Toymods » General Car Talk » Finally seen the engineer
fade-e
icon10.gif  Finally seen the engineer Wed, 19 January 2005 13:39 Go to next message
when and spoke with my engineer today after 6 months of starting the rebuild Rolling Eyes and a massiv list of things i wanted to ask and do to the car for engineering along with pics to show...
I am Happy to say that everything is a GO Very Happy he has approved my brake upgrade. i explained to him what i wanted to do and showed him all the current pics and he said it was fine and would pass on the spot no worried.
with the battery relocation, he said that the box has to be mounted to the boot floor and ALSO the battery!!!! the battery NEEDS to be clamped down as it is in the engine bay. so all i have to do there is buy a battery base and clamp and bolt that through the battery box and into the floor. the strap he says is only to hold the cover on the box and also it needs to be vented to outside, so im gonna vent that through the floor aswell. he has also approved that i can run the battery positive terminal through the chassis rail
with the boot surge tank and fuel pump location all that is legally required is that the boot area be sealed off from the cabin by a piece of metal only, that way if there is a leak or explosion then it wont get into the cabin as the metal is not flamable and therefore wont get into the cabin. i know it still can but that is the only requirement, therefore it does not need to be boxed off on its own and vented
now when i was there i was EXTREMELY worried about my aftermarket POD filter and Haltech ECU... but after thourough research of the EPA and RTA i couldnt find any reason not to engineer a POD filter, i mentioned this to him and he said the only reason why it is illegal is cause of the increase of induction noise and also being a forced injection engine that just makes it worse. we have therefore come to an agreement that he will engineer the pod as long as it is sheilded and induction noise reduced to a legal limit, ie, 96Db as it is pre 1983. i told him i will just get heat sheild material and cover it like that and he said thats fine and will pass HOW MAD IS THAT Very Happy
also with all the extra drilling and stuff he said all that is required is that for everything that is not a bolt requires a rubber gromet. so 2 are required for the positive cable (one in boot and one in engine bay), one is required for the venting hose of the battery box
with the Haltech, apparently engineers in NSW had a meeting with the RTA and EPA a couple weeks ago and have been advised that there is no way in HELL they will allow them BUT he said to me that he does not check the electrical system when he goes to engineer it so if he cant see it then he assumes stock ECU is being used Rolling Eyes... to that i replied you will never see it Laughing so providing that the ECU is not easily visible then he will pass me but under the assumption that there is the stock ECU still there...
so in summary my brake upgrade approved, my POD filter approved, my battery relocation approved and my fuel system approved and written on the certificate... with the ECU that is some what approved (i guess you could say that)... so all in all I AM A VERY HAPPY CHAPPY and can now complete everything with a peace of mind, now all i need is the money Confused
only stupid thing is that i forgot to ask him bout the filler nozzle, i guess ill call him tomorrow...
setsuna
Re: Finally seen the engineer Wed, 19 January 2005 13:54 Go to previous messageGo to next message
thats awesome news!
good work mate!
now to do the same thing with mine..
its not ready yet! nono
Smiley =
Re: Finally seen the engineer Wed, 19 January 2005 13:59 Go to previous messageGo to next message
Just on the pod filter subject, your engineer cannot approve the filter. He can only document it one the cert which means squat, so dont use that any kind of argument with police or the transport dept.
fade-e
Re: Finally seen the engineer Wed, 19 January 2005 15:37 Go to previous messageGo to next message
Cool1 wrote on Thu, 20 January 2005 00:59
im not too sure bout that! cause my engineer was very strict and somewhat forceful that if the POD is not completely sealed and and silenced then immediate fail... he actually recommended that i get like a VT filter box and use that as they are designed from factory to be heat resistent and silenced and then run a cold air intake setup
also he actually said that so long as it is boxed/sealed off and not loud then the cops cannot say anything as it is approved and engineered... i dont believe he would say that just so I (who he doesnt know and we only met the first time today) can get his licence revoked or whatever
on top of that i ran a thread bout POD filters in tech/conversions a couple weeks back bout this exact issue and supplied the EPA guidelines for it. when i mentioned that to him he stated that they are the only requirements for PODS in NSW... he said it has nothing to do with pollution, AFM OR MAP sensors or anything other than literally NOISE. the EPAs and RTAs requirements is pure noise based and basically they will not allow excessive and unnecessary noise levels for a road/street car.
