Toymods » Tech & Conversions » 2tg hybrid
Big-Al
2tg hybrid Mon, 17 January 2005 03:18 Go to next message
Does anyone know if 2tg valves hit the pistons if it breaks a cam chain?
I have a hybrid and i have to check that pistons don't hit valves.
Iwant to put head on,no gasket and turn over engine to check clearances.
Is this possible or do i have to put all timming chains and cam gear on.[don't have old head gasket]like a mitsi if you have the cam belt off the valves hit the pistons, cam belt on and they miss the pistons.
Thanks,
Alan.
Evil_Foetus
Ballarat, Victoria
Re: 2tg hybrid Mon, 17 January 2005 05:32 Go to previous messageGo to next message
talk to 'the untouchable'
he had a 2t/3t hybrid that dropped a valve 2 blocks after getting it finished, he should be able to help you Smile
styler
Re: 2tg hybrid Mon, 17 January 2005 05:50 Go to previous messageGo to next message
ie - is it a non interference head... as opposed to an
interferring one i suppose.
id like to know too. i know most hybrids need flycut
pistons so it would seem logical they do interfere.
also if you modify cams etc could it start to interfere
if it was a non interferring head originally?
[Updated on: Mon, 17 January 2005 05:52]
jesseT18
Castle Hill, Sydney
Re: 2tg hybrid Mon, 17 January 2005 07:40 Go to previous messageGo to next message
yeah its ineterference alright. valves will hit, not 100% sure about the stock 2tg, but 3tg sure is
setsuna
Re: 2tg hybrid Sat, 19 February 2005 16:59 Go to previous messageGo to next message
if chain breaks... cam stops turning.. valves stop moving out of the way of pistons.. lol
whats this about def ahving clearance problems on hybrids?
Im about to drop a 2T-GE head on my 3T-GTE.
thought it was pretty much a direct bolt on?
T APLUS 22
Re: 2tg hybrid Sun, 20 February 2005 02:49 Go to previous messageGo to next message
setsuna wrote on Sun, 20 February 2005 03:59
And what if the cams are interfering with the pistons when the chain breaks?
Re: 2tg hybrid Sun, 20 February 2005 03:00 Go to previous messageGo to next message
Most chain-driven Toyota engines are interference, including the 2T-G. Most belt-driven engines are non-interference.
TRD-75
Re: 2tg hybrid Sun, 20 February 2005 23:22 Go to previous messageGo to next message
i built a 2tg hybrid. when it was on the engine stand i had it all together and turned it over. got hard to turn, pulled head off and found bent inlet valve on no.1 cylinder.
YelloRolla
On your mum!
Re: 2tg hybrid Mon, 21 February 2005 13:40 Go to previous message
Should be o.k - any engine builder worth his wait in salt will check the clearances.
Also note - that the way that you are going (2T head on 3T GTE) is fine - but check it anyway. The problems come for the guys fitting 3T cranks into 2T using the stock 2T NA pistons.
Previous Topic:Supercharger Query
Next Topic:6 speed 20v lsd gbox into ae82
Current Time: Mon Nov 2 06:05:14 UTC 2026
Total time taken to generate the page: 0.050727128982544 seconds
