Toymods » Tech & Conversions » Cruise Control
Flebbert
Wagga
Cruise Control Tue, 18 January 2005 22:34 Go to next message
I have an MA70 with cruise control (doesnt work). I turn the cruise control on with the switch on the right and then try to set it with the stearing controls but it no working.
I was wondering where the control unit for the cruise control is and if anyone has any ideas
malazn
Re: Cruise Control Tue, 18 January 2005 23:09 Go to previous messageGo to next message
switch / button is broken?
a wire is shorting?
not plugged in?
Rolling Eyes
Driftspec
Re: Cruise Control Wed, 19 January 2005 00:07 Go to previous messageGo to next message
Yep take the steering wheel off first thing, just check to make sure the wires are still connected to the buttons etc.
Could also be a fuse?
There is an online Toyota Manual... unsure of the link thought ( i have it at home), someone else here should know it.
Hope this helps.
[Updated on: Wed, 19 January 2005 02:14]
Twiggy
Re: Cruise Control Wed, 19 January 2005 02:09 Go to previous messageGo to next message
The cruise control module is a small box a bit larger than a cigarette packet. Mine is a light green colour and is situated in under the dash just to the left of the steering column. Its not easy to get to - but it can be done without removing the whole dash.
Good luck.
Twiggy
Flebbert
Wagga
Re: Cruise Control Wed, 30 November 2005 06:57 Go to previous messageGo to next message
hey again guys,
i am re visiting this post again as i very much would like to get my cruise control fixed, i have pulled the module out and it doesnt look to be burnt out, replaced all the fuses in the car unless there is one hiding, have tested to see if there is any current at the actuator but there is none,
Any ideas guys would be great, also what and how to test certain things
rgards, Phil
Flebbert
Wagga
Re: Cruise Control Wed, 30 November 2005 08:15 Go to previous messageGo to next message
hey edit after what i found out in last hour or so,
Switch wasnt working but now when i chech the resistance across the switch it changes when i press any of the three buttons
When cruise control is on there is no power what so ever getting the to actuator and other various things in the engine bay when it is turned on.
Oh the little light comes on when i press the cruise button!!!
.....Have to start somewhere.
To be honest this is a little out of my league but how am i ment to learn if i dont try.
As far as i am aware the buttom tells the cruise module to turn cruise on which controls the actuator which inturn controls the acceleration. Dont know how right i am, as i said i am open for anything.
regards again
[Updated on: Wed, 30 November 2005 08:15]
Re: Cruise Control Wed, 30 November 2005 09:42 Go to previous messageGo to next message
here would be some useful reading:
TSRM for MA70 (US version, but basically the same car)
<http://www.cygnusx1.net/supra/library/TSRM/index.h tml>
cruise control system starts here:
<http://www.cygnusx1.net/supra/library/TSRM/be/BE_0 58.html>
but description of system starts here:
<http://www.cygnusx1.net/supra/library/TSRM/be/BE_0 61.html>
the resistance might change across the switches when you press them, but are they connected to the cruise control box? and does the earth that they switch to actually earth?
the lack of voltage to the actuator suggests that the cruise control does not want to set a speed for the engine. The cruise control light turning just indicates that the crontroller is getting power and can power up.
anything could be stopping it from enabling: stop light on, clutch engaged or in auto in neutral, handbrake on, dead speed sensor, transmission ECU not connected correctly.
also, cruise control needs a speed signal (either from the gearbox or from the dash) - have you been working in either of thse places lately?
cheers,
charles.
sideshow
Re: Cruise Control Wed, 30 November 2005 10:14 Go to previous messageGo to next message
if cruise l;ight comes on means the unit is turnin on
have u done a conversion or an auto to manual swap
there is afew things than need to be switched for the actruator to work
its had to test it by just checking for power at the actuator
it works a different way
Flebbert
Wagga
Re: Cruise Control Wed, 30 November 2005 20:40 Go to previous message
Thanks for input guys,
starting to think that it might be a job for a sparkie.
Thanks for those diagrams tho they will be a huge help,
Will post how i go this afternoon,
Phil
Previous Topic:4agze crankcase pressure
Next Topic:ae86 20v wiring mystery :(
Current Time: Fri Nov 20 07:59:15 UTC 2026
Total time taken to generate the page: 0.038219928741455 seconds