when i mentioned bout pollution and what not he said that has no effect on anything as the air is drawn in and therefore no pollution issues as the pollution comes from the exhaust and so long as that meets guidelines then there is nothing to worry about. also on that note he stated that because the car is PRE pollution requirements i dont even need a CAT for the exhaust but rather that it would be better to have one, ie, i DONT need a CAT for engineering purposes
we spent a good couple hours together going through every little detail, every scenario that could occur with cops. i basically walked in there and said that i want to be covered for every possible scenario with respect to cops and defects... by the time i walked out of there i literally had a head ache cause of all the info he gave and the requirements... what i mentioned up top was a summary of the meeting but we went through practically every law in respect to vehicle modifications in NSW so effectively i am covered for absolutely everything other than the ECU
clubagreenie
1st street on the right
Re: Finally seen the engineer Wed, 19 January 2005 20:28 Go to previous messageGo to next message
And the name of this guru is?
davedave
Re: Finally seen the engineer Wed, 19 January 2005 22:00 Go to previous messageGo to next message
Location too please... and tell em the price son!
Smiley =
Re: Finally seen the engineer Wed, 19 January 2005 22:10 Go to previous messageGo to next message
All very interesting information!
When I had the 3tgte conversion engineered I was running factory ECU and have been real worried that the 3sgte will never pass with the autronic. But sounds like if I hide it well all will be sweet Smile
Re: Finally seen the engineer Thu, 20 January 2005 00:00 Go to previous messageGo to next message
As I said he can mention the pod on his cert but it means fuck all as there is no mod code that he can certify the pod with.
fade-e
Re: Finally seen the engineer Thu, 20 January 2005 00:37 Go to previous messageGo to next message
Cool1 wrote on Thu, 20 January 2005 11:00
matbe so but thats what he said... I found him to be pretty strict in the engineering requirements, he said too that even if there is a missing rubber gromet or if there isnt one where required as outlined then i would fail. so he goes into alot of detail with his inspections just not electrical...
also DO NOT mention ECUs to him, i was put onto him by a very good friend of mine and when i mentioned bout the Haltech he said if he couldnt see it then he wont worry but still is ILLEGAL, he also mentioned never to talk bout the ECU with him again so if you call him let him assume stock ECU being used at all times
the cost for the cert is $500...
TurboRA28: you had a thread bout battery relocation, he said it HAS to be clamped/mounted down, so using rubber or whatever in the box is not allowed as was mentioned in the thread... he was very adament bout this when it came to the relocation of the battery...
he also says to try and not drill anything through the chassis at all times possible, if you do have to then you need to drill a big hole and put a metal cylinder through which gets welded and made flush with the chassis and then you feed the bolts through... so not just drill and bolt as this is an immediate fail... he said to me that he will unbolt it and check to see if done right
[Updated on: Fri, 21 January 2005 00:07]
Re: Finally seen the engineer Thu, 20 January 2005 00:40 Go to previous messageGo to next message
This guy cant be to strict if he is allowing you to drill through the bottom of the battery box either.
rob_RA40
c'town, NSW
Re: Finally seen the engineer Thu, 20 January 2005 01:16 Go to previous messageGo to next message
im not sure your engineer would be happy to know that you've just told the entire world that he does the dodge with ECU's.
fade-e
Re: Finally seen the engineer Thu, 20 January 2005 01:18 Go to previous messageGo to next message
Cool1 wrote on Thu, 20 January 2005 11:40
how do you mean? how else are you supposed to mount it down?
Re: Finally seen the engineer Thu, 20 January 2005 01:29 Go to previous messageGo to next message
Yeah this has confused me more.
Re: Finally seen the engineer Thu, 20 January 2005 01:30 Go to previous messageGo to next message
metal bracket securing the box from the outside is the other option.
