Toymods » Tech & Conversions » Looking for Nitros Kit
v204age
icon7.gif  Looking for Nitros Kit Wed, 19 January 2005 03:22 Go to next message
Does anyone know of a wet Nitros Kit for a 4age 20v. Needs 4 injectors due to quad throttle bodies.
Richard
ke382TG
Re: Looking for Nitros Kit Wed, 19 January 2005 04:37 Go to previous messageGo to next message
I am always surprised at how many cars are actually using this stuff on the street (here in Canberra) and most are dissappointingly slow.
Speaking of illegal street products, I was damn surprised at the number of cars that were out at a local "car hangout" trying to line up races in their cars and they not only had Nos but drag slicks too Rolling Eyes But it was hilarious to see them get rolled by more legal vehicles (street racing is silly).
I don't know how developed your engine is v204age but surely you would want to extract as much legal (Nos is not illegal to have in the car but is illegal to have connected and useable whilst on the street as far as I am aware) power from your car as you can before going down the Nos path (IF you are wanting Nos for off street drags on a highly strung 20v then ignore what I said).
Let us know how you go with it and how much it knock off your 1/4's
[Updated on: Wed, 19 January 2005 04:39]
Fattony
Re: Looking for Nitros Kit Wed, 19 January 2005 04:41 Go to previous messageGo to next message
Ive gathered that NOS make a model spcefic kit for your car though its a Dry manifold setup. So unless you want to have a shared inlet to a filter thats the only way that kit will work. If you do i would recomend you go for this kit if your motor is not turbocharged as it will take out a lot of time hassle and $$$ out of the setup as these kits can be had for the high 800odd dollar mark. Though what your after is a direct port kit. There are other manufactures like Zex and NOX, they really dont have the range of kits that NOS do. There are a few direct port efi nitrous kits that NOS make for your application though some of them would only want to be used for a compition motor. One that stands out is the NOSZLE direct port efi system this is able to be jetted 50-125 hp with the 4 cyl kit and has a 3 part NOSZLE. Basically one part for Nitrous, other for supplement fuel for nitrous and the other part of the NOSzle houses your injector and basically it fits into your original injector hole in your inlet. Kit number is 08004NOS and you can get info at www.nosnitrous.com
Cheers Adam
Fattony
Re: Looking for Nitros Kit Wed, 19 January 2005 04:46 Go to previous messageGo to next message
Dont forget your fuel system also has to be up to spec to be able to fuel the extra fuel required for a xHP shot of N20 and not to mention the fact that your motor needs to be able to withstand the extra hp and driveline components aswell. Though if your building a serious compition engine then you might aswell go all out on the sport compact nitrious system offered by NOS which is 80-225HP adjustable, as you would be upgrading the rest of the components to be able to withstand and a fuel system that can make that hp.
Cheers Adam
ke382TG
Re: Looking for Nitros Kit Wed, 19 January 2005 04:52 Go to previous messageGo to next message
Quote:
Dont forget to paint it blue.
I wouldn't mind the carbon bottles, they look real trick!
ed_ma61
Lost in the K hole
Re: Looking for Nitros Kit Wed, 19 January 2005 10:13 Go to previous messageGo to next message
enough FNTF shit, ok...
on topic, or not at all...
Kyosho
Wollongong
Re: Looking for Nitros Kit Wed, 19 January 2005 10:29 Go to previous messageGo to next message
ke382TG wrote on Wed, 19 January 2005 15:47
Edit: don't get me wrong, Nos has it's purpose for relatively cheap power gains if done right (Fattony sounds knowledgable on the topic). But you will get reamed if caught driving the streets with it hooked up, or worse have a crash and get caught with it hooked up (both are quite unlikely though).
The other problem is the amount of pressure it creates, it is quite easy to blow a piston through the block if not set up right...
There are certain types of pistons that Nitrous is also good for destroying.
The whole bottom end of the engine has to be strengthened quite a lot to handle a decent amount of Nitrous, a friend runs a 75HP shot through a V8, it's basically on it's limit of throwing a rod through the block...
Luckily he is rebuilding the whole engine for good 1/4 power.
Also, N2O is a bit of a bad gas to have release out into the atmosphere... So don't let it outta the bottle...
On the topic or painting bottles... Another friend had an old fire extinguisher, about the size of a small nitrous bottle...
He got a "NOS" Label, painted his fire extinguisher blue, bolted it into the kick panel on the passenger side for a laugh, made the label face so people could read it... And all the guys at his school thought he really had NOS...
clubagreenie
1st street on the right
Re: Looking for Nitros Kit Wed, 19 January 2005 11:42 Go to previous messageGo to next message
ke382TG wrote on Wed, 19 January 2005 15:52
I can get these if you are really keen. Mind you I can get you a cylinder that'll hold 15 litres of the stuff at 300 bar. Poofy little red and blue bottles are for amateurs.
improvedae86
Re: Looking for Nitros Kit Wed, 19 January 2005 11:55 Go to previous messageGo to next message
300bar ? i thought the hose was rated to 1200psi . well whatever the rating those jet connections are just bronze crimped and alloy ,so i can't see them withstanding pressure for a great time . I was just sold a braided line kit for my new turbo , they used one of those NOS fitting on the block end . Leaked easy with just oil pressure .
Mr DOHC
Re: Looking for Nitros Kit Wed, 19 January 2005 11:56 Go to previous messageGo to next message
Hunty wrote on Wed, 19 January 2005 19:30
seen a stocko commie VP or sumthin i think with no nos running low 16's then put in a 75hp of nos and it was doing low 14's
funnily enuff at the drags on the weekend i raced a VR V6 commodore with a 330,000k old engine with 100hp nos, ran 13.00 Shocked
Fattony
Re: Looking for Nitros Kit Wed, 19 January 2005 14:07 Go to previous messageGo to next message
[quote title=Kyosho wrote on Wed, 19 January 2005 21:29]
Smile
With regards to the hose being only able to take 1200psi, i think thats a little understatement as the optimum bottle pressure for N2O is somewhere between 800-900psi so you would hope that the hose can take more than that. Though in the event the bottle pressure does reach that of 1200 psi it usually has a pressure releif valve to vent excess pressure.
Cheers Adam
[Updated on: Wed, 19 January 2005 14:11]
clubagreenie
Re: Looking for Nitros Kit Wed, 19 January 2005 20:15 Go to previous messageGo to next message
How is the nos actuall supplied? Via bottle pressure only. In that case you only need to run it through a regulator to give required delivery pressure. But I'd just plumb it with solid stgainless line, 10,000psi working and put up with lots on non chromed shine.
Fattony
Re: Looking for Nitros Kit Wed, 19 January 2005 23:44 Go to previous message
Yeh the Nitrous is supplied to the nozzles via bottle pressure. Though when you buy the Nitrous kit what every it may be you get the appropriate lines with it.
Cheers Adam
Previous Topic:Ae-111 Suspension
Next Topic:IS 200 gearbox 6speed question
Current Time: Sat Oct 24 02:41:02 UTC 2026
Total time taken to generate the page: 0.0055959224700928 seconds
