Toymods » Tech & Conversions » Give us Hand Gearbox Problems?:S
Pr0j3kt_SA63
icon5.gif  Give us Hand Gearbox Problems?:S Fri, 21 January 2005 14:29 Go to next message
uh well i have a RA65 with a w55 gearbox i thinks?? well anwyays its not really a gear box problem all gears are fine..... it jus tthe shifter:S its like to put simply like a loose bitch.....i can do cirlce with the gearknob in neutral....though its annoying it can be put in gear etc.......just wodnering what the problem is.......and how simple or har dit is to fix and how much it should cost me
well thanks for the help
MoMo Smile
BlackSupra
Re: Give us Hand Gearbox Problems?:S Fri, 21 January 2005 22:14 Go to previous messageGo to next message
3 worn bushes
2 available from toyota and ed_ma61 can can the other made up for you, but it involves removing the gearbox and pulling it apart to get to it
RA28
Re: Give us Hand Gearbox Problems?:S Fri, 21 January 2005 22:25 Go to previous message
there is also another piece that wears. the little steel plate that bolts down over the big ball-thingo. If this is worn and all opened out then it will move all over the place no matter what gear it's in.
you can see it in this pic.
http://www.members.iinet.net.au/~cooltim/DSCF0016. JPG
on the one on the right, that metal thing that sits above the spring. It's what the bolts go through to hold the shifter down. If the slot in the middle of that is bent and spread out then you need a new shifter.
Tim.
Previous Topic:SW20 injector Impedance
Next Topic:4age Crank
Current Time: Thu Oct 22 09:02:18 UTC 2026
Total time taken to generate the page: 0.0047850608825684 seconds
