Toymods » Tech & Conversions » 1JZ-GTE R154 Diff Ratio
rogue-vl
Casino
1JZ-GTE R154 Diff Ratio Tue, 18 January 2005 10:00 Go to next message
Hi Guys,
I am in the process of putting a 1JZ and R154 into my VL Commodore, as I am having the diff reco'd to turbo spec I have the option of picking the diff ratio.
what would be best for a daily driver that see a fair bit of highway driving?
Std VL diff 3.45:1
I belive the standard 1jz Soarer manual is 4.11:1 ??
Can anyone help me out?
Manny
Re: 1JZ-GTE R154 Diff Ratio Tue, 18 January 2005 10:41 Go to previous messageGo to next message
The Soarer 1JZ factory R154 diff ratio is 4.083:1 for a 1600kg car and revs at 2500rpm in 5th for 100km/hr.
Re: 1JZ-GTE R154 Diff Ratio Tue, 18 January 2005 11:19 Go to previous messageGo to next message
I reckon around 3.5:1 would work pretty well. The Soarer has a pretty low ratio but it's also a lot heavier than a VL. If you do a lot of highway driving you'll want reasonably tall gearing.
Re: 1JZ-GTE R154 Diff Ratio Tue, 18 January 2005 13:15 Go to previous messageGo to next message
Well, you could probably pick either the 3.7 or 3.889 bogwarmer diff gears, just remember that especially the 3.889's seem to be pretty prone to being noisy...
dingaling
tas
Re: 1JZ-GTE R154 Diff Ratio Tue, 18 January 2005 13:21 Go to previous messageGo to next message
yes i concur.
4.3:1 LSD with an auto ain't fun on the highway, far out i miss my decent highway fuel economy Sad
whats a VL wiegh? 1200kg or there abouts?
[Updated on: Tue, 18 January 2005 13:22]
Jag7799
Re: 1JZ-GTE R154 Diff Ratio Tue, 18 January 2005 13:26 Go to previous messageGo to next message
ive for a 3.9 lsd, out of an ma61 .. I think its just under 3k at 100 km/h
gets to 96km/h in the top of 2nd
my car weighs aroun 1250kg, so about the same as a vl with a 1jz.. I get around 8.3l/100km
[Updated on: Tue, 18 January 2005 13:28]
Grant
Newcastle, NSW, Australia
Re: 1JZ-GTE R154 Diff Ratio Tue, 18 January 2005 21:14 Go to previous messageGo to next message
I've got a diff ratio program in the Tech Data section of my website. It would probably help you choose your ratio. http://www.sixworks.com.au/html/tech_data.html
[Updated on: Tue, 18 January 2005 21:15]
JustenGT4
Re: 1JZ-GTE R154 Diff Ratio Wed, 19 January 2005 03:15 Go to previous messageGo to next message
The JZA70 diff (same diff) i have in the GT8 is a 3.7:1. It was behind a R154 so should be reasonably well matched ratio wise.
If anything it's a bit too short for the GT4 but it only weighs 1380kg. Plus i have A LOT of torque.
E30-323ti
Re: 1JZ-GTE R154 Diff Ratio Wed, 19 January 2005 05:05 Go to previous messageGo to next message
I had a 3.46 behind my W58 (similar 5th ratio) and it was good, pulled well sat at ~2400rpm @ 100km.
I now have a 3.91 and it is too short, the engine doesn't need to work very hard and doesn't make use of the 1JZ torque, sits at ~2700@100 (but ~3k @ 120, a bit buzzy.)
Mind you a E30 BMW only weighs just over 1100kg wet.
Stenno
Re: 1JZ-GTE R154 Diff Ratio Wed, 19 January 2005 05:25 Go to previous messageGo to next message
JustenGT4 wrote on Wed, 19 January 2005 14:15
JZA70's ran a rear end ratio of 4.100 - there were no other ratios offered by Toyota.
3.73 was behind the MA70-MA71 Turbo 5 Speed.
I'd have to agree with Norbie 3.5 would be right on the money, even 3.2's would work a treat.
[Updated on: Wed, 19 January 2005 05:26]
Jag7799
Re: 1JZ-GTE R154 Diff Ratio Wed, 19 January 2005 05:28 Go to previous messageGo to next message
E30-323ti wrote on Wed, 19 January 2005 16:05
jesus, they are that light?.. thats bloody awesome
rogue-vl
Casino
Re: 1JZ-GTE R154 Diff Ratio Wed, 19 January 2005 10:51 Go to previous messageGo to next message
Thanks grant for that spread sheet.
I made some modifications so that I can show the differences between both doff ratios and the different gear ratio from the MX5 VL 5 speed and the R154.
I've looked at many of everyone suggestion this is what I came up with
3.2:1 100kph @ 2000 rpm
1st @6000 rpm 70 kph
2nd @ 6000rpm 100kph
3.5:1 100kph @2300rpm
1st @6000 rpm 63 kph
2nd @ 6000rpm 105 kph
3.7:1 100kph @2400rpm
1st @6000 rpm 59 kph
2nd @ 6000rpm 99 kph
3.889:1 100kph @2500rpm
1st @6000 rpm 57 kph
2nd @ 6000rpm 94 kph
Purely going of these figure I would lean towards 3.5 or 3.7 ratio. What would be like to drive? would I still get good take off? would the engine make boost at a reasonable speed?
feedback please guys
rogue-vl
Casino
Re: 1JZ-GTE R154 Diff Ratio Sun, 23 January 2005 12:06 Go to previous messageGo to next message
Bump
E30-323ti
Re: 1JZ-GTE R154 Diff Ratio Sun, 23 January 2005 21:50 Go to previous messageGo to next message
I'd go with the 3.5 or 3.7 depending on wheel/tyre size (height I should say).
[Updated on: Sun, 23 January 2005 21:51]
Mofo III
Kelmscott, Perth, W.A
Re: 1JZ-GTE R154 Diff Ratio Tue, 09 August 2005 15:37 Go to previous messageGo to next message
Stenno wrote on Wed, 19 January 2005 13:25
auto jza70's equipped with a torsen recieved a 3.91 ratio. Very Happy
...cant let a thread be burried with false information now can we?
hemi twofifteen turbo
Re: 1JZ-GTE R154 Diff Ratio Tue, 09 August 2005 18:06 Go to previous message
I'd actually stick with the 3.45's, or if it costs no more 3.55. I guess the question is what do you want out of the 'daily driver' part of it. I'm biased towards pulling long torquey gears, (once owning a 360cu/R154/2.78 diff Smile - The available borg warner ratio's would prob be a choice of:
2.77, 2.92, 3.08, 3.23, 3.45, 3.55, 3.7, 3.9, 4.1, 4.3's
Quite literally somewhere in the middle at 3.45/3.55 I would choose. Any variation lower or higher from there will be how biased you are towards performance/economy. Having a first gear that can allow the engine to load enough to produce boost is what I like, but if you want to zip thru gears in traffic maybe 3.9/4.1?
Previous Topic:Left of Field–Turbulence and throttle bodies
Next Topic:Sub Oxygen Sensor Removal?
Current Time: Thu Oct 22 14:03:50 UTC 2026
Total time taken to generate the page: 0.010196924209595 seconds
