Toymods » Tech & Conversions » GZE spark plugs?!
NERD
GZE spark plugs?! Sun, 16 January 2005 20:58 Go to next message
Hi all,
I am looking to change my plugs on my GZE.
Im looking to go copper, and from the search, i could only find this spark plug model number to use: NGK BCPR6EY
Is that the right one?
If not, which is reco. for the GZE?
Is it better off going copper than platinum?
(more frequent changing than spending more money on platinum one?)
feral4mr2
Bundaberg, Qld.
Re: GZE spark plugs?! Sun, 16 January 2005 21:21 Go to previous messageGo to next message
NERD wrote on Mon, 17 January 2005 06:58
they are what i used on the 4agze and now in the 4agte, gapped at .8mm
4ageeza
Adelaide, drift capital
Re: GZE spark plugs?! Mon, 17 January 2005 01:13 Go to previous messageGo to next message
I use those plugs on my 4AGE gapped at 1.1mm or something.
NERD
Re: GZE spark plugs?! Mon, 17 January 2005 02:18 Go to previous messageGo to next message
Thanks for the replies..
How often should platinum plugs be changed?
mikey93
Re: GZE spark plugs?! Mon, 17 January 2005 07:53 Go to previous messageGo to next message
NGK BCPR6EY
im using 101GZE 1.1m gap is fine no real need to regap it
cheap and easy $15 a set of 4 vs $30-70 for plats/iridiums
Spanktown
Inside a giant turbo (syd...
Re: GZE spark plugs?! Mon, 17 January 2005 07:57 Go to previous messageGo to next message
i also run those ngks, gapped at .8mm, only because im going to be running around 18-20psi on the motor.
mikey93
Re: GZE spark plugs?! Mon, 17 January 2005 08:00 Go to previous messageGo to next message
so i asume its smaller gap so its less prone to pre-ignition?
im running 11.5psi boost (max i get anyway) on 1.1mm plugs as above runs fine. i had .8mm gapping and it would cut out at 5500RPM/6000RPM like a hard redline
TE72_Turbo
Re: GZE spark plugs?! Mon, 17 January 2005 12:25 Go to previous message
Its actually got more to do with difficulty igniting the fuel/air mixture with the soaring combustion pressures at high boost.. It shows up as an ignition miss with the bigger (1.1mm) gaps, and can be quite harsh like a rev limiter. Running the smaller gaps (0.7-0.8mm) makes it easier for the spark to jump the gap, but can slightly affect lower rpm & low boost power.
The only way that you will get around having to run small gaps at high boost is to upgrade your ignition system, like a CDI unit etc.
Previous Topic:Best front pads for MA70 Supra?
Next Topic:MX83 idle problem
Current Time: Fri Nov 20 20:17:19 UTC 2026
Total time taken to generate the page: 0.0059809684753418 seconds
