Toymods » Tech & Conversions » 3SGE -> 3SGTE (ST162)
MAD180
Adelaide, SA
3SGE -> 3SGTE (ST162) Fri, 21 January 2005 07:58 Go to next message
Hi all, I have been thinking about converting my 89 SX which currntly has a 3SGE in it to a 3SGTE, I have saved up what i feel will be enough. However i am not very mechanically minded, However my two best mates are both mechanics and *should* know whats going on, Now my question about engine hunting, Can I Put a 3sgte in out of any model celica, ie the rounder 1990 shape (ST185) or does it have to be from a ST162/5
Also has anyone done the 4wd conversion, if so how difficult is this to do and any rough prices on it
Thanks - Josh
SilverGhost
Re: 3SGE -> 3SGTE (ST162) Fri, 21 January 2005 08:28 Go to previous messageGo to next message
Hi Josh,
Searching the forum for info on this will reveal plenty of threads full of info, but heres some to get you started.
the 3sgte motors (Gens 1,2 & 3) are only available in the gt4 variants of the celica i.e. ST165, 185, 205 and the SW20 MR2. The MR2 motors apparently need a bit more work converting them to a front mounted setup, but can be done.
All 3 generations come with top mount IC's as standard. the 165, 185CS and 205's have WTA (water to air intercooler) and the ST185R comes with ATA (air to air intercooler) so if your going for a front cut off a ST185R you will need to adapt a bonnet scoop, or install a FMIC. The others can go straight in, but I believe vents in the bonnet would be a wise idea due to the heat generated by this motor.
All 3 motors share the same basic block design which means they should all mount up the same (I may be mistaken as I believe the 205 or Gen 3 3SGTE has a different sump setup which may indicate a change in block design.
An mr2 gearbox may also be a wise investment as its setup for 2WD and is deisgned for the additional power/torque of the 3SGTE (any guys here more familiar with the different variants of gearboxes can confirm or deny this.
The other major thing is wiring, you will need a different ECU, and wiring loom. MR2 wiring looms are quite different and wont fit straight in a celica without some serious cutting and rewiring. As far as im aware ECU location is the same in all 3 models so holes in the firewall and wiring lengths should be close of not the same.
As far as recommending which type to go for its up to your taste and budget.
165 (1986-1989) has a smaller WTA intercooler than the 185CS or 205, small port head and has a single entry CT26 turbocharger running 8-11psi stock.
185 (1990 - 1993) has T-VIS (toyota variable intake system) large port head, larger WTA or ATA IC, twin entry exhaust manifold and CT26 also running 8-11psi stock
205 (1994 - 1998) has the same WTA IC as the 185CS (205 owners may be able to outline a difference i have overlooked) no T-VIS, smaller ported head but apparently has the highest flowing manifold-head setup of the three and a larger CT20B turbocharger running 8-13? PSI stock (please correct me if this isnt accurate, but i know its a higher level than the other 2 gens)
obviously they newer gen motor you get the bigger the dollar sign will be, and if your attempting a conversion, best to just get the half cut so you can be sure you get all the peripheral goodies and pipes needed to make it fly.
If anyone has spotted a flaw in my information please ammend it as this was off the top of my mind while sitting here bored at work.
G/L with the conversion....post it in members rides! Cool
MAD180
Adelaide, SA
Re: 3SGE -> 3SGTE (ST162) Fri, 21 January 2005 09:48 Go to previous messageGo to next message
Thanks for all that info, That assures me that it wont be as hard to find a motor then, as i see plenty of gt4's (ST185) coming through on import mailing list, a few of them are bound to get rear ended.
Anyone that has done the conversion, could they please comment on issues that arose or the simplicity of it all, would be much appreciated.
Now im just wondering about the whole drive-train thing
Thanks - Josh
Toobs
Re: 3SGE -> 3SGTE (ST162) Sat, 22 January 2005 09:46 Go to previous messageGo to next message
Yep the ST185 (not the group A / CS / RC model) is the most commonly available 3SGTE front cut at the moment... and they are fairly sensibly priced too! (Low 2,000's usually)
Having said that if you can find an ST165 front cut at the right price go for it as there will be more parts you can use from the ST165.
The gearbox will be the only other major part you will need to consider... all the other bits you will need will be fairly small (bits of vacuum hose, water hose, intake pipework etc.)
Personally I would try to budget an extra $500ish for the little stuff you will need and just buy it as you go... I doubt anyone has bothered to keep a list of the smaller parts they have needed for this sort of conversion (unless you're really lucky)
If you get an ST165 front cut you probably won't need so many of the little bits and pieces.
Further to that you may want to consider just buying an ST165 outright... it would probably end up more expensive in the long run to build the ST163.5
Draza
Wahroonga
Re: 3SGE -> 3SGTE (ST162) Sat, 22 January 2005 10:03 Go to previous messageGo to next message
MAD180, i have done the conversion. I would have to agree with toobs. That buying a st165 would be cheaper than doing the conversion.
MAD180
Adelaide, SA
Re: 3SGE -> 3SGTE (ST162) Sat, 22 January 2005 21:12 Go to previous messageGo to next message
My only problem with buying a st165, is trying to bloody find one!
