Toymods » Tech & Conversions » 1g-gte Unussual tacho behaviour
willwal98
Toowoomba
1g-gte Unussual tacho behaviour Sat, 22 January 2005 13:18 Go to next message
I have just fitted a VDO tacho to my Ga28 (1g-gte in an RA28). Seems to work fine, RPM readout in general is correct but at 4000rpm the needle stutters and ad 5000rpm it starts to drop (even though engine RPM is smooth and increasing).
I have connected the signal wire to the black wire on the coil. Any ideas?
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Sat, 22 January 2005 20:51 Go to previous messageGo to next message
That's funny, I get that same problem but with my factory tacho.
Any ideas would be appreciated since i'm sick of not seeing anything past 3-4000rpm
sideshow
Re: 1g-gte Unussual tacho behaviour Sat, 22 January 2005 21:00 Go to previous messageGo to next message
u prob need a signal booster
the voltage to tacho is not enough at hi revs
i sell 4 diff types of boosters
one of them should fix yr problem
just got to get right one
grim boy
Re: 1g-gte Unussual tacho behaviour Sun, 23 January 2005 11:32 Go to previous messageGo to next message
side show is write but you dont need to buy any thing to fix it , if you look on the wiring loom there is a dionostic box , there is a tacho out pput in it , just hook your tacho up to that and it will run fine
Dennis
sixworks
Newcastle, NSW, Australia
Re: 1g-gte Unussual tacho behaviour Sun, 23 January 2005 20:59 Go to previous messageGo to next message
Try what Dennis suggests although in theory it shouldn't make any difference if the signal comes from the igniter (to the diagnostics box) or directly from the coil. If you still get the same problem, find an autoelec in your area with an oscilloscope and get him to check the output.
Grant
willwal98
Toowoomba
Re: 1g-gte Unussual tacho behaviour Sun, 23 January 2005 21:10 Go to previous messageGo to next message
thanks guys. I might just save myself some time and visit an autoelec.
sideshow: What do your boosters cost?
[Updated on: Sun, 23 January 2005 21:10]
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Sun, 23 January 2005 21:52 Go to previous messageGo to next message
I only get a signal if I splice the tacho signal wire into one of the three wires from the coil to the ignitor... the black and blue wires I think.
RA28
Re: 1g-gte Unussual tacho behaviour Sun, 23 January 2005 23:22 Go to previous messageGo to next message
there should be a tacho line on one of the plugs that goes through the firewall near where the ECU plugs in. on the big long plug I think. I had my original RA28 tacho hooked up to that and it went all the way to 7K. Maybe the aftermarket tacho needs a better signal though.
it's labeled on the 1GGTE diagrams in the tech docs section anyways.
Tim.
indian
south east - melbourne
Re: 1g-gte Unussual tacho behaviour Sun, 23 January 2005 23:28 Go to previous messageGo to next message
guys im planning on installing an aftermarket tacho in the 1g as well i was thinking why not hook up the tacho from the ecu signal its has rpm signal in there theres2 pins for the rpm i dunno which does what but wont that way work Confused Confused Confused Confused
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 00:03 Go to previous messageGo to next message
Hmmm I wonder if my ignitor is faulty? Razz
Maybe I just need to get rid of the standard ignition and do something cooler... When did they say UMS was coming out? Razz
sixworks
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 01:48 Go to previous messageGo to next message
I was thinking about this again and I remembered that 1GGTE coils have 2 primary windings; they are unique in this respect. I won't bother going into the reason why they have 2 windings (unless someone really wants me too) but suffice to say that I believe the igniter drops out one of the windings at ~4000rpm. Sounds like both of you have spliced into the wrong winding which is why you are experiencing this problem.
As already mentioned, connect the tacho to the igniter output. If you can't find the correct wire then connect to the IG terminal on the outside of the diagnostics box.
Grant
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 02:55 Go to previous messageGo to next message
Tried, no workies!!
Any further ideas?
sixworks
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 03:07 Go to previous messageGo to next message
No, sorry. Time to get it tested by an auto electrician I think.
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 03:14 Go to previous messageGo to next message
HyDrA wrote on Mon, 24 January 2005 10:03
UMS is due in 6-9 months - Megasquirt II is in testing at the moment so expect it sooner.
