Toymods » Tech & Conversions » 1G-GZE Gremlins
ra23celica
1G-GZE Gremlins Tue, 18 January 2005 12:25 Go to next message
Hi all.
The 1G-GZE in my RA23 is giving me grief.
It drives OK, but does not produce any boost, runs rich, and hunts at idle. A test light rigged up to mimic the engine check light flashes continously, meaning the ECU has no codes to throw up.
Can someone please hazard a guess as to what the problem might be ?
Thanks,
Mitch.
jackel
Re: 1G-GZE Gremlins Tue, 18 January 2005 20:46 Go to previous messageGo to next message
just a guess, have you checked the wiring to see if anything has come out or unplugged?
Grant
Newcastle, NSW, Australia
Re: 1G-GZE Gremlins Tue, 18 January 2005 21:11 Go to previous messageGo to next message
Check your idle solenoid valve; it could be stuck open. Easiest way is to tell is to block off the pipe leading to the ISCV and see if that fixes the issue.
Also check that the air flow meter flap is not sticking. That would also account for all the symptoms you describe.
HyDrA
Adelaide, SA
Re: 1G-GZE Gremlins Tue, 18 January 2005 21:53 Go to previous messageGo to next message
I'm also pointing a finger at the idle stepper motor... check that you have power to it, and make sure you've grounded everything you need to ground.
Also check that the supercharger clutch is engaging!
ra23celica
Re: 1G-GZE Gremlins Tue, 18 January 2005 22:23 Go to previous message
Thanks guys, I will check out your suggestions. Much appreciated.
Mitch.
Previous Topic:Air Con Wiring 1G
Next Topic:Is there such thing as 3S-GZE
Current Time: Thu Nov 19 00:25:25 UTC 2026
Total time taken to generate the page: 0.046336889266968 seconds