I have looked and looked and looked, and will continue to till i decide on the conversion, but they appear to be something of a rareity
-Josh
Thanks for all the info again!
stark
Re: 3SGE -> 3SGTE (ST162) Sun, 23 January 2005 05:37 Go to previous messageGo to next message
It isnt that hard to get an st165 at all.. goto www.prestigemotorsport.com.au
and ring them up and order one... its that easy..
As for a 4wd conversion... good luck... the ST165 has a different fuel tank to make way for the rear diff... it also has a completely different floorpan..
MAD180
Adelaide, SA
Re: 3SGE -> 3SGTE (ST162) Sun, 23 January 2005 07:12 Go to previous messageGo to next message
Ok, another thing ive been told is that i can buy the manifold, turbo, computer, loom, standard top mount ic (everything required to convert the 3gse to turbo) for $1100 then i have to get it fitted and tuned. How do you think this would work out, i have a heavy duty clutch, upgraded brakes and am currently doing suspension in my car, but what about the 3GSE's internals. Can anyone comment on this idea ?
leclercqr
Adealide, Australia
Re: 3SGE -> 3SGTE (ST162) Sun, 23 January 2005 09:05 Go to previous messageGo to next message
MAD180,
I wouldn't consider turbing' the ATMO 3SGE unless you only want to run extremly low boost. For the fairly low price of 3SGTE's go for the transplant. Or go nuts a find a BEAMS, hehe.
Happy Conversion.
leclercqr.
Toobs
Re: 3SGE -> 3SGTE (ST162) Sun, 23 January 2005 09:23 Go to previous messageGo to next message
stark wrote on Sun, 23 January 2005 16:37
Theres one for sale on our forums right now... just posted up today!
Go look!
MAD180
Adelaide, SA
Re: 3SGE -> 3SGTE (ST162) Sun, 23 January 2005 09:26 Go to previous messageGo to next message
So all in all my best option is to convert my ST162 with a 3GTSE (FWD) unless i can get a gt4, as turboing a 3SGE is useless ?
Just a question (excuse the ignorance, due to my lacking mechanical mind as explained above) isnt a turbo 3SGE practically the same as a 3GTSE by the time your finished, whats the difference. Stronger internals, (obviously turbo) stronger gearbox etc ?
4agte
Toronto, Downtown
Re: 3SGE -> 3SGTE (ST162) Sun, 23 January 2005 09:36 Go to previous messageGo to next message
there is supposed to be no difference between turbo and non turbo sw20 gearboxes apart from the lsd. I dont know if the mr2 gearboxes are different from the gt4 gearboxes
MAD180
Adelaide, SA
Re: 3SGE -> 3SGTE (ST162) Sun, 23 January 2005 09:38 Go to previous messageGo to next message
The red GT4 on the forums is a bit out of my price range, thats my only issue with the car and the fact it probably in another state.
acreese
Re: 3SGE -> 3SGTE (ST162) Mon, 31 January 2005 15:08 Go to previous messageGo to next message
4agte wrote on Sun, 23 January 2005 17:36
What???
The non turbo is a s54 5 speed (Non turbo Mr2, Celica SX w/5SFE)
The turbo is an e153 (turbo Mr2, Camry V6)
The LSD was standard in the e153 transmission in Late model MR2s (96+ i think)
I reckon they are quite different. Evil or Very Mad
The GT4 gearboxes are 4WD gearboxes, and are very different to 2wd MR2 boxes. (The GT4 box is an e series box though)
Adam.
davedave
Re: 3SGE -> 3SGTE (ST162) Mon, 31 January 2005 20:02 Go to previous messageGo to next message
acreese wrote on Tue, 01 February 2005 02:08
*agreed*, the S54 is a variant of the C54 (4age etc) whereas the E series are just about bullet proof Smiley =
4agte
Toronto, Downtown
Re: 3SGE -> 3SGTE (ST162) Mon, 31 January 2005 20:39 Go to previous messageGo to next message
i thought there was no difference in synchros and both boxes were based an the mr2's 4agze gearbox.
davedave
Re: 3SGE -> 3SGTE (ST162) Mon, 31 January 2005 22:15 Go to previous messageGo to next message
Synchos? I don't know all that much about gearboxes and synchros, but I would have though most toyotas would have used the same synchros.
Anyways, here's some info on toyota gearboxes
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Transaxles.html
http://www.mr2.com/TEXT/LimitedSlipCode.html (explains codes)
http://www.mr2.com/ARTICLE/1991_Specifications.htm l (US MR2 specs)
4agte
Toronto, Downtown
Re: 3SGE -> 3SGTE (ST162) Mon, 31 January 2005 22:21 Go to previous messageGo to next message
cheers for the info.
Werent trying to say you were wrong i was interested because im looking to rebuild one of my gearboxes (both supercharged mr2 gearboxes) and i heard that you can use the synchros from the sw20 which are better than the gze synchros. The gearbox is damn strong in the gze but the syncrhos are a bit average.
verbatim210
Victoria, Melbourne
April 2005
Re: 3SGE -> 3SGTE (ST162) Sat, 30 April 2005 06:39 Go to previous message
please dont tell me i gotta buy a new car, isnt there any hope for my stocky 162??
im going to cry
Previous Topic:Sydney backyard mechanic wanted (for easy job, pays beer or $$$)
Next Topic:1JZ rear main seal, JZA70 steering rack boots and engine mounts.
Current Time: Sat Nov 21 00:13:16 UTC 2026
Total time taken to generate the page: 0.0056459903717041 seconds
