Toymods » Tech & Conversions » 2tg hyrid - 4y crank, 2150cc?
styler
2tg hyrid - 4y crank, 2150cc? Sun, 16 January 2005 23:45 Go to next message
i heard that this can be done, i read hybrids shouldnt
be more than 2000cc for balance also. well has anyone
done it, is it hard to do? i assume the 4y rods are used
and what pistons are used? any advice?
i am referring to the later model block, same as 3tg. that
is where i heard about doing the conversion, on a 3tg.
seeing since a hybrid 2tg has the bottom end of a 3tg i
assume it can be done.
and then if it is bored out after being stroked from 1.8
to 2150, could it be bored to 2300 or so?
[Updated on: Sun, 16 January 2005 23:50]
fade-e
Re: 2tg hyrid - 4y crank, 2150cc? Mon, 17 January 2005 01:42 Go to previous messageGo to next message
if memory serves me right the 2T can be bored out to a 2L or even 2.2L but you are not leaving any room between the cylinder and the water jackets
thats the main thing that needs to be considered!!! you dont want only a couple mm between them otherwise the head gasket will continually blow... even using a metal head gasket wouldnt be that much different as there is very little room to seal
as for crank you could still use the 2T/3T crank but would require pistons to the size of the over bore
styler
Re: 2tg hyrid - 4y crank, 2150cc? Mon, 17 January 2005 02:24 Go to previous messageGo to next message
ah thanx for that info, i didnt know it would such
a major factor in it. so say a 4y crank with a mild bore
job would give a capacity of 2150 + 150 = 2300cc, how
does that sound?
i have a hybrid at the moment and its basically a 2000cc,
it has 3t crank and oversize pistons, no probs with head
gasket so i assume the overbore of about 200cc was fine.
what parts and mods do i need to do to use a 4y crank?
is it recommended, anyone have one?
jesseT18
Castle Hill, Sydney
Re: 2tg hyrid - 4y crank, 2150cc? Mon, 17 January 2005 07:49 Go to previous messageGo to next message
i cant imagine you being able to increase the stroke by much more at all?
the pistons are close enough to hitting the valves as it is!
you definately wouldnt be able to stroke it out any further without custom made forged pistons! $$$$$$$$$$
Joshstix
Toymods Vice President
Re: 2tg hyrid - 4y crank, 2150cc? Mon, 17 January 2005 08:00 Go to previous messageGo to next message
fade-e wrote on Mon, 17 January 2005 12:42
I think if you bore the 3T block for big enough pistons to make it a 2.2 on the standard stroke, head gasket sealing would be the least of your problems. The bores would be right through to the water jackets.
The "Internet wisdom" on how much a 3T block can be bored out is 89mm, the more informed tend to keep it down to a maximum of 88.5 due to too thin a bore wall.
The guys at Toysports talk about using the 4Y crank to stroke the T series out to 2150cc. http://www.toysport.com/Technical%20Information/2t g_18rg_3tg_tech_notes.htm
Yes obviously you are going to have to reduce the compression height either through the use of customer pistons with a higher pin location or shorter con-rods. I really wouldn't like to contemplate the latter though.
styler
Re: 2tg hyrid - 4y crank, 2150cc? Mon, 17 January 2005 10:27 Go to previous messageGo to next message
ah yes... compression. maybe custom made metal gasket would work to lower compresssion but is not the best and probably prone to blowing out and expensive i assume.
the 4y crank fits with some modification but they dont say
what has to be done. probably not a great deal. iv read most
of that site, its awesome!
yes and a 3t crank has a tight enough clearance as it is
lol, so a 4y would have to have pins higher up or shorter conrods$$$, i wonnder what the 4y pistons are like hmmm
or if any pistons would work.
it seems the 4y crank stroke the 1.8L 3t and the later model
1.6L 2tg to 2150cc?? with no boring out is this correct?
so 4y of 2150cc and overbore to 88.5 = 2300cc?
well its recommended not to make the 2tg more than 2L
capacity for strength, balance and smooth operation so
maybe ill stick with my 2L hyrid then.
towe_001
Somewhere on a dirt bowl ...
Re: 2tg hyrid - 4y crank, 2150cc? Mon, 17 January 2005 16:57 Go to previous messageGo to next message
Yeah they also say that how the conrod connects to the crank isn't all that good either for the mod. But i sent them an email a couple of year back asking them about what needs doing to fit the crank and from memory its the front of the crank that needs to be machined down in size.
But yeah its got me interested in it still especially the line "No officer its only a 1.6" Very Happy
Joshstix
Re: 2tg hyrid - 4y crank, 2150cc? Mon, 17 January 2005 23:49 Go to previous messageGo to next message
styler wrote on Mon, 17 January 2005 21:27
I believe the 2150 quoted was with 89mm pistons. I can't say I'd expect a very long life with the kind of side loads on the bores that suc a long stroke crank would have, especially when the bores would be paper thin already.
towe_001
Re: 2tg hyrid - 4y crank, 2150cc? Tue, 18 January 2005 18:06 Go to previous messageGo to next message
By using the 4y crank or even the 3y crank will bring the capacity out to 1952cc. Thats with standard 85mm pistons.
Using 88.5mm pistons (18r) brings the capacity to 2116cc
89mm pistons = 2188cc
91mm pistons (4y) = 2237cc Which pretty well much what the 4y is.
styler
Re: 2tg hyrid - 4y crank, 2150cc? Wed, 19 January 2005 14:08 Go to previous messageGo to next message
thanx too all for all the info, much appreciated
i think ill rebuild the 2L 2tg hyrid cheers
Toycrash
Finland
Re: 2tg hyrid - 4y crank, 2150cc? Thu, 20 January 2005 07:42 Go to previous messageGo to next message
How about using 4Y bottom and 2T or 2T-G head Wink 2300cc "5T"-engine Cool
It CAN be done...
Look at Krn's place:
http://personal.inet.fi/cool/loser/weird.html
Rispect Razz
styler
Re: 2tg hyrid - 4y crank, 2150cc? Thu, 20 January 2005 09:45 Go to previous message
Shocked wow
Previous Topic:gearbox turns into tank mode
Next Topic:Wiring up a turbo timer
Current Time: Wed Oct 21 02:57:36 UTC 2026
Total time taken to generate the page: 0.005640983581543 seconds
