Toymods » Tech & Conversions » My T50 sucks!
loki boyracer
Carlingford NSW
My T50 sucks! Mon, 17 January 2005 07:42 Go to next message
My T50 out of my 86 wont hold in second (read: pops out of under load). I have pulled down the gearbox but all the the synchro's look fine and the bearing play is minimal. I have been told many things from "need a new input shaft" to complete "new bearings" and "gear sets". So what the hell should I do (cos I dont have $500 to spend on a bearing set and $270 on synchro rings and still find out its still not it)
Keven
jesseT18
Castle Hill, Sydney
Re: My T50 sucks! Mon, 17 January 2005 07:44 Go to previous messageGo to next message
buy another T50?
ive seen em going for $100-$200 on here, claimed to be working fine
Re: My T50 sucks! Mon, 17 January 2005 07:50 Go to previous message
loki boyracer wrote on Mon, 17 January 2005 17:42
lay shaft bearings are stuffed - under load the gears won't mesh properly so it pushes itself out of gear (which is better than snapping and chewing the teeth of the gears).
if it's been like this for a while, it's likely that the teeth on the layshaft and possibly the main shaft are also flogged slightly. Synchro's should be alright unless they grind.
does is also pop out 1st during heavy take off, or when slowly crawling down a steep slope in 1st (e.g. no accel, engine braking) - this is also a sign of layshaft no longer aligning correctly with main shaft when under load.
cheaper to buy another box ... if you feel bored and in need of wasting more money, rebuild the 1st box.
Previous Topic:custom high rpm crank pulley??
Next Topic:3 wire turbo timer installation
Current Time: Fri Nov 20 21:04:46 UTC 2026
Total time taken to generate the page: 0.004918098449707 seconds
