Toymods » Tech & Conversions » 18r-g aircon setup, will this work??
brett_celicacoupe
townsville NQLD
18r-g aircon setup, will this work?? Wed, 19 January 2005 09:38 Go to next message
hi,
i have been fidling around tryin to organise a suitable setup to have the 18r-c compressor on the 18r-g. mounting the compressor wont be a problem, but having a suitable belt setup that will work is a bit of work.
the way i have it experimentally setup at the moment is,
pulley1: (the inner pulley) just running the alternator alone.
pulley2: (the outer/3rd pulley) runs over the outer pulley on the water pump, then around the compressor.
now to have the belt connected from the crankshaft pulley to the alternator, i had to machine off the "bigger" pulley on the water pump so that the outside of the belt wouldnt rub.
i then had to space the water pump out by using 2 washers behind the pulley on each bolt (will make proper spacer on lathe later).
my question is;
seeing as the outer pulley on the water pump is smaller than the inner one, will this make it spin too fast???
also, is there enough belt-to-pulley contact on the water pump?? (belt is loose in photo though)
also, will there be too much flex in the belt?? should i use a guide???
if it is any significance, im runnin a thermo fan.
here are the pics
** origional image deleted so page can download quicker**
thanx
brett
[Updated on: Sat, 22 January 2005 11:18]
Re: 18r-g aircon setup, will this work?? Wed, 19 January 2005 10:37 Go to previous messageGo to next message
you'll need an idler pulley to adjust tension on the a/c belt - the air con compressor needs to be firmly mounted (e.g. can't pivot)
you might get away with that setup for the water pump -buti doubt there would enough contact from the belt to water pump.
i'd suggest finding a pulley for the water pump that is 'hat' shaped (and brings the belt close to the engine) and let it use the same belt as the alternator - then source/position an idler pulley somewhere for the a/c compressor
brett_celicacoupe
townsville NQLD
Re: 18r-g aircon setup, will this work?? Wed, 19 January 2005 10:43 Go to previous messageGo to next message
thanx,
that gives me an idea, if i weld 2 "big" pulleys on the water pump pulley, have the aircon runnin off the 2nd cranskaft pulley instead of the 3rd.
then keep the origional setup of the 1st crankshaft pulley running around to the alternator
Re: 18r-g aircon setup, will this work?? Wed, 19 January 2005 11:00 Go to previous messageGo to next message
unless your engine uses a serpentine belt, i'd keep the important things (water/alt) on the inner primary belt and special stuff (like a/c and p/s) on the outer.
what's the stock setup for the alt/water pump?
can you run with that with a secondary belt (on crank pulley #2) running over the water pump up to the a/c? as long as both pulley sizes on the water pump are the same this would be sane?.
Mr DOHC
Re: 18r-g aircon setup, will this work?? Wed, 19 January 2005 12:01 Go to previous messageGo to next message
odd, Confused my w/p and alt run off one belt, the other 2 grooves arent used, i was gonna machine them off
Re: 18r-g aircon setup, will this work?? Wed, 19 January 2005 21:04 Go to previous messageGo to next message
middle groove to me doesnt actually look like it is supposed to take a V belt, or any belt at all. It just looks like a spacing between two belts.
I cant find any pics anywhere of how this is supposed to be done, i vaiguely remember there being an idler pulley just below the a/c compressor.
river
Land of Oz
Re: 18r-g aircon setup, will this work?? Thu, 20 January 2005 04:40 Go to previous messageGo to next message
I have an 18RG factory fitted air-con.
There is a dual pulley at the bottom of the engine and another dual pulley on the water pump.
The inside belt (closest to the engine) runs around the alternator and water pump and the big end.
The outside belt (closest to radiator) runs around the a/c compressor, water pump and the bigend.
So, both belts pass over the water pump and go around the big end. Inside belt to alternator, outside belt to a/c.
When my water pump broke some years ago, the car was off the road for nearly two months while I tried to source another unit with dual pulleys.
Both pulleys, on the water pump are the same size.
Witzl is correct, the v-shape is merely the groove between the pulleys and doesn't support a belt.
My a/c compressor is an old piston-type unit, circa 1974. To adjust the a/c belt you need to loosen the a/c compressor securing bolts and move the whole unit. It bolts to the passenger side of the engine, just above the exhaust manifold. I assume your unit would have to bolt on in a similar position.
seeyuzz
river
brett_celicacoupe
townsville NQLD
Re: 18r-g aircon setup, will this work?? Thu, 20 January 2005 11:26 Go to previous messageGo to next message
THE WITZL wrote on Thu, 20 January 2005 08:04
strange Confused my crankshaft pulley has definately got 3 useable grooves, although there is 4 spaces/grooves in it.
Mr DOHC wrote on Wed, 19 January 2005 23:01
ok this was my origional *stock as a rock* setup before i tried to fit a aircon
#1 groove(closest to reaer of car) = runs the alternator + water pump. this is infact a pulley that takes a belt.
#2 groove = this is an actual spacing between pulley #1 and pulley #2.
#3 grove = this is infact a pulley that takes a belt. it is the same size as the #1 pulley. runs nothing
#4 grove = this is infact a pulley that takes a belt. it is slightly smaller than pulley #1 and pulley #2. runs nothing
this makes me wonder why it has 3 useable pulleys on it and u guys only says it has 2 Confused
river wrote on Thu, 20 January 2005 15:40
seeyuzz
river
*this is the setup i will be using now*
#1 groove(closest to reaer of car) = will be running the stock configuration, ie.runs the alternator + water pump. (in the picture i was just playing with options)
#2 groove = this groove does not support a belt, it is a space Razz
#3 grove = this is infact the puley that will be running the air-con, on my setup anyway. i will have it runnin over the water pump (i have put dual big pulleys on the water pump) and then around the air-con compressor
#4 grove = nothing
Rolling Eyes
thanx brett
brett_celicacoupe
townsville NQLD
Re: 18r-g aircon setup, will this work?? Sat, 22 January 2005 11:16 Go to previous messageGo to next message
well this is it at the moment,
i made a custom water pump pulley that has 2 big pulleys on it in stead of one. im pretty confident this will work Smile
river,
is this similar to your setup???
http://img141.exs.cx/img141/4088/newairconsetup.jpg
BTW: belt isnt tight and havent finished making compressor brackets proply yet
thanx alot
brett
river
Land of Oz
Re: 18r-g aircon setup, will this work?? Sun, 23 January 2005 06:12 Go to previous message
Yep, that's how it goes.
seeyuzz
river
Previous Topic:cant get my fuel filter off!
Next Topic:ke30 corolla steering box into ta22
Current Time: Sat Oct 24 22:11:09 UTC 2026
Total time taken to generate the page: 0.00484299659729 seconds
