard on pretty much all EFI cars. They are a vacuum controlled restrictor, that is open at full vacuum (idle). As vacuum drops fuel pressure increases, and thus more fuel can flow.
I guess it's just a coarse adjustment before the injector duty does the adjusting.
Previous Topic:18RGU problems?
Next Topic:tweakin the 4AGE
Current Time: Sat Nov 21 04:22:16 UTC 2026
Total time taken to generate the page: 0.0059020519256592 seconds
