Toymods » Tech & Conversions » Speed sensor for AE86?
pepsicola
Speed sensor for AE86? Wed, 23 October 2002 00:15 Go to next message
Does all the 4age ECU need a speed signal?
I am planning to put a 4age(redtop or 20v) into a sprinter.
How can I get a speed signal from a sprinter?
And does the ECU output speed signal will do the job for the stock speedo meter?
[Updated on: Wed, 23 October 2002 00:30]
Re: Speed sensor for AE86? Wed, 23 October 2002 00:32 Go to previous messageGo to next message
Standard ae86 speedo is cable driven, unless you get one of those *danmned sylish* digital dashes.
pepsicola
Re: Speed sensor for AE86? Wed, 23 October 2002 00:50 Go to previous messageGo to next message
sorry, I am silly about this. Sad
can you explain more?
Re: Speed sensor for AE86? Wed, 23 October 2002 02:56 Go to previous messageGo to next message
The standard speedo is run off of a cable that runs from the end of the gearbox to the back of the dash - nothing needs to be changed because you'll use the same gearbox.
pepsicola
Re: Speed sensor for AE86? Wed, 23 October 2002 03:12 Go to previous messageGo to next message
yeh, I've got a same thought.
by then how do I get a speedo signal for the ECU? or I don't have to give a speedo signal to the ECU(redtop or 20v)?
Re: Speed sensor for AE86? Wed, 23 October 2002 04:38 Go to previous messageGo to next message
I'm not actually sure if the ECU NEEDS a speed signal, or if its only for the speed limiter anyways... If it needs one, then you'll probably need to make up something on the end of the gearbox, or fit a pulse generator to the speedo cable - ask a speedo place.
hiaaa
Re: Speed sensor for AE86? Wed, 23 October 2002 06:18 Go to previous message
If you want to use Engine Check Light then you need to connect the speed signal to the ECU, otherwise the check light will flash when you reach 100km/h. The Aus Sprinter has speed signal output at the back of the speedo,I think it's the pin No.7 (turn the speedo over and read from R->L).
Leon
Previous Topic:Auto to manual
Next Topic:where to rent an engine hoist, or who has one I could borrow
Current Time: Sat Nov 21 03:51:55 UTC 2026
Total time taken to generate the page: 0.0043158531188965 seconds
