Toymods » Tech & Conversions » 3 wire turbo timer installation
craufurd
Auckland
3 wire turbo timer installation Sat, 15 January 2005 09:38 Go to next message
i have installed a three wire turbo timer into my project car - ke70 3tgte - but i dont have the instructions. i have spliced it onto the steering column to +12V, and to IG (i think) (black w/ yellow stripe) and grounded. when i turn the key off however the engine stops but i can still use accessories like heater fan etc. for 1 minute. I thought i might be splicing the loom in the wrong place as the engine runs on a separate loom to the car- should i splice the TT to the IG teminal on the ecu instead? or somewhere else
mikey93
Re: 3 wire turbo timer installation Sat, 15 January 2005 10:12 Go to previous messageGo to next message
hmm are you sure thats the ignition not the acc you've tapped into?
malazn
Re: 3 wire turbo timer installation Sun, 16 January 2005 09:14 Go to previous messageGo to next message
easiest way to check if you spliced into the acc wire is shut down as normal and see if the acc works after the timer turns off..
if it does then you have spliced into the acc wire.. Rolling Eyes
craufurd
Auckland
Re: 3 wire turbo timer installation Sun, 16 January 2005 09:42 Go to previous messageGo to next message
well it certainly seems that way Smile i'll find my wiring diag and see what i've done but im pretty sure black with yellow stripe is the the colour code for IG.
Re: 3 wire turbo timer installation Sun, 16 January 2005 10:14 Go to previous messageGo to next message
Dont use a diagram to find the colour wire, use a multimeter/test light. Then you can be sure.
Joel
malazn
Re: 3 wire turbo timer installation Sun, 16 January 2005 23:55 Go to previous messageGo to next message
agreed
[Updated on: Sun, 16 January 2005 23:56]
Toobs
Re: 3 wire turbo timer installation Mon, 17 January 2005 01:20 Go to previous messageGo to next message
Just look for the wire that is only +ve 12V when the ignition is on and DOESN'T drop to 0V when the starter motor is cranked.
craufurd
Auckland
Re: 3 wire turbo timer installation Mon, 17 January 2005 04:43 Go to previous message
yeah...nice touch
Previous Topic:My T50 sucks!
Next Topic:What does a 92 Cressida weigh?
Current Time: Fri Nov 20 21:10:26 UTC 2026
Total time taken to generate the page: 0.0070891380310059 seconds
