Toymods » Tech & Conversions » small block chev into 86 hilux
GREENLUX
small block chev into 86 hilux Sat, 22 January 2005 23:13 Go to next message
ok ive got my motor and now im looking at puting it in my hilux
what i'd like to know is there anyone that makes kits to fit the small block into the hilux
and how much it is an were i can get it from...
improvedae86
Re: small block chev into 86 hilux Sat, 22 January 2005 23:35 Go to previous messageGo to next message
There Rod Hatfield {spelling ?} kits for 308's so there would also be a kit on the market for 350 i guess . I diff place here in Melbourne has a fleet of 308 hiluxs with ford 9" diffs and xf front brakes running taxi rims with commodore dashes fitted to which there swear by being great for there work .
boxh34d
wangaratta
Re: small block chev into 86 hilux Sat, 22 January 2005 23:46 Go to previous messageGo to next message
"marks 4X4 adapters" in dandenong VIC make adapters for just about anything into anything when it comes to 4WD's.
my old man just put a 454 big blocker into his 75 series land crusher, and he used their kit. this included engine mounts, flywheel, sandwich plate for bellhousing, and gauge and sensor adapters.
some small problems like they gave him the wrong oil pressure sender adapter ( small block instead of big block ), but the workmanship is very professional.
i can get phone number if you want it.
good luck with it,
lee.
towe_001
Somewhere on a dirt bowl ...
Re: small block chev into 86 hilux Sun, 23 January 2005 03:47 Go to previous messageGo to next message
Why a ford 9" ? A mate of mine had an '82 Chevy Hilux 4wd running on the standard Hilux diffs. And he never had a breakage.
ae86drift
sydney.au
Re: small block chev into 86 hilux Sun, 23 January 2005 03:58 Go to previous messageGo to next message
everyone loves a 9" towe Wink
ps. why u on probation? Laughing
towe_001
Re: small block chev into 86 hilux Sun, 23 January 2005 04:27 Go to previous messageGo to next message
probation?
Ball and chain more like it, lol, for being a baaaaaad boy.
But at least being on the ball and chain is better then what davedrifts got
RIP davedrifts / kimber
GREENLUX
Re: small block chev into 86 hilux Mon, 24 January 2005 05:54 Go to previous messageGo to next message
do you guys have numbers so i can contact those shops?
improvedae86
boxh34d
Skip
Re: small block chev into 86 hilux Mon, 24 January 2005 07:27 Go to previous messageGo to next message
A quick search for Marks 4x4 and castlemaine rod shop will yield these elusive numbers.
Mookie
Tassie
Re: small block chev into 86 hilux Tue, 25 January 2005 04:59 Go to previous messageGo to next message
My dad bought a holden 253 to toyota gearbox bellhousing for me from mark finch
he had kits for everything and if not they will custom make it.
V8_MA61
Re: small block chev into 86 hilux Tue, 25 January 2005 05:02 Go to previous messageGo to next message
why not put a 302 or a 351 windsor in it? WAY better motor than holden poo.
Rev much better, easier to work on, cheaper to buy parts for, and easier to get power out of. also rear dizzy on holden motors can pose a problem to cars not designed for one.
towe_001
Re: small block chev into 86 hilux Tue, 25 January 2005 18:43 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 25 January 2005 16:02
How about the Chevy 308 donk?
Yeah something to note
boxh34d
wangaratta
Re: small block chev into 86 hilux Tue, 25 January 2005 23:09 Go to previous messageGo to next message
i dont know about a chev V8 in a hilux, but with my dads cruiser, the V of the big block meant that it sat a lot lower than the original 1FZFE, and there was already a slight 'relief' in the firewall that the back of the straight six's head sat against. the dizzy sits below this, with plenty of room for leads etc.
V8_MA61
Re: small block chev into 86 hilux Sat, 29 January 2005 14:06 Go to previous messageGo to next message
the Wide V of the 308 isnt ideal for a hilux either - itd be an asshole to work on. Also if you put a ford cleveland in this would be the case. Hence id spec a windsor.
Dont forget 308's are those Woful motors they used to put into kingswoods and toranas.
