Classifieds » Engines, Accessories and other Mechanicals » 18rgeu engine, full efi setup ecu etc. will swap for 1ggte parts
people100
Rocklea qld
18rgeu engine, full efi setup ecu etc. will swap for 1ggte parts Sun, 16 January 2005 10:43 Go to next message
i have a fully rebuilt 18rgeu engine with 18rc pistons for low comp. new rings, bearings and gaskets. sump is modified with a turbo drain in it. polished timing case,
full efi setup including proper 18rgeu elec dizzy, coil and ignitor, efi thermo housing x 2, plenium, polished inlet manifold,standard injectors and everything else needed.
megasquirt ecu that is currently setup to idle my engine...needs more tuning though to run properly and run boost, can be setup to run spark also,
6 x 7mgte injectors
T04 turbo with external waste gate that was for this engine.
Heaps of spares that can go also including carbs for the engine if your not keen on the efi gear.
Pm me or make an offer here. Im more than willing to swap any of these parts for gen 2 or 3 1ggte parts and thats the new plan atm.
jcmunga
adelaide
Re: 18rgeu engine, full efi setup ecu etc. will swap for 1ggte parts Sun, 16 January 2005 11:51 Go to previous messageGo to next message
how much would you want for the 7m injectors??
muli
Re: 18rgeu engine, full efi setup ecu etc. will swap for 1ggte parts Wed, 19 January 2005 08:50 Go to previous message
So its a complete engine minus gearbox, so i wont need anything additional to get the engine running, is it in a car at the moment? Im very interested,
this would be sweet for my hilux
[Updated on: Wed, 19 January 2005 08:52]
Previous Topic:Stock aus spec sprinter diff center and axles
Next Topic:32/36 webber carby
Current Time: Sat Oct 17 23:54:57 UTC 2026
Total time taken to generate the page: 0.0076630115509033 seconds
