Toymods » Tech & Conversions » uh oh!! Urgent advice please....
capableronTRD
uh oh!! Urgent advice please.... Wed, 19 January 2005 09:03 Go to next message
I'm a little freaked out right now.
I just went to check the water in my car, having just did a head gasket repair (details in the previous thread) but upon opening the radiator cap i noticed a fine oily layer in the water (not running coolant as yet) and a foamy white substance covering the cap itself.
There is no evidence of water contamination in the oil. (either via dipstick or under the filler cap).
I am hoping this is just excess WD40 that i used to coat the block and help reinstall hoses, eg: it seeped down into the water jackets when the head was off.
I flushed the block before reconnecting the radiator, and the radiator was professionally cleaned and pressure checked before reinsallation.
The car has been driven on the road about 7km, and probably idled for a total of 30 minutes since I got it going.I started the car with the cap off and it didn't shoot coolant like it used to.
Has anyone noticed similar findings after doing a head gasket?? Should i be worried, cos i am !! Sad .
EVOSTi
cambo
      no
Re: uh oh!! Urgent advice please.... Wed, 19 January 2005 09:39 Go to previous messageGo to next message
i wouldnt worry at this stage, as it may be reidual even tho you say youve cleaned it out. im confused as to why you would run it without coolant? its not expensive. the furthest ive driven without coolant was from my work to home where i had toyota genuine.
so what i would do it just get a bottle of radiator flush and run that for 10 mins before you put the actual coolant in, but i wouldnt be overly worried.
capableronTRD
Re: uh oh!! Urgent advice please.... Wed, 19 January 2005 09:49 Go to previous messageGo to next message
I had heard that running coolant can hinder the gasket from 'beading' in properly, thats all. I wanted to do everything i could to give the gasket the best chance of survival so i don't have to do it again for a little while.
I was going to flush and refill with coolant at 1000kms when i retorqued the head.
brett_celicacoupe
townsville NQLD
Re: uh oh!! Urgent advice please.... Wed, 19 January 2005 09:51 Go to previous messageGo to next message
just wonderin, have u cleaned the cap since it was foamed up. might just be the stuff that was there from when it was fucked head gasket
EVOSTi
cambo
      no
who have you spoke to about this? how old were they? 60-plus? i havent heard of doing this before but maybe i just havent been in the game long enough hehe. and also with most modern head gaskets retensioning isnt required. but it wouldnt hurt i supose.
capableronTRD
Re: uh oh!! Urgent advice please.... Wed, 19 January 2005 09:57 Go to previous messageGo to next message
Cap was cleaned before reinsallation.
A couple of mechanics mentioned it to me, (and yes they were old coots) plus read it on the net (so it MUST be true Razz ).. its a 7M-GE, i was looking for anything to help the problem, that includes the retorque aswell.
So i shouldn't be worried?
TheStitt
Membership Secretary
Re: uh oh!! Urgent advice please.... Wed, 19 January 2005 10:05 Go to previous messageGo to next message
Dump and clean and see if it does it again It may of just been residue.
Yeah I would retorque the head, mine lost a little of its tension
capableronTRD
Re: uh oh!! Urgent advice please.... Wed, 19 January 2005 10:25 Go to previous messageGo to next message
Yeah.. It'd be strange for it to leak oil and not compression, especially on a gasket less than 7kms old (with a machined head surface too).
TheStitt Did you initial retorque to 72ft/lbs? How did you retorque - back each bolt off and retighten or just tighten without backing them off first??
Re: uh oh!! Urgent advice please.... Wed, 19 January 2005 21:11 Go to previous messageGo to next message
next question - the oil filter. Did you put a new one on, because they can retain water, and the same thing freaked me out on my last head gasket swap and turned out being water in the oil filter.
Replaced oil filter all was good.
TheStitt
Re: uh oh!! Urgent advice please.... Sat, 22 January 2005 23:44 Go to previous messageGo to next message
Yeah I initally tourqued the bots to a little over factory, and then did the retourque at 600km or so kms.
I can't quite remember but I think I Just wound them up didn't back them off not 100% sure though this was a while ago
YelloRolla
On your mum!
Re: uh oh!! Urgent advice please.... Sun, 23 January 2005 01:45 Go to previous messageGo to next message
If the head gasket is a mono-torque type then DO NOT retorque it. These are specifically designed with a glue that will crack if it is retensioned and cracking is not good for longevity. Always go with the advice of the gasket manufacturer.
Apart from that I have nothing to offer over what has already been said.
capableronTRD
Re: uh oh!! Urgent advice please.... Sun, 23 January 2005 06:52 Go to previous message
Well i used 100% genuine parts in the repair, so i'm unsure if the toyota HG is monotorque or not. It is similar in appearance to the non genuine HG i pulled out -ie: some sort of carbon based material around a metallic frame. That gasket had to be retorqued, but i'm not at all sure of the toyota one.
PS: The oily residue has all but disappeared, to my great relief it seemed to be left over WD40 that got into the water jackets as over 100kms later there is little more than a small amount of oil floating on the surface, you can only tell by catching it on the right light angle.
The car runs faultless now, i can definatley see why these cars created such as hype back in the late 80's, even now it would be competitive with most sedans less than half its age in most areas.
Previous Topic:MX83 Cressida STD stereo plug wiring
Next Topic:ta22 gt oil pressure ammeter gauge
Current Time: Sun Oct 25 08:05:30 UTC 2026
Total time taken to generate the page: 0.005903959274292 seconds