Re: Finally seen the engineer Thu, 20 January 2005 01:33 Go to previous messageGo to next message
fade-e wrote on Thu, 20 January 2005 11:18
By rights if you drill holes in the box or change the original specification of the box, you need paper work from the manufacture stating that the box will still meet their regulations. Sounds lame, but thats the way it is.
When my work first started fitting batteries in cabin they went through all this bullshit and decided against modifying the box. We now make our own metal brackets that sit around the box to stop it from moving around. The strap supplied with the box simply holds it down in the bracing.
You also need to make sure that you do buy a box that does meet the Australian safety regulation and not one sold by silly sollys.
Re: Finally seen the engineer Thu, 20 January 2005 01:34 Go to previous messageGo to next message
Did that make sense? Rolling Eyes
Re: Finally seen the engineer Thu, 20 January 2005 01:38 Go to previous messageGo to next message
Ok cool.. So... you first make some kind of metal tray/base that bolts to the floor.. Sit box in this tray with the strap holding it to the tray?
My plan was to put a metal plate inside the box, which bolted through the box into the floor. Then I could make some internal bracing inside the box to hold the battery down.
But if no holes allowed in the box.. I see no way at all to mount the battery down apart from packing with foam etc.
Re: Finally seen the engineer Thu, 20 January 2005 01:49 Go to previous messageGo to next message
I just talked to the engineer that I used with my 3tgte conversion.
He said that the battery MUST be somehow fixed to the car. So its not good enough just having it inside the box. Holes have to be drilled in the box for brackets to go through so the battery itself is fixed to the car. He said its not good enough to have the box fixed to the car and not the battery.
He also seemed to think most of the boxes are not completely sealed and would be quite concerned about engineering them without some additional sealing.
Re: Finally seen the engineer Thu, 20 January 2005 01:50 Go to previous messageGo to next message
I'll try and get some photos of an install we have done.
But what we use is 1.5inch angle steel and weld up a brace that sits tightly around the box.
This gets bottled to the floor and the strap gets bolted to the floor in the center of this brace. If you shop around you can actually get boxes with two straps.
We then put a very thin piece of flat rubber mat in the brace so that the bolt heads dont damage the plastic box.
The box is then fitted with battery and strapped up.
We dont have the problem with the batterys being loose in the box as our batterys are a tight fit anyway.
Re: Finally seen the engineer Thu, 20 January 2005 01:54 Go to previous messageGo to next message
Any recommendations where to get the boxes with 2 straps? I've checked out a few auto parts stores but all just real cheap looking 1 strap jobs.
fade-e
Re: Finally seen the engineer Thu, 20 January 2005 02:59 Go to previous messageGo to next message
TurboRA28 wrote on Thu, 20 January 2005 12:49
thats what my engineer said too, when i mentioned the bracket he said wat if for what ever reason you go over a jump or car flips or anything out of the ordinary and bracket will not hold it down... i know its not every day you go over a hump/jump and the car gets crazy airborne or flips but he said of the possibility is there then it needs to be addressesd no matter how unbelievable it may be and thats why he wants the box bolted down
EDIT: also the other issue is the acid he said... the boxes are supposed to be designed where they can handle any leaks from the battery, he said obviously its not going to hold it completely and forever but enough to be able to take action... with any foams or anything else mentioned it would melt straight away from the acid and if it took time for you to notice for whatever reason then the battery is not held down for that time...
does that make sense? when he explained it, it made sense Confused
[Updated on: Thu, 20 January 2005 03:08]
Re: Finally seen the engineer Thu, 20 January 2005 03:18 Go to previous messageGo to next message
Did he say anything about the box not being completely sealed and extra sealing would be required?
Re: Finally seen the engineer Thu, 20 January 2005 03:21 Go to previous messageGo to next message
With a bracket made up like I described the battery is not going anywhere if it is fitted correctly. Even in a roll over.
Also you can foam rubber or even just rubber that acid wont hurt.
The good thing is you are thinking hard about this. But also think about the bolts you would use to through the bottom of the box. How long do you think they would last in a sealed box that has costic(spelling?) gases floating around? They will corrode away within a few months.
4agte
Toronto, Downtown
Re: Finally seen the engineer Thu, 20 January 2005 03:34 Go to previous messageGo to next message
fade-e wrote on Thu, 20 January 2005 11:37
He was probably strict because you asked him to be as you said you wanted to cover all situations which includes strict coppers. But at the end of the day a copper cant see a hidden ecu.
