Toymods » Tech & Conversions » Injectors permanently switched on
Injectors permanently switched on Mon, 17 January 2005 23:36 Go to next message
Ok, I have finished the Crown. I had this thing running months ago but had a vast range of things that needed doing.
The other day I plug in the ECUs. Crank her over and petrol comes out of the exhaust manifolds. That's bad on the Dave good <--> bad continuum. After eliminating the CSI as the source, I became a little more worried. I put a test light across the injector plugs which revealed that all injectors are permanently switched on (hence the flooding).
What might be doing this?
The ECU has never received a reverse polarity. ECUs are sitting on carpet. All grounds are connected.
Re: Injectors permanently switched on Tue, 18 January 2005 00:10 Go to previous messageGo to next message
The injectors have constant 12v and are ground switched, so your test-light does not necessarily reveal the injectors are permanently on.
Having said that, petrol coming out of the exhaust is never a good thing. So you're certain you have spark? And it's not firing at all?
Re: Injectors permanently switched on Tue, 18 January 2005 00:19 Go to previous messageGo to next message
I put a multimeter across the INJ power wire and ground to reveal a short. Also did the same to the switched INJ wires from the ECU to reveal a short. Disconnected the engine ECU to reveal short was still present! When I umplugged the ECT ECU, short disappeared. A bit of further tracing has discovered a cretin (moi) had a strange wiring malfunction whilst doing the ECT wiring. Embarassed
Will rectify wiring a little later today.
[Updated on: Tue, 18 January 2005 00:21]
Re: Injectors permanently switched on Tue, 18 January 2005 00:36 Go to previous messageGo to next message
good luck Smile
if a cylinder locks due to being filled with petrol, don't be tempted to crank it with the spark plug out... as one MSer found out it leads to "Very Bad Consequences", such as 5ft fireballs by the side of the road and a visit by the local fire brigade Wink
Re: Injectors permanently switched on Tue, 18 January 2005 01:46 Go to previous messageGo to next message
"very bad consequences" I love that Smile
would this "certain MSer" be you?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Injectors permanently switched on Tue, 18 January 2005 02:54 Go to previous messageGo to next message
PICSORBAN!!
Re: Injectors permanently switched on Tue, 18 January 2005 03:27 Go to previous messageGo to next message
Well, my brilliance continues to amaze me. Rolling Eyes
So I checked the wiring. As it turns out the ECT ECU has 2 plugs 26P and 16P, whilst the engine ECU has 4 plugs (8P, 22P, 26P and 16P). As it turned out, I hooked up the 26 and 16P ECT plugs to the engine ECU and vice versa. Interestingly the plugs have exactly same slots so they will just plug into the wrong place (ie not Dave proof). I suppose in a Crown they are separated by a foot of loom and a shitload of plastic.
After expunging all the petrol from petrol locked motor, shooting a bit of oil into the bores, swapping ECU plugs and waiting till all the petrol fumes had dissipated, the stupid thing fired first crank.
Re: Injectors permanently switched on Tue, 18 January 2005 03:30 Go to previous messageGo to next message
LOL
joo = teh suck.
Nark
Cabramatta, NSW
Re: Injectors permanently switched on Tue, 18 January 2005 03:35 Go to previous messageGo to next message
gianttomato wrote on Tue, 18 January 2005 14:27
I must say, that's pretty impressive! Laughing
At least you didn't kill the engine (like my effort with the sump pickup bolts).
Re: Injectors permanently switched on Tue, 18 January 2005 04:00 Go to previous messageGo to next message
I take it the plugs are not different COLOURS?
Am I also correct in assuming that things are now labels?
Is this a UZS-131 wiring harness?
If so, I will have to remember this, as I will be attempting the same thing soon.
EDITED Embarassed
[Updated on: Tue, 18 January 2005 04:03]
Re: Injectors permanently switched on Tue, 18 January 2005 04:37 Go to previous messageGo to next message
draven wrote on Tue, 18 January 2005 12:46
LOL, no Razz i think it was a guy called Wing (he named the Wing Diode int he MS tach trigger circuit Wink )... so he had "gas" shooting "feet", ie US Razz
woohoo!! nice one GT Very Happy
gotta love happy (and non-fiery) endings Smile
Re: Injectors permanently switched on Tue, 18 January 2005 06:45 Go to previous messageGo to next message
Plugs are labelled and color coded now, and it's a UZS131 loom. So pleased I didn't blow the ECUs.
Re: Injectors permanently switched on Tue, 18 January 2005 06:47 Go to previous messageGo to next message
gianttomato wrote on Tue, 18 January 2005 14:45
Cool, I know who I'm calling when I get stuck.
Re: Injectors permanently switched on Tue, 18 January 2005 07:56 Go to previous messageGo to next message
If you use Kdog's diagrams on Lextreme, you will piss it in.
If you plan on keeping the auto, read that thread with Grant's explanation. I will let you know tomorrow if the 5MGE single pulse doover works as a short cut. I suspect it will still need a 4 pulse per revolution doover to get the right shift patterns. Also beware that the Kdog diagrams for the ECT are almost perfect except for what he calls SS, SS1 and SS2 speed sensors - they are in fact steering sensors and can be turfed. Using Cambelt's intact halfcut and a multimeter, we deduced that the purple/white wire sees 1 pulse per revolution, whilst the black/orange probably sees 4 (I'll be testing that next week).
I can also offer you some other stuff where I traced out (almost) all the wires in the loom which end up in the fuse box.
Re: Injectors permanently switched on Tue, 18 January 2005 08:04 Go to previous message
Yeah, I've been keeping an eye on that thread, and its locked away for safe keeping.
Will PM you.
Previous Topic:18rg trouble HELP! :(
Next Topic:Help with my KE55
Current Time: Wed Nov 18 14:50:53 UTC 2026
Total time taken to generate the page: 0.0061910152435303 seconds
