Toymods » Tech & Conversions » from what car is this (anyone with MX73 please confirm)
fade-e
from what car is this (anyone with MX73 please confirm) Fri, 21 January 2005 00:51 Go to next message
guys i have these steering arms but i dont know what car they came from... can anyone help
http://members.optusnet.com.au/ta22rebuild/ICAM000 3.JPG
on this first pic it has L4
http://members.optusnet.com.au/ta22rebuild/ICAM000 4.JPG
on this pic it has a P
please help!!!!! i dont know what ball joint to get and my parts guy aint much help either
[Updated on: Fri, 21 January 2005 23:01]
Re: from what car is this Fri, 21 January 2005 00:54 Go to previous messageGo to next message
Your links are teh suck. Try this:
And they look like pretty much any Toyota steering arm... pretty hard to identify them from a photo.
Re: from what car is this Fri, 21 January 2005 00:55 Go to previous messageGo to next message
If anyone is going to know it'll be IRA11Y as he did a major comparision of steering arms.
fade-e
Re: from what car is this Fri, 21 January 2005 00:56 Go to previous messageGo to next message
Norbie wrote on Fri, 21 January 2005 11:54
yeah i relaised when i created the topic Rolling Eyes Embarassed
and here are pics of the actual strut and brakes
http://members.optusnet.com.au/ta22rebuild/ICAM000 5.JPG
http://members.optusnet.com.au/ta22rebuild/ICAM000 6.JPG
[Updated on: Fri, 21 January 2005 01:06]
Re: from what car is this Fri, 21 January 2005 01:40 Go to previous messageGo to next message
How about:
*some side on shots of the actual arm?
*centre to centre measurements of the mortice holes and also the mounting holes?
*total length measurement?
*diameter, thickness and total height of the disc rotor that's on the strut (to cross reference it with the DBA parts catalogue so at least you have a smaller range of possibilities)?
Like Norbie said, it could be from anything.
fade-e
Re: from what car is this Fri, 21 January 2005 02:01 Go to previous messageGo to next message
ok i got pretty much all the measurements i think...
the disk
- 10"
- 23mmm thick vented
- 4 stud
- 114.3PCD
- single pot caliper
the arm (all measurements are from centre to centre)
- 230mm total length
- approx 35-40mm in height
- actual ball joint hold is 18mm
- 92mm mounting hole to mounting hole
- 47mm from mounting hole to ball joint hole (both inner and outter mounting holes)
- 140mm from ball joint hole to tie rod hole
- 95mm from inner mounting hole to tie rod hole
- 185mm from outer mounting hole to tie rod hole
all measurements may be +/- 1mm but im pretty sure im on the spot
and more pics here
http://members.optusnet.com.au/ta22rebuild/ICAM000 7.JPG
http://members.optusnet.com.au/ta22rebuild/ICAM000 8.JPG
http://members.optusnet.com.au/ta22rebuild/ICAM001 0.JPG
[Updated on: Fri, 21 January 2005 02:05]
fade-e
Re: from what car is this Fri, 21 January 2005 02:07 Go to previous messageGo to next message
update, i have been told buy the person i bought it from that they may possibly be corona... does that sound right with those mesaurements?
and guys thanks for the help its much appreciated
Re: from what car is this Fri, 21 January 2005 04:15 Go to previous messageGo to next message
Are these local?
The 114.3 x 4 PCD narrows it down - has to be RWD car with a front strut. Locally delivered options include Corolla, Cressida, Celica and Corona. Some Sprinters also had vented discs. Local RWD Corollas and Coronas never had ventilated discs so rule them out. Leaves you with the 60 series Celica and 60/70 series Cressidas. However 10" is too inaccurate a number for a diameter, nothing in the Toyota RWD cars had a 23mm thick disc and you didn't supply a rotor height so you can't proceed any further.
I suggest you get a very accurate measurement of the rotor diameter (10" is too vague - you want a mm figure) and total rotor height and scan thru the DBA catalogue under Toyota to find a match here (assuming these struts came off something that was here in Australia).
fade-e
Re: from what car is this Fri, 21 January 2005 05:04 Go to previous messageGo to next message
yeah i noticed taht from the DBA catalogue... therefore what i did is measure the circumference and divide by Pie and got 248mm, it is a 22mm thick disk vented and total thickness is 40mm
from this and the DBA catalogue i got it being a TOYOTA CRESSIDA MX73 (8/84-8/88)... that makes it:
- a vented disk
- 248mm in diameter
- 40mm in original height
- 22mm original thickness
- 21mm min thickness
- 76mm centre hole
- with 4 bolt holes
does this sound and look right? can anyone with an MX73 or has worked on one confirm this for me?
thanks again for the help guys
rob_RA40
c'town, NSW
Re: from what car is this Fri, 21 January 2005 05:09 Go to previous messageGo to next message
it certainly fits the bill as MX73 strut.
fade-e
Re: from what car is this Fri, 21 January 2005 05:12 Go to previous messageGo to next message
yeah but do the pics look like the MX73 strut?
rob_RA40
c'town, NSW
Re: from what car is this Fri, 21 January 2005 05:22 Go to previous messageGo to next message
yep (by process of elimination tho)
vented disc ruled out all models except #A60/65 and MX73.
mac strut rules out the hiluxes, MA70 and mk2 coronas
4 stud rules out the MX83
DBA confirms disc sizes.
not much more we can say unless u wanna scour for pics (try CrUZida's members ride thread)
HTH
fade-e
Re: from what car is this Fri, 21 January 2005 07:34 Go to previous messageGo to next message
i am after pics of the MX73 front brakes... anyone else able to help here otherwise ill be heading to pick and payless in blacktown tomorrow to check it
Re: from what car is this Fri, 21 January 2005 07:35 Go to previous messageGo to next message
I thought getting you to within 3 possible cars on your description was pretty bloody good.
fade-e
Re: from what car is this Fri, 21 January 2005 07:56 Go to previous messageGo to next message
gianttomato wrote on Fri, 21 January 2005 18:35
yeah mate you were a great help much appreciated!!!!!!!!!!!!!!!!!!!!!
fade-e
Re: from what car is this (anyone with MX73 please confirm) Fri, 21 January 2005 23:02 Go to previous messageGo to next message
am still after confirmation of the pics, anyone with an MX73 can you confirm the pics please?
Re: from what car is this (anyone with MX73 please confirm) Sat, 22 January 2005 02:14 Go to previous messageGo to next message
They look a lot like MX73 (mine even has that yellow spray patch on it, dunno what its there for though).
But MX73 discs are 248x22.
Are your measurements off?
Hub looks identical to MX73 though.
Perfect hub/strut to upgrade to Z32 brakes!
fade-e
Re: from what car is this (anyone with MX73 please confirm) Sat, 22 January 2005 02:29 Go to previous messageGo to next message
yeah i went to pick 'n payless here in syd and confirmed they are MX73.. does the Z32 caliper fir straight on it? are they twin or quad pot calipers?
Re: from what car is this (anyone with MX73 please confirm) Sat, 22 January 2005 02:35 Go to previous message
http://forums.toymods.org.au/index.php?t=msg&t h=52875&start=0&rid=4164&S=feb8eb48634 5ccf0336801cff582b4d5
Previous Topic:MALS4 GT4 ST185 Group A Info needed??????
Next Topic:product name and source for intake ducting (brisbane)?
Current Time: Fri Oct 23 04:56:34 UTC 2026
Total time taken to generate the page: 0.074204206466675 seconds