Re: Finally seen the engineer Thu, 20 January 2005 03:37 Go to previous messageGo to next message
Yeah I can definately see what you are saying. If it wasn't for the problems with mounting the battery itself - regards what i've heard the engineer say as well as someone mentioning grief at the track. I'd be not thinking about this and using your method of mounting.
Just seems i'm wasting my time doing it all and then not being able to pass engineering as well as coping shit at track days.
But yeah, seems to defeat the whole purpose by putting bolts through the box...
Seems there is no way to please the authorities with this one.
fade-e
Re: Finally seen the engineer Thu, 20 January 2005 03:40 Go to previous messageGo to next message
yeah i see your point and honestly in everything youve said earlier i can understand and agree with you Cool1... out of everything my main concern was the battery relocation not only cause its in the boot but also cause the surge will be in there aswell... im putting the battery on the passenger side and the surge on the driver side
my best option is to do what he said but before putting it all in take it to him and get it checked once over and reconfirm placement
he also said that i could put a metal plate next to each (to the right of the battery and left of the surge) like a wall but he said thats just over kill
fade-e
Re: Finally seen the engineer Thu, 20 January 2005 03:48 Go to previous messageGo to next message
4agte wrote on Thu, 20 January 2005 14:34
HELL YEAH, when i first walked in and we started talking i said to him from the get go that i never want to have hassels with cops what so ever, if i ever get pulled over then i can pull out the cert and sit back and relax so to speak...
i told him it will be a street car but i will also take it to runs and track days and stuff so i want everything done right so i dont get too many headaches from everyone and thats what he said i needed to do
Re: Finally seen the engineer Thu, 20 January 2005 04:13 Go to previous messageGo to next message
So anyone know where to get an RTA approved box?
Re: Finally seen the engineer Thu, 20 January 2005 04:55 Go to previous messageGo to next message
Joel. any good marine shop should have some good ones.
Also another idea for mounting: If you make a brace that goes around the bottom of the box like I described, you could make a bracket that goes over the top of the box. This would be just like the bracket that normally holds the battery down, except it goes over the box.
Sigmeister
Adelaide, SA
Re: Finally seen the engineer Thu, 20 January 2005 07:56 Go to previous messageGo to next message
TurboRA28 wrote on Thu, 20 January 2005 14:43
I have been told by an engineer that these ones:
http://www.vpwmailorder.com.au/asp/product_page.as p?sub_cat_id=659 Do not cut the mustard.
I think this one:
http://www.vpwmailorder.com.au/asp/product_page.as p?sub_cat_id=1490
Or this one:
http://www.vpwmailorder.com.au/asp/product_page.as p?sub_cat_id=660
Will be approved as they are sealed and vented.
Also are you supposed to put a blue triangle on the boot to show it has been relocated. Or is that just for racing?
fade-e
Re: Finally seen the engineer Thu, 20 January 2005 08:30 Go to previous messageGo to next message
i was told that the 1st one would get approved as long as you get a venting hose made and bolt it down... also the first one is the one that i have and i even showed him the pictures of it and he said it was fine
Re: Finally seen the engineer Thu, 20 January 2005 10:14 Go to previous messageGo to next message
the first one is what I was recommended as a cheap-but-legal option.
shane: caustic Smile
Youngy
Eskilstuna, Sweden
Re: Finally seen the engineer Thu, 20 January 2005 10:38 Go to previous messageGo to next message
Has anyone considered making their own box from scratch?
I have tiny little Odyssey mounted in a box on it's side, that was made for it and that is welded to the floor with a clamp that holds the Odyssey into it. My engineer said that despite the laws saying that you need a sealed box and vent etc that he would pass it due to the sealed battery being used.
The law was written before sealed battery technology had progressed as far as it has.
That said has anyone seen how much effort some factory boot installations go to - such as the MX5?
Not a whole lot. The MX5 is mounted in a tray as it would be under the hood. And then has this tube go from the top of the battery into the gunnels on the side of the boot - not very sealed really!
