Toymods » Tech & Conversions » please help!!!! dash lights not working
whiteshadow
January 2005
please help!!!! dash lights not working Sat, 22 January 2005 10:19 Go to next message
Hi at night when i turn my headlights on they work fine, but no lights on the dash inside the cabin work.... the hand brake light, fuel light etc work fine, its just the dash lights that light up the tacho and speedo....
any ideas of what this could be? is there a fuse to check or something like that..?
dave.
gr8r-x
Vic, AU
Re: please help!!!! dash lights not working Sat, 22 January 2005 11:25 Go to previous messageGo to next message
Not knowing what type car you've got, can't help heaps..
Most likely though, it'll be the dash light brightness adjuster knob/dial. If that's completely toast, it'll be stopping all current to the lights. So, look for the dial.. Or, it might just be turned down. Smile
Aside from that, I'm pretty sure if the lights work, the dash should work, same fuse... Could be wrong though.
sideshow
Re: please help!!!! dash lights not working Sat, 22 January 2005 12:29 Go to previous messageGo to next message
find yr dimmer and bypass it
or most common thing is people pull apart dash and forget to put dimmer back on
whiteshadow
January 2005
Re: please help!!!! dash lights not working Sat, 22 January 2005 13:06 Go to previous messageGo to next message
sorry its a toyota corolla twin cam hatch 87 model
tried the dimmer, that doesn't do anything... will try bypassing it/make sure its connected...
[Updated on: Sat, 22 January 2005 13:06]
towe_001
Somewhere on a dirt bowl ...
Re: please help!!!! dash lights not working Sat, 22 January 2005 13:53 Go to previous messageGo to next message
Have you added any aftermarket gauges, pulled the lower panel off at all?
whiteshadow
January 2005
Re: please help!!!! dash lights not working Sat, 22 January 2005 14:10 Go to previous messageGo to next message
no gauges, not sure about the underneath cover, i just bought the car... so just trying to fix up all the little bits and pieces...
will look under there when i get a chance.
thanks.
Sam_Q
S.E suberbs, Vic
Re: please help!!!! dash lights not working Sat, 22 January 2005 21:04 Go to previous message
sprinters have a ground problem that causes this, I wonder if its the same?
Previous Topic:Flat spot in 20V
Next Topic:Extractors on 4age
Current Time: Sun Oct 18 22:59:42 UTC 2026
Total time taken to generate the page: 0.015033960342407 seconds
