Classifieds » Parts Wanted » Wanted Working SX Oil sender
Matt20v
Richmond NSW
Wanted Working SX Oil sender Mon, 17 January 2005 07:53 Go to next message
Hey i need a Working Oil Pressure sender for my SX dash to work ???? have already brought a brand new one but it dosnt seem to work and have checked out all the wireing and the gauge and that seems to be fine so need a new one that i no has worked before thanks matt.
Scorpion
Menai area of Sydney
Re: Wanted Working SX Oil sender Mon, 17 January 2005 12:07 Go to previous messageGo to next message
Check the resistance of the pressure gauge with a multimeter. If it's infinite (no reading) then the gauge may need to be rewired. Also check that you have 12v in the wire to the sender when the ignition is on. Also check that there is no resistance between the body of the sender and the block - i.e. you're not using plumbing tape or similar around the thread of the sender to seal it. (this insulates the sender from the block and it needs to be earthed).
Matt20v
Richmond NSW
Re: Wanted Working SX Oil sender Tue, 18 January 2005 02:26 Go to previous message
I will.. but the thing is if you stay at steady revs the oil will rise to like 1/4 of the gauge so this means it is getting a signal but i thought may be the sender has been dented and it cant send out the right reading
Previous Topic:WTB, 71-72 TA22 Celica taillights. "Flat lense type"
Next Topic:AE86 handbrake cable
Current Time: Tue Oct 27 00:45:54 UTC 2026
Total time taken to generate the page: 0.093760967254639 seconds
