Toymods » Tech & Conversions » corona idling problem
driftae86
perth
corona idling problem Mon, 17 January 2005 09:12 Go to next message
hey guys,
my mate has an '84 toyota corona and it has idling problems.
one day it started idling really high, too high, probly like 2,000 rpm.
its a carby engine and it is constantly idling this high.
does anyone know why this is happening?
any ideas?
people100
Rocklea qld
Re: corona idling problem Mon, 17 January 2005 09:39 Go to previous messageGo to next message
i had this problem once...it was after i nailed it quickly it acculatly bent s a linkage on the carby which kept it partly accelrated so there fore idling high
Kyosho
Wollongong
Re: corona idling problem Mon, 17 January 2005 09:55 Go to previous messageGo to next message
Could be a linkage as mentioned...
Or the idle needle has moved either through vibration, or someone f'ucking with it...
toyotacorona
melb
Re: corona idling problem Mon, 17 January 2005 10:49 Go to previous messageGo to next message
i've had the same problem check if any of the anti-pollution lines have disconnected any way thats my 2 cents
cya sam
Maurice c
Re: corona idling problem Tue, 18 January 2005 01:52 Go to previous messageGo to next message
It could be a vacumn leak somewhere, from one of the lines or the intake manifold gasket. Is it an intermittent rise in tickover or is it steady? If its steady it could be as simple as adjusting the tickover screw. Some peope like to raise the tickover or tune up the radio to cover an idleing problem. Last Summer, my girlfriends dad made it home in record time when a washer jammed the carby in his Camira. He was a bit white in the face when he came in though.
driftae86
perth
Re: corona idling problem Sun, 30 January 2005 13:46 Go to previous message
ok it has been sorted out now.
turned out that the accelerator cable was sticking, holding it open slightly, giving it higher revs.
cheers anyway guys Smile
Previous Topic:Changing of fuel lines
Next Topic:1g HKS single turbo manifold
Current Time: Wed Oct 28 17:36:35 UTC 2026
Total time taken to generate the page: 0.063459873199463 seconds
