Classifieds » Parts Wanted » 1ggte gen 2 or 3 bits...what do u have..
people100
Rocklea qld
1ggte gen 2 or 3 bits...what do u have.. Sun, 16 January 2005 10:49 Go to next message
chasing anything needed for this conversion engine, loom ecu etc etc. name some prices. Im willing to also swap any of these parts http://forums.toymods.org.au/index.php?t=msg&t h=56684&start=0&rid=2197&S=83fb6c021e8 4b98a00f611272dfe4a77 for them.
matt_84
Ipswich
Re: 1ggte gen 2 or 3 bits...what do u have.. Sun, 16 January 2005 13:34 Go to previous messageGo to next message
Hey Ben, you're probably chasing full engines, but i've got some bits and pieces here.
Head
Block
Gen 1 complete inlet manifold
Gen 3 Exhaust manifold
Gen 3 turbos (bit 'o shaft play)
Gen 3 injectors
Box 'o pipes and bits
What kind of cash adjustment are you putting on the T04 assuming you're interested in these bits. Ditto for the megaquirt?
Cheers, Matt
people100
Rocklea qld
Re: 1ggte gen 2 or 3 bits...what do u have.. Mon, 17 January 2005 07:36 Go to previous messageGo to next message
at this stage for me to drop my project id be chasind a complete engine package...how is your going anyway...id like to come see it some time soon.
matt_84
Ipswich
Re: 1ggte gen 2 or 3 bits...what do u have.. Mon, 17 January 2005 09:06 Go to previous message
Not too bad, making progess anyway. Engine has has the seals changed, and a new timing belt. W58 is on the engine. She's ready to go.
Ended up getting a Chaser radiator. Fits nicely (read; tight), but bonnet clearance is fine, just need to cut some of the old radiator support panel out (like in Tina's RA28 in the gallery) but will probably be mounting the battery in the boot.
Intercooler is coming, a standard ga70 item with piping for a ta23 (should be the same-ish as an RA28) courtesy of siktoy.
Waiting on a friend to finish copying Charles' engine mounts (couldn't be stuffed trying to find the front mounted ones), then cutting the mounts off the crossmember, and then rewelding this week hopefully.
Then its just hoses, wiring, piping and other little bits i'm sure to have forgotten.
With any luck, i'll have it started in a month...
Previous Topic:Clutch fork R154
Next Topic:ST165 Fuel Rail + injectors
Current Time: Sat Oct 24 17:08:38 UTC 2026
Total time taken to generate the page: 0.008965015411377 seconds