From my (work affected) recollection, there is a return signal from the igniter to the ECU (IGd ?) that tells the ECu if the ignition event was a 'good' event (e.g. spark plug fired). At higher rpms, that signal might be truncated in duration.
you don't want to pull a signal directly from the coil as you'll be placing a much higher voltage across the tacho input (i think). If you used a MSD igniter, you'd be shoving nearly 400V at the tacho. You'll also get varying pulse widths from there as the dwell time on the coil does vary a bit as rpms rise.
Hydra: If you're feeling experimental, the MSnS thread on MSEFI.COM has discussion about using the wheels in various dizzis (toyota included) to - one variant looks like being able drive a toyota DLI ignition system (e.g. waste spark).
Start reading here: http://www.msefi.com/viewtopic.php?t=5296 and here for DLI stuff: http://www.msefi.com/viewtopic.php?t=4895
(wilwal98: sorry for the post hijak)
cheers, charles.
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 04:03 Go to previous messageGo to next message
Thanks for the links!!!
I'll take a look into this... Wink
EvilJack
Sutho/Hills NSW
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 04:18 Go to previous messageGo to next message
ran mine from the ecu, no dramas
RA28
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 07:14 Go to previous messageGo to next message
HyDrA wrote on Mon, 24 January 2005 13:55
Tried, no workies!!
Any further ideas?
Did you try running it off the line that the original car used?
http://toymods.org.au/Repository/TechDocs/1G%20ECU %20connectors.pdf
look at that doc, it's pin 22 on the long plug. Everyone I've spoken to has used that and it worked fine.
Tim.
CrAiGzEE
south of the big smoke
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 11:55 Go to previous messageGo to next message
i had the same problem , turned out i had the wrong signal wire
craig
sixworks
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 20:59 Go to previous messageGo to next message
Pulling a signal directly from the coil is not an issue as the original tacho was also connected to the coil and all aftermarket tacho's are protected. The problems you guys are experiencing are not common and in all the time I've been wiring up engines I've never seen it myself.
If you're sure you are using the correct tacho output then you need to know if the signal is actually the problem. Find and auto elec with a hand held scope (most now have them) and ask him to check the signal. 5 mins work if that.
BTW RA28, pin 22 on the diagram is the cat converter temp sensor input so you'll get no joy from connecting a tacho to that. Toyota ecus do not actually have a tacho output; it comes from the igniter.
[Updated on: Mon, 24 January 2005 21:16]
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 22:13 Go to previous messageGo to next message
I've tried that wire without any sucess yet.
Since it's Australia day tommorow I might have some spare time... if it's not hot, i'll give the tacho another shot.
Sorry for the major on-topic hi-jack willwal98!!
flynn21atwork
Re: 1g-gte Unussual tacho behaviour Mon, 24 January 2005 23:58 Go to previous messageGo to next message
I just hooked this up yesterday. I used the Black with blue trace wire on the F1 plug which is the squarish looking plug of the the three, not one of the long ones. It seems to be ok. I tried EVERYTHING else before using this connection, as I was under the initial impression that it was pin 22 of the the longest plug, from reading previous posts. None of the other pins worked for me, except the black, with blue trace wire. I think it's pin number 16, but I'm not sure, at work at the moment. All I know is all of my wire colours are completely different to the colours in the diagram, I used pin numbers instead of colours for all my wiring and has worked fine. I originally tried hooking up off the ECU RPM connection and the tacho needle would never get above 2000rpm.
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 00:08 Go to previous messageGo to next message
Interesting!!
I traced wires back from the ignitor and figured it was the black wire.
Might have the motivation to give it a go tonight Smile
sixworks
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 00:34 Go to previous messageGo to next message
Tacho wire is black with brown bands.
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 01:03 Go to previous messageGo to next message
Isn't the general idea "don't ever trust the wires colours on a toyota wiring loom"??
They seem consistant to an extent, but I have seen variations. Confused
willwal98
Toowoomba
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 01:21 Go to previous messageGo to next message
Thanks for all the info guys. And don't worry about the post hijack, it's all interesting reading. I'll have a search around tommorow and see if I can find something that will work. From the above posts I have a few things I can try.
willwal98
Toowoomba
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 08:10 Go to previous messageGo to next message
OK, Blue and Black on the coil are both no go's. Both of them will show revs to an extent but won't give me redline.
The IG on the diagnostic plug lead to nowhere, seems it had been deemed unnecessary during the wiring conversion. If anyone can tell me where it used to go or if someone wants to trace it back to the ECU that would be a big help.
EvilJack: I had a bit of a poke around the ecu and couldn't find anything useable, Can anyone point me to a pin on a plug I should be looking at or a wire colour to try or something? It's a Gen III 1g-gte and the connector plugs (that join parts of the loom together) are not present in my loom, they were removed to make a little bit more space.
