Toymods » Tech & Conversions » Turbosmart boost controller V's EBC
japspec
Turbosmart boost controller V's EBC Mon, 27 May 2002 11:14 Go to next message
Hey yall. I know there is a post up asking about pro's and con's of manual & EB controllers. I just wanted to know if anyone had encountered the boost spike problems people talk about when using the cheap $100 manual boost controller that you just set and leave. If so how much of a problem do they cause using about 15 pound. How much better is an EBC?
After boosting staight up to 13 psi using a maual valve I have noticed the boost " die off" a couple of pounds . I was told this was normal and that porting can fix this. Will this "die off" be eliminated by using an EBC.
Whats the going rate for a decent EBC
Cheers guys
Dylo
Re: Turbosmart boost controller V's EBC Mon, 27 May 2002 12:36 Go to previous messageGo to next message
Can you explain this "boost die off", im gonna get one of these valves too when my car is on the road, so any info now would be good!
Re: Turbosmart boost controller V's EBC Mon, 27 May 2002 12:37 Go to previous messageGo to next message
Yes that is a common problem with the manual bleed valves!
For a decent "Electronic Boost Controller" that will eliminate this problem your looking at least $800!
There was an article in Hot4's about Boost Controllers that I think JapMotorsport sport tested! Cant remember what issue though! If i looked i could probably find it.
TOY77
Re: Turbosmart boost controller V's EBC Tue, 28 May 2002 07:01 Go to previous message
G'day,
i have a manual boost bleed on my 1ggte.
I have none of the problems you are talking bout. my boost hits 14psi then sits there.
By the way the article on boost controllers was also in last months zoom.
Stew
Previous Topic:xA6x Celica/Supra tailgate rust
Next Topic:Valve shim resizing
Current Time: Fri Nov 20 13:51:01 UTC 2026
Total time taken to generate the page: 0.0055689811706543 seconds
