Toymods » Tech & Conversions » Air Con Wiring 1G
ra23celica
Air Con Wiring 1G Tue, 18 January 2005 12:32 Go to next message
I have found the A/C idle up wire in the loom of my 1G-GZE but I am at a loss as to where I should connect this to. I know its function but if it does not go to the ECU to up the revs at idle when the A/C comp. is on; does it come from the A/C switch in the console to tell the ECU that the A/C is on and therefore, it must up the revs at idle ?
Thanks,
Mitch.
Grant
Newcastle, NSW, Australia
Re: Air Con Wiring 1G Tue, 18 January 2005 21:17 Go to previous messageGo to next message
Connect it to the switch wire or the A/C compressor wire. The motor will idle higher whenever it gets a 12v feed.
ra23celica
Re: Air Con Wiring 1G Tue, 18 January 2005 22:25 Go to previous message
Thanks Grant, for some reason I did not consider the obvious thing and connect it to the A/C comp switch.
Mitch.
Previous Topic:T18 struts onto ke 30 rolla
Next Topic:1G-GZE Gremlins
Current Time: Thu Nov 19 00:54:30 UTC 2026
Total time taken to generate the page: 0.0055248737335205 seconds