GREENLUX
Re: small block chev into 86 hilux Tue, 22 March 2005 12:01 Go to previous messageGo to next message
update on the hilux
we'v got the engine in we just ended up using a hk engine mount and made new chasie(sp) mounts
we cut the old gbox mount in half and the T400 sat right on top of it so that was the easiest part but we must of pulled the engine out 10 times befor we got it all in the right country
only thing left to do now is a radiator,tail shaft and the extractors...
ill see if i can get pics of the engine in the car in the next week or so
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: small block chev into 86 hilux Tue, 22 March 2005 22:04 Go to previous messageGo to next message
GOOD TO SEE SOME ONE IS DOING THIS I HAVE A 308 AT HOME AND I AM CONTINPLATING PUTING IT IN MY HILUX. FINDING INFO TO DO THE PROJECT IS EXTREAMLY HARD WHEN ITS A 4X2. 4X4 PARTS/KITS ARE APLENTY BUT WHEN DOING A CONVERSION TO 4X2 SO MANY PARTS ARE DIFFERENT. SEND ME SOME PHOTOS IF YOU CAN. WHAT DID YOU DO WITH YOUR BRAKES? IS YOURS 4X2 OR 4X4?
lumpy
Adelaide, SA
Re: small block chev into 86 hilux Tue, 22 March 2005 22:20 Go to previous messageGo to next message
V8_MA61 wrote on Sun, 30 January 2005 00:36
10 points to the resident toymods bogan for trying to start a chev/holden vs ford debate on a toyota forum! Laughing . No bites yet though....
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: small block chev into 86 hilux Tue, 22 March 2005 22:48 Go to previous messageGo to next message
GOOD TO SEE HE CAN ARGUE THE 308 POINT WHEN GREENLUX IS USING A CHEV, NOT QUITE THE SAME.
WHAT SIZE SMALL BLOCK IS IT?
305, 307, 327, 350, 400?
GREENLUX
Re: small block chev into 86 hilux Wed, 23 March 2005 11:05 Go to previous messageGo to next message
81LOWLUX ill see if i can get some pics for you i have to go have a knee reco tomorrow so ill try and get down to see how things are going next week
the enginge is only a baby 283ci or 4.6L (easy to engineer) and ill be serching for xf falcon front disc and calipers for stopping power
i also found some headers to fit it today of the shelf block huggers they have about 15-20 mm space from every think
and ill be using a v8 commodoor radiator with different end tanks and twin thermo fans to keep it cool
i also put the bonet back on today and it all fits under the bonet air filter has heaps of clearence and same with the radiator so you can say it was a good engine conversion for a hilux..
also if your thinking of puting a auto box under it i fited a T400 in the stock tunel...
and it a 2wd hilux Smile
Nolan
Campbelltown, NSW
Re: small block chev into 86 hilux Wed, 23 March 2005 11:36 Go to previous messageGo to next message
towe_001 wrote on Sun, 23 January 2005 15:27
probation?
baahaha i remember that thread..
we were on probation..
i have a sneaky suspision that davedrifts still lurkes somewhere on these forums under an alias Razz
NOLAN
p.s. sorry for Off Topic
Turbo_Tim
Townsville
February 2005
Re: small block chev into 86 hilux Wed, 23 March 2005 14:23 Go to previous messageGo to next message
A bloke I know who is on performance forums is involved in a v8 swap into a 4 x 2 hi-lux. Best bet is to go to the forums and search for ratlux. Its a tad bit difference.
Its coping a big single turbo blow through carb setup. A bit different anyway Smile Planning to be road registered also.
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: small block chev into 86 hilux Thu, 24 March 2005 02:20 Go to previous messageGo to next message
look forward to seeing those pictures
sideshow
Re: small block chev into 86 hilux Thu, 24 March 2005 09:17 Go to previous messageGo to next message
i just wired up a nissan 4.5 lt all alloy v8 into a
wb ute i think it was
think goes pretty good
when the vti cam thingy cuts in at 4000 or 5000 feels like vtec
these engines have supposedly 208 kws but i recon they have more
not to bad since u can pick an engine up for 1500 bucks
GREENLUX
Re: small block chev into 86 hilux Fri, 25 March 2005 21:51 Go to previous messageGo to next message
hey sideshow was that wb ute down at livo exhuast about 3 weeks ago? if so i kno the ute your talking about looks like a very simple swap.....
sideshow
Re: small block chev into 86 hilux Sat, 26 March 2005 23:48 Go to previous message
yer it was
yer its easy to do
just big wiring job due to havin to wire up
auto ecu and engine ecu
Previous Topic:Painting Rims
Next Topic:anybody want to weld my diff-adelaide???
Current Time: Fri Oct 23 02:07:03 UTC 2026
Total time taken to generate the page: 0.028414964675903 seconds
