Toymods » Tech & Conversions » 7M head bolt retorque?
capableronTRD
7M head bolt retorque? Mon, 17 January 2005 08:23 Go to next message
Well i've just finished a head gasket job on a 7M-GE, Very Happy
Aint she pretty? Laughing
http://img.photobucket.com/albums/v606/Asmodai/finished.jpg
I've torqued the bolts down to 72 ft/lbs (as this is the number i kept hearing from everyone).
Anyway, i'm wondering what is the go with retorquing the head?
I know its a good idea to wait till 1000-1500kms or so,
Some say to back off each bolt and retighten one by one, others say not to back it off as you introduce oil, water, whatever sorts of stuff into the thread that can mess up the torque readings (??).
What is the proper technique?
ed_ma61
Lost in the K hole
Re: 7M head bolt retorque? Mon, 17 January 2005 10:21 Go to previous messageGo to next message
must undo them and retorque one by one in order as indicated in the manual
highly highly unlikely to introduced shit into the thread as the h/g should still be sealing the galleries
bbaacchhyy
Re: 7M head bolt retorque? Mon, 17 January 2005 10:34 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 17 January 2005 20:51
Then theoritically Ed, can you do the same by taking out the old headbolts and installing ARP ones in the same manner ?
If so, consider the job done !!!!
I would guess to torque in stages like 50 - 70 and then 90 (or whatever the ARP instructions say ?
ed_ma61
Lost in the K hole
Re: 7M head bolt retorque? Mon, 17 January 2005 10:58 Go to previous messageGo to next message
bbaacchhyy wrote on Mon, 17 January 2005 21:34
id be happy enough to do that Smile
make sure you follow the pattern correctly though
but dont just guess, as above, follow the instrustions exactly. each bolt also needs to go through a torque, re-torque cycle for preliminary stretch before final tensioning.
ed
7MSupra
Perth W.A.
Re: 7M head bolt retorque? Mon, 17 January 2005 12:15 Go to previous messageGo to next message
So is 72 ft/lbs the correct torque for the 7m-gte also?
ed_ma61
Lost in the K hole
Re: 7M head bolt retorque? Mon, 17 January 2005 12:37 Go to previous messageGo to next message
72ft/lbs is the maximum sustainable torque capable by the stock 7m head bolts (as measured by some yank doing a stress strain analysis ages ago)...
its commonly regarded as what you should retorque them to
ARP or other fasteners have thier own specs to follow when installing
V8_MA61
Re: 7M head bolt retorque? Mon, 17 January 2005 13:01 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 17 January 2005 22:37
i did mine at 73 and they were fine!!
i didnt *undo* mine when i re-torqued it..i just tightened them up...to discover they had lost fuck all of their tightness
dingaling
tas
Re: 7M head bolt retorque? Mon, 17 January 2005 15:28 Go to previous messageGo to next message
First time i torqued the headbolts i whent to 68ft pounds. Good thing i did as i found a couple headbolts on intake side were loose. The headgasket was just done at toyota from the previous owner ($2500!!)
A year later i did a retorque and found none of the bolts had lost any tightness from the original 68ft pounds.
capableronTRD
Re: 7M head bolt retorque? Mon, 17 January 2005 21:03 Go to previous message
I believe you are referring to this article:
http://www.supramania.com/phpBB2/viewtopic.php?t=1 0219&highlight=genuine+head+gasket
Previous Topic:R32 GTR Brake conversion for AE86
Next Topic:anyone with a 1ggte manual??
Current Time: Fri Nov 20 12:57:46 UTC 2026
Total time taken to generate the page: 0.0052218437194824 seconds
