Toymods » Tech & Conversions » 4A-GE to W58 clutch
BigWorm
Toymods Board Member
Turramurra, Sydney.
4A-GE to W58 clutch Wed, 23 October 2002 08:29 Go to next message
OK, I'm putting a W58 onto my 4A-GE, and I'm wondering what I can do with the clutch.
My options are:
1. Use the clutch from Dellow. Cost's $100.
Has rubber blocks instead of springs, which I've been advised not to use. Very easy to get though.
2. Buy a custom made clutch. Cost's $???.
Whatever clutch I choose to use I will replace with something a bit sturdier once I get a turbo happening, so I don't wanna spend too much. This goes for the Dellow clutch too, 100 bucks is right on the limit.
3. Now this is the option I'm not too sure about. $???.
If I took an old clutch to suit a supra box and the clutch I currently use to a clutch place, would it be possible to get the splined part from the sopra clutch swapped to the sprinter clutch? Any idea of what the cost would be?
Like I said, either way I'll be going for a bigger flywheel & bigger & stronger clutch, so this won't be in use for too long (hopefully Razz )
Thanks for any input you can provide.
TE72_Turbo
Re: 4A-GE to W58 clutch Wed, 23 October 2002 09:57 Go to previous messageGo to next message
hey mate.
Clutch manufacturers often use an old spline section for reconditioned clutch kits, but i'm not sure if the local clutch distributors have the equipment to do the swap.
If you cant get a hold of a supra plate to get the spline section from, a 4AGZE has the same spline configuration, and we know there are heaps of 4AGZE clutches around that people cant fit into bellhousings!
Phil
BigWorm
Turramurra, Sydney.
Re: 4A-GE to W58 clutch Wed, 23 October 2002 10:18 Go to previous messageGo to next message
Really, so the ZE clutch fits the W58? Hmmm, that's something to think about.......
Re: 4A-GE to W58 clutch Wed, 23 October 2002 10:20 Go to previous messageGo to next message
Direct clutch (07) 3862 2680
Buy the $300 2800lb clutch kit now, keep it when you turbo it. No point paying $100 for a $40 clutch plate from dellows!
Re: 4A-GE to W58 clutch Wed, 23 October 2002 10:22 Go to previous messageGo to next message
Yeah, the ZE clutch fits, so long as you get viscious with that Dellhousing(tm) with a grinder.
BigWorm
Turramurra, Sydney.
Re: 4A-GE to W58 clutch Wed, 23 October 2002 10:44 Go to previous messageGo to next message
What flywheel is that clutch kit for?
Re: 4A-GE to W58 clutch Wed, 23 October 2002 11:13 Go to previous messageGo to next message
I've got the 200mm one, I think they can do it for the 215 as well
Youngy
Eskilstuna, Sweden
Re: 4A-GE to W58 clutch Wed, 23 October 2002 12:33 Go to previous messageGo to next message
mrshin wrote on Wed, 23 October 2002 20:22
Dellhousing(tm)
'tm' crack-up!!
TE72_Turbo
Re: 4A-GE to W58 clutch Wed, 23 October 2002 12:55 Go to previous messageGo to next message
I recently called Direct Clutch about a 4AGE clutch kit, and they definately do have both 200mm & 215mm diameters
Phil
Re: 4A-GE to W58 clutch Wed, 23 October 2002 12:58 Go to previous messageGo to next message
Gotta buy the rights before you go using words like that Very Happy
FLY PSI
icon4.gif  Re: 4A-GE to W58 clutch Wed, 23 October 2002 13:14 Go to previous messageGo to next message
if someone wants to donate Very Happy a dellows housing then i will be able to mod it to fit the GZE flywheel & clutch by grinding it out then beefing it up. Then i will be able to cast a(or ten) new ones Smile that way it wont be any weaker then the origional Smile So anybody...................... Very Happy Very Happy Very Happy
Re: 4A-GE to W58 clutch Wed, 23 October 2002 13:30 Go to previous messageGo to next message
My mother always told me to never trust a salesman that smiles TOO much - they're usually up to something.
"Hi. I'm actor Troy McClure. You might remember me from such caryard documentaries as...'
FLY PSI
icon4.gif  Re: 4A-GE to W58 clutch Wed, 23 October 2002 13:55 Go to previous messageGo to next message
What is the rough price for a dellows housing? as i may do this mod for myself in the future.
ed_ma61
Lost in the K hole
Re: 4A-GE to W58 clutch Wed, 23 October 2002 14:14 Go to previous messageGo to next message
JOEL::
--specialised brake and clutch--
glossop st, st mary's
absolute PROs on clutch conversions. recommended by daikin vic and nsw offices (independantly of each other) for any custom or unusual clutch work. i was impressed with em. can do ANYTHING for you.
give em a call
ed
Re: 4A-GE to W58 clutch Wed, 23 October 2002 14:17 Go to previous messageGo to next message
Dellhousing(tm) is 450, 60 for the bearing + 'carrier', 60 for the clutch fork (which looks like something made in kindy, and is about 3 inches too long)
faulksy
Re: 4A-GE to W58 clutch Wed, 23 October 2002 15:43 Go to previous messageGo to next message
450...wow. i picked mine up from this forum for 250 i think. i knew i was getting a bargain but didnt realise it was that much. when i first looked at them almost 2 years ago they were priced at over 650 bucks from memory. seems the demand for them is increasing and therefore the price is decreasing
FLY PSI
Re: 4A-GE to W58 clutch Wed, 23 October 2002 15:52 Go to previous message
mrshin wrote on Thu, 24 October 2002 00:17
I maybe able to make one that looks a bit better than that as well.And will be extremely strong! Smile
Previous Topic:2TC carby problem
Next Topic:Dash Light
Current Time: Sat Nov 21 03:19:19 UTC 2026
Total time taken to generate the page: 0.0095071792602539 seconds
