Toymods » Tech & Conversions » Venting batteries to the atmosphere
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Venting batteries to the atmosphere Thu, 20 January 2005 00:41 Go to next message
Hey all,
A question that's a bit more specific that the other battery thread that's active right now, so I thought I'd start a new thread.
I've had a battery in the boot for ages now but have never had it vented. Yes, stupid, but that's me. I'm lazy.
But now the the interests of my health, I have decided to get off my arse and do it.
Anyway, let's start the questions!
Where would I extract the air from? The top of the box? The bottom of the box?
Do I need to actually seal the box? If so, what's considered a good seal? What's good material to use?
The xA6x's have nice air vents on the side which are ideal for dumping (and hopefully being low pressure areas, extracting) air to the outside of the car.
Re: Venting batteries to the atmosphere Thu, 20 January 2005 00:58 Go to previous messageGo to next message
Good questions and i'm keen to hear the answers as this is my project for the weekend Smile
I thought the plastic battery boxes were classed as 'sealed' though. So no extra sealing would be required.
davedave
Re: Venting batteries to the atmosphere Thu, 20 January 2005 01:03 Go to previous messageGo to next message
Ditto that, as I'll be mounting mine in the frunk next week.
ke382TG
Re: Venting batteries to the atmosphere Thu, 20 January 2005 01:21 Go to previous messageGo to next message
Most of the cheap plastic boxes are not sealed, makes sure you purchase a good quality selaed unit if the battery is going ot be in the car with you.
Once you have your sealed box just run a small hose (what ever diameter fits your particular box) from the vent on the box (usually found on the lid) to the outside of you car.
My vent tube runs from the lid through a grommet in the boot floor to vent to atmosphere. Been like that for 5 or 6 years and nothing has blown up, passed engineers and rego etc.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Venting batteries to the atmosphere Thu, 20 January 2005 01:26 Go to previous messageGo to next message
Nark, for a vent, consider the little black vents on the rear quarters on the ra60?
Re: Venting batteries to the atmosphere Thu, 20 January 2005 01:31 Go to previous messageGo to next message
I think they're the ones he was talking about.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Venting batteries to the atmosphere Thu, 20 January 2005 01:33 Go to previous messageGo to next message
Yeah, I really should've read the post for more than 2 secs, sorry Smile
Re: Venting batteries to the atmosphere Thu, 20 January 2005 01:39 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=57082&start=0&rid=34&S=d5b36e7690d95 3cbb455442fefedf647
Bit of info there.. Just more confused now though about how to mount these stupid boxes.
Re: Venting batteries to the atmosphere Thu, 20 January 2005 01:52 Go to previous messageGo to next message
Where do you buy the boxes that are a good seal? Not just the super cheap auto ones i'm assuming?
Nark
Cabramatta, NSW
Re: Venting batteries to the atmosphere Thu, 20 January 2005 02:04 Go to previous messageGo to next message
ke382TG wrote on Thu, 20 January 2005 12:21
So extract from the top eh?
My battery box has two holes where the wires come in and has two vents at the top of the box.
I'm assuming I run pipes from the vents at the top.
[Edit: Should've refreshed the thread before answering]
[Updated on: Thu, 20 January 2005 02:07]
Chris Davey
sunny coast, qld
Re: Venting batteries to the atmosphere Thu, 20 January 2005 02:28 Go to previous messageGo to next message
also you can get batteries that are designed to vent. Not the oddysey ones. They are a normal fluid type but they are already sealed and they come with two small holes in them for you to plug the tubes into. I have this battery, so I just ran the tubes from there out the lid and through a grommet in the boot floor.
too easy Smile
Re: Venting batteries to the atmosphere Thu, 20 January 2005 03:17 Go to previous messageGo to next message
Yeah thats the battery I got I think its from a BMW or Merc they run under the rear seat or something.
For all these people in this thread about to tackle the battery box conversion, what method are you going to use for mounting the box and the battery inside the box?
In that other thread I posted a link too seems there are some different engineering opinions there.
allencr
tallahassee FL usOFa
Re: Venting batteries to the atmosphere Thu, 20 January 2005 14:53 Go to previous messageGo to next message
don't sweat it unless you've got a bad battery that needs a huge re-charge every time you startup, or an alt that is putting out more then 14v, there isn't that much gas, hydrogen, whatever output.
there are, or were, millions ov\f VW beetles on the road with their battery under the back seat.
