Toymods » Tech & Conversions » crank work/machining. any point????
people100
Rocklea qld
crank work/machining. any point???? Sat, 15 January 2005 21:38 Go to next message
the engine is a 18rgeu with turbo. ive heard of people detsressing cranks etc. is there any point or should i just run the crank standard. Anything else i should do to the crank besides cleaning it?
tilio_enduro
icon14.gif  Re: crank work/machining. any point???? Sun, 16 January 2005 00:26 Go to previous messageGo to next message
I reckon with what you're doing to the engine destressing the crank will be very important, otherwise there is good chance of crank failure.
All the guys who build their crazy drag cars do it, as crank failure is really high in engines when you have them putting out huge power.
Good Luck!! Very Happy
people100
Rocklea qld
Re: crank work/machining. any point???? Sun, 16 January 2005 00:44 Go to previous messageGo to next message
i did think about the but the car will not be drivin hard all the time...its mainly a weekend toy and to get my to work (5 minute drive). So i dont know how nessicary it is
tilio_enduro
Re: crank work/machining. any point???? Sun, 16 January 2005 09:44 Go to previous message
My understanding was its not how often you drive the car hard, but how hard you drive it; so if you took it upto 6000 RPM max, then it should be OK; but if you take it to 7,000 - 7,500 even just a few times it might be enough to stuff the crank.
Even if you don't touch the crank you may want to find if you can get ARP Big end bolts for your crank - apparently they are very successful at reducing crank / bearing problems in 3SGTE's that are driven very hard.
Cheers!! Very Happy
Previous Topic:Beams 3SGE inlet manifold on ST205 3SGTE?
Next Topic:Power Steering Workshops
Current Time: Fri Nov 20 06:15:15 UTC 2026
Total time taken to generate the page: 0.0075027942657471 seconds
