Toymods » Tech & Conversions » 4A-GE + Keihin Carbs
Josip
4A-GE + Keihin Carbs Wed, 19 January 2005 09:42 Go to next message
Anyone got idea about this setup?
I've found carbs from Kawasaki ZX-9R, 10 000km. Bike is destroyed.
Carbs are keihin G314 AKKL with 40mm inner diameter.
We've calculated that air flow on 900ccm engine on 14k rpm is same as 4a-ge small port on 6,6k rpm so it should be ideal in terms of sizing.
I might try this setup, but the bike-guy says i have to run them with airbox on. Since i would like to run them with trumpets/KN filters is there any problem with that, since these carbs need vacuum to work properly.
PLEASE SOME OPINIONS since it's kinda urgent.
I need to buy or return these babies.
fangsport
timaru NZ
Re: 4A-GE + Keihin Carbs Fri, 21 January 2005 09:42 Go to previous messageGo to next message
build a box similar to the factory Solex set-up.
i know of these carbs being fitted to Datsun engines with awesome results.
slydar
Re: 4A-GE + Keihin Carbs Sat, 22 January 2005 02:06 Go to previous messageGo to next message
40mm is quite a nice size if you ask some engine builders, for a 1.6. the FCR's which some japanese guys run are 41.5 from memory, and are said to be good to 170hp, which in reality is massive power for a 4ag.
ive spoken to a few bike wreckers/workshops, jets are definately available.
the hardest part is the ignition system. there is a company though that sells an ignition only computer, that will interface with the standard 4ag dizzy. cant remember the name right now though, they have a site, pm me and ill dig it up. theyre an aussie company, i think it was developed for LPG cars (which are basically carburetted) but ive spoken to one performance shop that has fitted them to alfa's ect. last time i check it was 330 for the kit.
[Updated on: Sat, 22 January 2005 02:07]
Re: 4A-GE + Keihin Carbs Sat, 22 January 2005 12:59 Go to previous message
Sure, they'll be fine, so long as you want carbs! Make sure you work out what it will cost for the carbs, manifolds, filters, etc. as well as ignition, tuning, etc., to see if it's not worth, in fact, just using EFI...
Previous Topic:AE86 Seat Swap
Next Topic:DRIFT KE70 OPINIONS?
Current Time: Wed Oct 14 09:51:27 UTC 2026
Total time taken to generate the page: 0.084451913833618 seconds
