Toymods » General Car Talk » 4AGTE in new Zoom
Rex_Kelway
4AGTE in new Zoom Wed, 23 October 2002 11:23 Go to next message
Boys and Girls,
For those that doubted the budget potential of the 4AGTE. See the new Zoom (#56)
In the backyard blitz section theres a KE25 running the series 2 (AFM/Twin Coil) 4AGZE minus the SuperCharger but with a T28.
The thing is bog stock internally, Uses a cutdown truck intercooler and Stock AFM ECU and throttle body with the only addition being a Malpassi Fuel regulator and RWD inlet manifold.
The best part is that it winds out 159Kw at the wheels on one measly bar of boost with some very healthy midrange snort. Not to mention how flat the AFR stays, albeit a bit rich (but some fuel regulator adjustment could help this though)
Also there would definately be some more grunt available by ditching that truck I/C (which in general dont flow the greatest)
My Smile grows ever wider Very Happy Very Happy Very Happy
[Zoom, however where off in some of there details about the stock 4AGZE's specs.]
[Updated on: Wed, 23 October 2002 11:25]
CrAiGzEE
south of the big smoke
Re: 4AGTE in new Zoom Wed, 23 October 2002 11:41 Go to previous messageGo to next message
159kw @ the wheels? or flywheel?
if its the flywheel i believe it, sounds reasonable
poida
Re: 4AGTE in new Zoom Wed, 23 October 2002 12:17 Go to previous messageGo to next message
(Rex under peps login)
It says wheels in the article and the Dynosheet uses KPH as the X axis (speed) which seems right given that KPH is a function of driveline gearing rather than out right engine RPM.
[Updated on: Wed, 23 October 2002 12:18]
Youngy
Eskilstuna, Sweden
Re: 4AGTE in new Zoom Wed, 23 October 2002 12:50 Go to previous messageGo to next message
Bye, bye T-50........... Rolling Eyes
Re: 4AGTE in new Zoom Wed, 23 October 2002 14:18 Go to previous messageGo to next message
It says he's already destroyed a few of those and wants a W box..
faulksy
Re: 4AGTE in new Zoom Wed, 23 October 2002 15:30 Go to previous messageGo to next message
better off going an afterarket computer then changing the intercooler. i bet theres heaps of idden kilowatts that the standard one is hiding.
Grega
melbourne.victoria.austra...
Re: 4AGTE in new Zoom Wed, 23 October 2002 20:42 Go to previous messageGo to next message
yes was reading this article earlier this morning, am a little sure of the stock piston specs, big port inlet manifold, yet 8.5:1 comp pistons (which by the way are ceramic coated?)
if its an early type it'll be 8.0:1 comp, no ceramic coating, otherwise if later type it will be 8.9:1 with ceramic coating..
it does use the later type cas tho...
anyone?
Corvid
Re: 4AGTE in new Zoom Wed, 23 October 2002 22:04 Go to previous messageGo to next message
Arrrr... mate i believe all 4agze's have got ceramic coated tops..
Only diff between s1 and 2/3 is s1 pistons are "Semi-Forged" and later pistons are "Forged"
Another thing to take note on.. That red mr2 in club which put out 200kw or whatever was using stock series 1 motor.
Grega
Re: 4AGTE in new Zoom Thu, 24 October 2002 00:50 Go to previous messageGo to next message
corvid, the 1st series don't have the ceramic coating on them (i have a set at home)
faulksy
Re: 4AGTE in new Zoom Thu, 24 October 2002 05:03 Go to previous messageGo to next message
yeah i agree the earlier pistons were definitely not ceramic coated
TE72_Turbo
Re: 4AGTE in new Zoom Thu, 24 October 2002 12:52 Go to previous messageGo to next message
grega & anyone else who has pulled apart a 4AGZE:
What colour is the ceramic coating?
There are many internal designs with truck cores, some may not be too flash, but there are several that have excellent cooling properties and very minimal restriction. I dont know how much there would be to gain in this area.
Grega
Re: 4AGTE in new Zoom Thu, 24 October 2002 21:00 Go to previous messageGo to next message
its a funny grey (almost a light grey if you like) color...
Joshstix
Toymods Vice President
Re: 4AGTE in new Zoom Fri, 25 October 2002 05:23 Go to previous messageGo to next message
If you want to take a look at the car just go to http://www.toymods.org.au/dyno_day_2.html, the car was at the second Toymods Dyno day. I believe it was still supercharged at this stage though. I'm pretty sure the owner was at Eastern Creek a while back when Rod and some other Toymods guys were out there for a run.
GAZZAke25
Re: 4AGTE in new Zoom Fri, 25 October 2002 07:55 Go to previous messageGo to next message
Gday
The truck intercooler that I run is not to bad, it only has 2 psi drop off boost across it.
I was at the dyno day 2 and it was still supercharged, its like a totally different car now that it is turboed.
I am currently fitting a Supra gear box and a commodore LSD diff with billet axles.
When that is in I will head up to Eastern creek and give it a go down the track. I have not had a good go down the strip yet as I broke an axle the first time I went to the drags.
Garreth
Rolla Boy
Club Member
Sydney, NSW
Re: 4AGTE in new Zoom Fri, 25 October 2002 16:42 Go to previous messageGo to next message
Hey cool, that car looks wicked...
Let us know wneh you head down to the Creek and I'll try to get out there to see the baby fly...
The engine bay looks sweet too... Some nice polished pipework I say...
GAZZAke25
Re: 4AGTE in new Zoom Sat, 26 October 2002 10:10 Go to previous messageGo to next message
Thanks mate.
Should be heading up to the drags in about 6 weeks,I am very keen to see what she can do. It should be somewere in the 12s.
As I can safely run my car at 19PSI on Avgas. The last atempt I had was a real shocker It was only on low boost and I bogged down on the line wich gave me a really slow 60foot time of 3 seconds. Next time will be different.
Hopfully see you there.
Garreth
Ben Wilson
Re: 4AGTE in new Zoom Sun, 27 October 2002 21:18 Go to previous message
Grega wrote on Thu, 24 October 2002 10:50
Mine definately had some sort of coating on the top of the piston - Yours haven't been bead balsted to clean them at any point have they?
Previous Topic:Sprinter VS XB Falcon - Bet
Next Topic:penalty without catalyst convertor?
Current Time: Tue Oct 27 00:45:55 UTC 2026
Total time taken to generate the page: 0.095403909683228 seconds
