Toymods » Tech & Conversions » valves bending
MR. 2
Parramatta
valves bending Fri, 21 January 2005 09:04 Go to next message
Guy i have questions, my oil pump has blown out so therefore my timing has well... there is no timming as hte belt sliped with no tension i need to know if 3sgte's will bend valves when something like this happenes
also i am wanting to know if there is any way of telling that they are bent with out taking the head off???
CelicaRA45
nth ringwood, Victoria
Re: valves bending Fri, 21 January 2005 09:40 Go to previous messageGo to next message
they are interference so you wont hit valves with the pistons but you will have to carefull when you set it up to tdc that you dont hit valves together
Re: valves bending Fri, 21 January 2005 10:22 Go to previous messageGo to next message
he means non-interference
so no you wont bend/break valves - that's a speciality reserved for nissan engines Smile
[Updated on: Fri, 21 January 2005 10:23]
Joshstix
Toymods Vice President
Re: valves bending Fri, 21 January 2005 10:49 Go to previous messageGo to next message
You're running big HKS cams right? The engine isn't standard so I think you really need to ask the engine builder if it was an interference engine in the form that he assembled it.
MR. 2
Parramatta
Re: valves bending Sat, 22 January 2005 04:53 Go to previous messageGo to next message
thanks guys thats the answeres i needed i can work with the rest now.
Toobs
Re: valves bending Sat, 22 January 2005 07:05 Go to previous messageGo to next message
Apparently with a 0.8mm MLM head gasket you can get away with shaving about 2-3 thou off the head without causing interference between the pistons and valves.
Also most cams esp from HKS are just longer duration not higher lift so changing cam's in most cases shouldn't cause any problems with interference.
I discussed all this with Justen and a few other people who have rebuilt quite a few 3SGTE's so I have reason to believe what they have said is correct.
Joshstix
Re: valves bending Sat, 22 January 2005 07:54 Go to previous message
What lift are the cams? As far as I know the 256's are 9.0mm lift and the 272's are 9.4mm lift with the 264's in the middle.
Previous Topic:Modifying driver's seat rails
Next Topic:ae92/101 coil overs
Current Time: Sat Oct 17 23:24:13 UTC 2026
Total time taken to generate the page: 0.0046651363372803 seconds