I guess I will soon find out if I have to change it........
Re: Finally seen the engineer Thu, 20 January 2005 11:00 Go to previous messageGo to next message
draven wrote on Thu, 20 January 2005 20:14
I nearly had it Wink
Re: Finally seen the engineer Thu, 20 January 2005 11:19 Go to previous messageGo to next message
"My engineer said that despite the laws saying that you need a sealed box and vent etc that he would pass it due to the sealed battery being used.
The law was written before sealed battery technology had progressed as far as it has."
yeah, engineer might pass it, but you can still get defected and be boned
Re: Finally seen the engineer Thu, 20 January 2005 11:22 Go to previous messageGo to next message
hehehe He said boned
Razz
Major Clod
Re: Finally seen the engineer Thu, 20 January 2005 11:36 Go to previous messageGo to next message
fade-e wrote on Thu, 20 January 2005 00:39
So... on my RA23 when I take off my back seats and the sound deadening, you can easily see the fuel tank, there is only a couple of braces going across. Would this mean I'd need to weld a plate over these holes to seal off my boot completely for my fuel setup?
fade-e
Re: Finally seen the engineer Thu, 20 January 2005 14:07 Go to previous messageGo to next message
Major Clod wrote on Thu, 20 January 2005 22:36
thats what i said to him! i told him that the original is behind the seat and only a piece of wood covers it from the actual seat... he said to that the the tank is far from any possibal coliision points, ie, if hit from the rear or sides there is no way in hell that it would reach the fuel tank, also cause it is bolted to the strut bracket then it is very firmly held in place. further to that the fuel lines go down and under the car so if anything were to happen it would more than likely be under the car and therefore still out of the cabin area and that is why it is fine... but with the surge cause the lines are still within the boot it would have nowhere to go,eg, if the lift pump blew then the full force would remain with in the boot and thats why he wants a metal piece/sheild between the back seat and the boot. it is more likely that the metal sheild would buckle from heat rather than catch on fire and burn everything else, also that extra seconds you gain before it does actually get into the cabin allows you to either get out of the car and run or even give that extra bit of time to grab the fire extinguisher... and thats why he wants a metal sheild... he said it can be any metal wether steel, milkd steel, iron, alluminium or whatever just as a baracade
ae86drift
sydney.au
Re: Finally seen the engineer Thu, 20 January 2005 14:33 Go to previous messageGo to next message
ARC make some nice dual panel-filter intake boxes.
not cheap but just as good as the pod
setsuna
Re: Finally seen the engineer Thu, 20 January 2005 16:15 Go to previous messageGo to next message
whats the specs on exhaust for the 3TG? Razz
funny.. I just got a yellow Sad
so homo
ahh well.
get into gear and fix all the things 'ive been meaning to get around to' etcetcetc
thu187
Re: Finally seen the engineer Thu, 20 January 2005 19:23 Go to previous messageGo to next message
2 things:
1. You said 96db limit for PRE 1983 cars. What's the limit for post 93?
2. What the hell are you doing?! Take down the guy's details! Cops can read too you know. If people want it, let them PM you.
Youngy
Eskilstuna, Sweden
Re: Finally seen the engineer Thu, 20 January 2005 21:41 Go to previous messageGo to next message
draven wrote on Thu, 20 January 2005 22:19
I am not sure if you are aware of this, but if an officer\cop wants to defect you, they can. They can even defect a brand new car if they really wanted to.
[Updated on: Thu, 20 January 2005 23:15]
davedave
Re: Finally seen the engineer Thu, 20 January 2005 22:04 Go to previous messageGo to next message
whoops, moving post to specific battery thread
[Updated on: Thu, 20 January 2005 22:05]
fade-e
Re: Finally seen the engineer Fri, 21 January 2005 00:08 Go to previous message
thu187 wrote on Fri, 21 January 2005 06:23
2 things:
1. post 83 is 90Db
2. good point
Previous Topic:Japan personal import laws
Next Topic:4AGTE Turbo manifold: NOW YOU CAN BUY!!!
Current Time: Thu Nov 19 11:01:24 UTC 2026
Total time taken to generate the page: 0.16303706169128 seconds