[Updated on: Tue, 25 January 2005 08:15]
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 08:37 Go to previous messageGo to next message
Don't the ECUs have the pinouts printed onto the circuit board?
RA28
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 09:01 Go to previous messageGo to next message
OK, here is a pic of my "long plug". This isn't a plug from the ECU. Just one that comes off the loom near it. I assume it plugged into the dash loom, to provide the guages with the signals and shit like that.
http://www.members.iinet.net.au/~cooltim/DSCF0019. JPG
I only used 2 wires off this plug when I had it wired up, one for the tacho and one for the temp guage.
I can't remember which is which but you should be able to work it out. The diagram on the PDF file in the tech docs section says the black wire is for the tacho and the yello/green one is for the temp guage, so start there.
Let me know if it fixes the problem.
Tim.
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 21:41 Go to previous messageGo to next message
Tried that black wire (which is the same wire as the diag connection IG-) with no luck whatsoever.
I wish my multimeter wasn't broken Sad Oh well, time to wait for pay day!
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Tue, 25 January 2005 21:42 Go to previous messageGo to next message
Nark wrote on Tue, 25 January 2005 19:07
My 1G-GE ecu did, was a great help, but the 1G-GTE ecu didn't so I was almost flying blind... the various tech docs and a bit of common sense with a multimeter let me work that one out!
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Sat, 29 January 2005 04:21 Go to previous messageGo to next message
Bought a new multimeter that has a tacho reader built in. I can get a signal from the IG- wire on the diag connector. I measured the voltage from that connector, around the 1V to 1.2V mark. Any ideas on what the standard analogue tacho in a toyota would be after? Razz
ddeane
PNG
Re: 1g-gte Unussual tacho behaviour Sun, 30 January 2005 00:09 Go to previous messageGo to next message
Gidday
Suggest you go to Tech Docs and click on 1G ECU Connectors. All will be revealed.
Craig
sideshow
Re: 1g-gte Unussual tacho behaviour Sun, 30 January 2005 00:24 Go to previous messageGo to next message
hydra if u r gettin signal at ig- and that signal wont run yr tacho then u prob need a tacho booster
just buy one of grant
old style tachos and some new aftermarket tachos need a signal booster for toyota and nissan engines
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Sun, 30 January 2005 00:29 Go to previous messageGo to next message
Yeh, you're right Smile
I'm just very persistant and try to do it all myself first Smile Since i'm not really experienced with designing anything electronic, I think I will just have to buy one Laughing
Cheers for the advice!
Re: 1g-gte Unussual tacho behaviour Sun, 30 January 2005 01:16 Go to previous messageGo to next message
With the tacho booster, what exactly does it do? That's going to seem like a really n00b question, but I've got signal with my multimeter and the Autometer tacho I have is working perfectly, but the factory tacho doesn't want to play ball at all.
Re: 1g-gte Unussual tacho behaviour Sun, 30 January 2005 11:56 Go to previous messageGo to next message
justcallmefrank wrote on Sun, 30 January 2005 09:16
...but I've got signal with my multimeter and the Autometer tacho I have is working perfectly, but the factory tacho doesn't want to play ball at all.
I'd just like to add that I've had this exact autometer tacho working on my 1uz.
Its got Bosch 008 ignitors, and I now have the factory mx73 tacho working fine.
However, I can't get the factory MA61 digitacho working with my 7mgte either.
Re: 1g-gte Unussual tacho behaviour Sun, 30 January 2005 13:54 Go to previous messageGo to next message
How can I test whether or not I need a signal booster without buying one? In theory, wouldn't I get something registering on the tacho even if it's only for a portion of the rev range?
Re: 1g-gte Unussual tacho behaviour Mon, 31 January 2005 01:13 Go to previous messageGo to next message
Surely someone must know how to trouble shoot whether or not I need it.
HyDrA
Adelaide, SA
Re: 1g-gte Unussual tacho behaviour Mon, 31 January 2005 02:35 Go to previous message
I was talking to MWP about this, you can't use a multimeter to test the voltages, you need an oscilloscope.
I'd like to know how I could build my own tacho booster, but it isn't that easy I guess.
Previous Topic:TA22: Electronically Assisted Ignition
Next Topic:RB20 into TA22
Current Time: Sat Oct 24 01:40:34 UTC 2026
Total time taken to generate the page: 0.011219024658203 seconds
