Toymods » Tech & Conversions » ae86 track width
TA-022
Glenmore Park, NSW
ae86 track width Wed, 19 January 2005 11:53 Go to next message
nice and simple one.
hub face to face, what is the measurement? (ie hub/drum face that wheel mates to)
disc and / or drum....
Nathan
improvedae86
Re: ae86 track width Wed, 19 January 2005 11:56 Go to previous messageGo to next message
think its 1335mm ?
TA-022
Glenmore Park, NSW
Re: ae86 track width Wed, 19 January 2005 11:58 Go to previous messageGo to next message
confirmation any1?
i like that size so far...
ty dave
CLG
Perth, Western Australia
Re: ae86 track width Wed, 19 January 2005 15:05 Go to previous messageGo to next message
You realise your request and explanation are two different entities, and based on wheel offset? Track width is the distance between the mid point of the two wheels, and offset will affect that distance naturally.
takai
Re: ae86 track width Wed, 19 January 2005 21:36 Go to previous messageGo to next message
Rear is 1370, front is something a bit more.
improvedae86
Re: ae86 track width Wed, 19 January 2005 21:45 Go to previous messageGo to next message
ok from the sprinter handbook , page 119 , section b specs
length : 4180mm
overall width : 1625mm
overall height : 1335
wheelbase : 2400
front tread :1355
rear tread :1345
Now tread must be taken from the internally measurement of the wheels , since the front is 1410 disc face to face , rear 1400 drum to drum from memory .
But what has this got to do with ta022 ?
takai
Re: ae86 track width Wed, 19 January 2005 22:02 Go to previous messageGo to next message
Rear is 1370 drum to drum, measured it up last night, thats why the Hilux diff fits.
1345 sounds too small, but makes sense because my car was 1407 give or take with the extra 50mm track.
improvedae86
Re: ae86 track width Wed, 19 January 2005 22:18 Go to previous messageGo to next message
Yeah i have so many measurements of this , i must have got lost . Maybe my measurement of 1400ish is the stock measurement from the outside of the wheels . Where Toyota take theres from is a mystery .
Purple_Beasty
New Zealand
Re: ae86 track width Wed, 19 January 2005 23:10 Go to previous messageGo to next message
Toyota's measurement will be the track width, ie cetre of tread to centre of tread. For 99% of cars this is less than the hub face to hub face measurement as they use positive offset wheels (which means the centreline of the wheel is inwards from the mounting face). If the diff is 1370mm drum to drum, with +15 offset wheels the track will be 1340mm (as there are two wheels of course).
Callum
TA-022
Glenmore Park, NSW
Re: ae86 track width Thu, 20 January 2005 10:58 Go to previous message
well ive been told that putting a lsd in my ta22 tseries diff will likely result in snapinh axles.
apparently ae86 have thicker/ stronger axles.
now i dont need to go the length of gseries conversion cause ill only be running a 4age but i want lsd as i plan to do some weekend drifting here and there once the car is built.
so my thoughts were tseries diff drum or disc from ae86 into my car.
bracket remounting is to be expected but i know a few welders so thats sweet.
so sizing sounds like it will work...hmmm.... and maybe a bit off a bigger dish will be allowed....nice.
any ideas if ae86 axles with a matching lsd will fit my housing?
Nathan
Previous Topic:3SGTE Oil Pressure Sender Location
Next Topic:Does this 1JZGTE dump pipe look the goods?
Current Time: Mon Oct 19 17:51:13 UTC 2026
Total time taken to generate the page: 0.005511999130249 seconds
