Toymods » Tech & Conversions » Bent Chassis Jack Points
Danish
Bent Chassis Jack Points Thu, 20 January 2005 05:41 Go to next message
Who fixes chassis jack points? Mine are extremely soft and bend every time it is jacked up. Now they are flat on some corners and rusted.
http://www.users.bigpond.net.au/soarer/undercar/chasisjackpoints.jpg
http://www.users.bigpond.net.au/soarer/undercar/chasisjackpoints3.jpg
[Updated on: Thu, 20 January 2005 05:46]
Re: Bent Chassis Jack Points Thu, 20 January 2005 05:58 Go to previous messageGo to next message
If that is happening, then you are obivoulsy not using the correct jack.
Those points are only for the factory scissor jack, or a jack with a "U" on the top of it.
You don't use a jack with a flat lifting position on those points.
To fix, just pull the metal back with pliers/vicegrips
drift86levin
brisvegas
Re: Bent Chassis Jack Points Thu, 20 January 2005 06:08 Go to previous messageGo to next message
yeh, it looks like youve been using a trolley jack..if you must use one..jack under the chassies rail just in a little further from the lip..or..use a scissor jack.. Very Happy
Danish
Re: Bent Chassis Jack Points Thu, 20 January 2005 06:15 Go to previous messageGo to next message
Yes, I and others were using a trolley jack. Smile It was so much easier.
Re: Bent Chassis Jack Points Thu, 20 January 2005 06:21 Go to previous messageGo to next message
If you want to use a trolley jack, use it on the crossmember mount (ie the big round thing in the first photo) or just jack it from the diff like I do.
Danish
Re: Bent Chassis Jack Points Thu, 20 January 2005 06:31 Go to previous messageGo to next message
I think it was the easiest point to use at the time as the car was very low. Cheers for your input.
So bending it back with pliers? That doesn't sound like it will turn out very neat.
Re: Bent Chassis Jack Points Thu, 20 January 2005 06:36 Go to previous messageGo to next message
Does it need to be?
Re: Bent Chassis Jack Points Thu, 20 January 2005 06:38 Go to previous messageGo to next message
yep - jack from the diff or crossmember if using a trolley jack. The listed jack points are only for you if you are using the factory supplied scissor jacks.
styler
Re: Bent Chassis Jack Points Thu, 20 January 2005 07:09 Go to previous messageGo to next message
its like using tap water for coolant, sure it will
work but it will stuff it up over time. screws for
screwdrivers, paint for paintbrushes.
iv seen many people use quick and easy trolley jacks
to lift the car but only where it will mount properley,
like under the diff etc.
as its been said use the u jack for your "u jackable"
mounts
Fr3aK
Wollongong
January 2005
Re: Bent Chassis Jack Points Thu, 20 January 2005 07:13 Go to previous messageGo to next message
What if you want to jack up the front of a car? With a trolley jack?
Re: Bent Chassis Jack Points Thu, 20 January 2005 07:18 Go to previous messageGo to next message
Fr3aK wrote on Thu, 20 January 2005 15:13
I don't know how good this is, but I use the middle off the crossmember (make sure you don't get the sump in the dark Very Happy)
Danish
Re: Bent Chassis Jack Points Thu, 20 January 2005 08:20 Go to previous messageGo to next message
This is the type of thing that you will be made to fix if you are defected and sent for inspection.
Re: Bent Chassis Jack Points Thu, 20 January 2005 08:21 Go to previous messageGo to next message
Danish wrote on Thu, 20 January 2005 16:20
Thanks for reminding me Very Happy
Danish
Re: Bent Chassis Jack Points Thu, 20 January 2005 08:38 Go to previous messageGo to next message
So how do you plan to fix them properly, other than tying to bend them back with pliers which will look dodgey?
Re: Bent Chassis Jack Points Thu, 20 January 2005 08:52 Go to previous messageGo to next message
Pliers/Vicegrips.
Major Clod
Re: Bent Chassis Jack Points Thu, 20 January 2005 11:21 Go to previous messageGo to next message
Pliers, then dolly and hammer to get them looking straight. Rub some dirt and mud in and they won't know the difference! Smile
Re: Bent Chassis Jack Points Thu, 20 January 2005 11:59 Go to previous messageGo to next message
Who would defect a car for something as trivial as that?? It's hardly a safety issue...
munki
Gold Coast
Re: Bent Chassis Jack Points Thu, 20 January 2005 13:03 Go to previous message
i guess with the designs of the scissor jacks you could say its much less stable without the Central support on the car, anything other than level could result in jack sliding offage?
Previous Topic:what exhaust do u have? 4age related.
Next Topic:Old School Celica
Current Time: Fri Nov 20 12:57:49 UTC 2026
Total time taken to generate the page: 0.0079400539398193 seconds
