Toymods » Tech & Conversions » T18 diff AE86 (Tail shaft? Sway bar mounts?)
D1-SPEC
T18 diff AE86 (Tail shaft? Sway bar mounts?) Fri, 21 January 2005 13:41 Go to next message
Hey guys just finished putting together my car t18 diff into ae86. I ve got two questions the first being am i supposed to use the T18 tail shaft? i am using it just dont no if its right It looks identical to the one i had in there is it the same what do you guys use? Also the t18 diff has no brackets for my sway bar so i had to take it of. I heard its not good to weld brackets to diffs so is there a way around this or do i just not use it.. Thanks 4 any help
ShiRi
Re: T18 diff AE86 (Tail shaft? Sway bar mounts?) Fri, 21 January 2005 15:20 Go to previous messageGo to next message
unbolt the rear half of the tailshaft on the t-18...
unbolt the front half of the tailshaft on the sprinter...
bolt two together
insert
done
t-18 tailshaft is shorter... there is a remote chance it could come lose while driving but unlikely chance
i welded my brackets to the diff... has been fine so far... better than having no swaybar at aall
D1-SPEC
Re: T18 diff AE86 (Tail shaft? Sway bar mounts?) Sat, 22 January 2005 00:51 Go to previous message
cheers man i am actually using the sprinter 1.. when i first put it in it made a little vibration i had to move the bracket a little foward then it went away... will get some one to weld the brackets on 4 the sway bar Smile
Previous Topic:product name and source for intake ducting (brisbane)?
Next Topic:MA61 Lambo Doors
Current Time: Sat Oct 24 01:22:43 UTC 2026
Total time taken to generate the page: 0.00388503074646 seconds