TOY77
Re: Venting batteries to the atmosphere Thu, 20 January 2005 19:48 Go to previous messageGo to next message
hey guys,
i have my battery in the boot of my 28.
we welded in a L shaped piece of 5mm flat bar that is raised from the floor level by about 30mm. This brought it up level with the side of the spare wheel well.
the battery box is bolted to the plate, pus i cut a slit both sides of the base to allow the strap that hold the battery to goout of the box and under the metal plate.
you have to be careful about your mounting set up if you ant to be passed for scruitineering at the drags. The battery cannot just be put in the box and the box secured, the battery must be secured too.
i made my own lid for the box - 1.2 mm alloy plate, bent and tigged together in the corners so it seals better.
i also used one of those batteries that have the vent in the battery with the tube to run out of the car, which i ran through the floor.
Stew
clubagreenie
1st street on the right
Re: Venting batteries to the atmosphere Thu, 20 January 2005 21:10 Go to previous messageGo to next message
Get the Mer/BMW type Batt for in boot/under seat install. Vented from the battery with tubes, apparently doesn't leak when you flip your car. Century have them, it's a DIN something part number. But never had a problem with mine, even after running flat, sitting for 12mths (no lisc) charging reverse polarity, draining, recharging, then remembering it should have water in it. Gets my stamp of approval.
davedave
Re: Venting batteries to the atmosphere Thu, 20 January 2005 22:06 Go to previous messageGo to next message
I just read this on a battery box site
Quote:
Required by ANDRA when there is no firewall between driver's compartment and battery
Now I'm planning on relocating my battery from my engine bay to my frunk. I have a firewall between myself and the battery, but my frunk is sealed as far as I know and does not "vent to atmosphere".
Do I need to get a sealed battery box? or can I just cut a hole in my car? or is this a question for the engineers?
Re: Venting batteries to the atmosphere Thu, 20 January 2005 23:01 Go to previous messageGo to next message
Hey Stew, did you consider mounting the box just behind the back seat infront of the spare tyre well (assuming you standing at the back of the car). From memory thats a pretty flat surface and was thinking of putting mine there.
Joel
TOY77
Re: Venting batteries to the atmosphere Fri, 21 January 2005 03:10 Go to previous messageGo to next message
hey joel,
dont know if you remember, but i dont have a back seat....
it would probly be good there if you have a back seat to hide it from veiw.
i had it set up like a panel van with my sub box twhere the back seat was.
so if i had put it the it would have been right in the middle of a flat panel.
though with my new interior i am doin i am considering putting the battery where the back seat was under a custom plate that forms part of the new stereo/ interior install.
Stew
davedave
Re: Venting batteries to the atmosphere Sat, 29 January 2005 00:17 Go to previous messageGo to next message
davedave wrote on Fri, 21 January 2005 09:06
I guess it's a question for the engineers then
Re: Venting batteries to the atmosphere Sat, 29 January 2005 00:35 Go to previous messageGo to next message
just a coupla points.
when charging, a lead acid battery will produce hydrogen.
hydrogen is much lighter than air and will rise (hence venting at top), so venting to a position above the battery box makes more sense.
if you vent to floor, then i guess it doesn't matter where takeoff point is, since the whole box and line must fill before it escapes...
that all said, hydrogen diffuses extremely quickly, and also diffuses THROUGH many plastics and rubbers (similar to how propane escapes through a balloon), and so any vent to atmosphere will let hydrogen escape by diffusion.
the main reason you need a sealed battery box (ie one with a good seal at the top, ie marine type box), is a) to prevent hydrogen build-up in a car, and b) to prevent acid leakage in an accident.
the DIN batteries are a good start, but the COPoLVM is clear in that you need a sealed box, securely mounted, venting to atmosphere.
last thing you want is a 10kg battery flying around the car...
TOY77's method sounds good..
remember the idea is to prevent a 10kg sulphuric acid bomb from going off in your car Wink
Alchemist
Re: Venting batteries to the atmosphere Sat, 29 January 2005 07:06 Go to previous messageGo to next message
The factory battery location in SW20's are located in the "frunks", no box, nothing(other than being bolted in). Maybe that could help answer you AW11 question dave, maybe you dont need a sealed box, but I'd still speak to an engineer about it.
Re: Venting batteries to the atmosphere Sat, 29 January 2005 07:08 Go to previous message
they dont need a box, because there is a firewall separating the bettery and the passenger compartment.
Previous Topic:CT12A blown seals ..
Next Topic:Surge tank. What low pressure pump to use?
Current Time: Fri Oct 23 02:59:24 UTC 2026
Total time taken to generate the page: 0.006479024887085 seconds
