Toymods » Tech & Conversions » 18rg trouble HELP! :(
twincamcelica
Ormeau, Brisbane
January 2005
18rg trouble HELP! :( Mon, 17 January 2005 04:53 Go to next message
UM well da problem is it just wont run right... Sad an i dont no what 2 do, cruisin along shes fine then soon as ya get to a slight incline or a hill it just lacks all nuts..... Rolling Eyes
its an 18rg with duel carbies in my ra40 ive had trouble with it already when it needed another set of carbs coz the little venturies were flotin round inside em.. Mad but found more nows fixed.... Very Happy well got it for $500 motor an gearbox an exhaust
i spose u get what u pay for hey Sad but it just doesnt have the power i think its spose to have Confused Confused Confused
so if anyone has any tips on what i can do to spruse it up a bit would be great Rolling Eyes Cool
munki
Gold Coast
Re: 18rg trouble HELP! :( Mon, 17 January 2005 06:53 Go to previous messageGo to next message
what exactly are you asking?
soaringmik
Re: 18rg trouble HELP! :( Mon, 17 January 2005 06:57 Go to previous messageGo to next message
Eye Spin Eye Spin Eye Spin
styler
Re: 18rg trouble HELP! :( Mon, 17 January 2005 07:24 Go to previous messageGo to next message
yeah ummm....
are you asking why it doesnt go hard up hills because
it should go harder up hills normally
or
are you asking why the engine practically dies when it
goes up hills and its fine on the straights
soaringmik
Re: 18rg trouble HELP! :( Mon, 17 January 2005 07:27 Go to previous messageGo to next message
twincamcelica wrote on Mon, 17 January 2005 15:53
Seriously,..
What power do you spose it should have??.
tilio_enduro
Re: 18rg trouble HELP! :( Mon, 17 January 2005 09:16 Go to previous messageGo to next message
Well a friend of mine bought a second hand engine for $500 and it had no power, no oil pressure at idle and didn't go hard cause............
The crank was wobblin and bearings were munched,
the cylinders were scored and pistons were for the wrong bore;
with his purchase he was out of luck, cause the whole engine was fucked!!!
Try a compression test to see if the car lacks compression - anything below 140 psi per cylinder could be your cause - if its dipping below 120psi thats probably your problem.
Is there bearing noise???
Is there smoke on start up, or under hard acceleration??
These things will tell you if the engine internals are OK.
The compression test is probably most important; is yours the 88230 or 88250 or 88270 - the 88270 has lowest compression and readings of 130 psi are OK
Hope its something simple.
Smile
brett_celicacoupe
townsville NQLD
Re: 18rg trouble HELP! :( Mon, 17 January 2005 09:26 Go to previous messageGo to next message
take it to a mechanic Rolling Eyes
brett
twincamcelica
Ormeau, Brisbane
January 2005
Re: 18rg trouble HELP! :( Tue, 18 January 2005 03:30 Go to previous messageGo to next message
Shocked Shocked Hmm ok well i have some cheakin out to do i think
Embarassed Thanks for the tips tilio, it probly is worn motor
but im not sure what no. it is, were do you find that out...??? Confused Shocked Very Happy
lilcrash
ipswich queensland
Re: 18rg trouble HELP! :( Tue, 18 January 2005 08:48 Go to previous messageGo to next message
does the engine die or does it just not move up hills??? if it just doesnt move it could be the same as mine. ur clutch is f**ked. (we took ours past the rivets wen we went grasin Very Happy)
oh and mine has 144hp thus the clutch went easily(i was in 4th goin up a hill the engine ova powered the clutch and went bye bye)
good luck with it
lilcrash
ipswich queensland
Re: 18rg trouble HELP! :( Tue, 18 January 2005 08:49 Go to previous message
good luck with it
Previous Topic:TA23 5 Stud front brake upgrade
Next Topic:Injectors permanently switched on
Current Time: Wed Nov 18 15:44:15 UTC 2026
Total time taken to generate the page: 0.0064010620117188 seconds
