Toymods » Tech & Conversions » Diff
badboybubby
On Probation
Diff Sun, 23 January 2005 10:49 Go to next message
Is there an LSD diff that bolts into the RA23 ?
jcmunga
adelaide
Re: Diff Sun, 23 January 2005 11:05 Go to previous messageGo to next message
not directly, modified g series diffs are the most common conversion for an lsd in celicas
an easy search will reveal all
[Updated on: Sun, 23 January 2005 11:08]
badboybubby
On Probation
Re: Diff Sun, 23 January 2005 11:09 Go to previous messageGo to next message
Are they the RN27 Hilux diffs ? know where i can get one?
jcmunga
adelaide
Re: Diff Sun, 23 January 2005 11:14 Go to previous messageGo to next message
im pretty sure they are RN41. i doubt youl find one moded already but you can probably get a standard one from a wrecker.
badboybubby
On Probation
Re: Diff Tue, 25 January 2005 00:00 Go to previous messageGo to next message
Cool, geez all the wreckers I speak to seem retarded ?
Re: Diff Tue, 25 January 2005 00:06 Go to previous messageGo to next message
why do you think they are wreckers? because they like cars?
badboybubby
On Probation
Re: Diff Tue, 25 January 2005 00:12 Go to previous messageGo to next message
True reminds me of deliverance every time i walk into a wreckers Very Happy
Re: Diff Tue, 25 January 2005 00:28 Go to previous messageGo to next message
You don't go into the wrecking business because you have a high IQ...
V8_MA61
Re: Diff Tue, 25 January 2005 04:49 Go to previous messageGo to next message
Norbie wrote on Tue, 25 January 2005 10:28
hence i quit after two weeks of being employed at one
river
Land of Oz
Re: Diff Tue, 25 January 2005 05:37 Go to previous messageGo to next message
badboybubby wrote on Tue, 25 January 2005 11:12
Wear a flanno shirt and bring along a banjo next time you go. Maybe they'll be more helpful.... either that or they'll make you squeal like a pig! Laughing
seeyuzz
river
badboybubby
On Probation
Re: Diff Tue, 25 January 2005 05:58 Go to previous messageGo to next message
Only if I get it cheaper Laughing
Ive found a LM106R G52 G285 in a 93 4WD Hilux does this mean anything to anyone ?
towe_001
Somewhere on a dirt bowl ...
Re: Diff Wed, 26 January 2005 08:59 Go to previous messageGo to next message
badboybubby wrote on Tue, 25 January 2005 16:58
LM106R = HiLux powered by a L series diesil
G52 = gearbox
G285 = Diff which will be a 8", 4.3:1, 4 pinions and LSD
Edit: wack on back of head "LM", isn't a HiLux. But it is powered by a diesil
[Updated on: Wed, 26 January 2005 09:11]
badboybubby
On Probation
Re: Diff Wed, 26 January 2005 10:40 Go to previous messageGo to next message
Your a legend towe Very Happy $700 sounds ok doesnt it ?
Re: Diff Wed, 26 January 2005 12:20 Go to previous messageGo to next message
Remember if it came off a 4WD Hilux it will have 6-stud hubs...
badboybubby
On Probation
Re: Diff Wed, 26 January 2005 13:07 Go to previous messageGo to next message
Fugit has anyone done a conversion or am i gunna have to tub it and run 21" bling bling rims Shocked
towe_001
Re: Diff Fri, 28 January 2005 03:57 Go to previous messageGo to next message
badboybubby wrote on Wed, 26 January 2005 21:40
Yeah legend at meal breaks Very Happy
Yeah i'd say so but check for play in the diff 1st. But i'd say being a late model there wouldn't much if any, but still.....
stradlater
Arthurs Creek, Victoria
Re: Diff Fri, 28 January 2005 04:16 Go to previous messageGo to next message
Your going to have to do a conversion to 6 stud or 5 stud of 4 stud in some way shape or form. BUT BUT BUT remember this.. If you redrill and WELD axle plates from 6 stud down to 4 stud you'll not be able to get it engineered because you have welded the axle plates. Another issue to get around that is if you get the 5 stud ones (Which I happen to be looking for too. rare as dogs balls) then you can just re-drill them without having to weld them and hence from my believing can be engineered because they are not welding.
Lambolica
Northwestern Sydney
Re: Diff Fri, 28 January 2005 04:19 Go to previous messageGo to next message
Or.... Find an F Series diff from a MX23 rig up a jig based on the standard Celica diff mount points and weld on new brackets.
LSD for these are easy to find as well.
stradlater
Re: Diff Fri, 28 January 2005 05:18 Go to previous messageGo to next message
how strong are they though?
Lambolica
Northwestern Sydney
Re: Diff Fri, 28 January 2005 05:53 Go to previous messageGo to next message
F series??? strong enough for a 1G?!?
stradlater
Yeah, that was teh question. I have no idea
Re: Diff Fri, 28 January 2005 05:54 Go to previous messageGo to next message
F series is strong enough for a 2JZ... 1G will not be a problem.
Lambolica
Northwestern Sydney
Re: Diff Fri, 28 January 2005 05:57 Go to previous messageGo to next message
Sorry badly written.
Standard diff size on MKIII supras, so if it can put up with 7M-GTE - 1J's will handle a 1G-GTE in a rather light celica easily.
Probably not as strong as a G but not too far off.
stradlater
So there is no particular need to go hunting for a g series hilux diff to put in an ra23, it could be good enough to simply get a f series mx23 diff?
stradlater
Ah, but is there a shortening issue?
stradlater
Re: Diff Fri, 28 January 2005 06:10 Go to previous messageGo to next message
Ok, so all told sounds like a reasonable solution. Hrm, how easy are they to find though. Frankly I'd never heard of a mx23 before, but I'm guessing it's a 5m? cresida of the same vintage as an ra23? or some such?
Lambolica
Northwestern Sydney
Re: Diff Fri, 28 January 2005 06:34 Go to previous messageGo to next message
Mark II Corona = MX23
Celicas diff width is about 1370mm the MX23 is about 1410mm
If you are going for a front brake up grade there is a combination that will bring the front out about that far as well widening your choice of rim as you will probably need to change offsets slightly. there are 2 RA28 I know of that have similar diff treatment.
And from a search I was doing the F series is about 25kg lighter than the G series. Diff
stradlater
Re: Diff Fri, 28 January 2005 06:38 Go to previous messageGo to next message
Gotcha. So the pitfall is the track widening.
Well, thanks that answers the questions. Seeing as I already have the rims, I think I'll be sticking with the hilux one, despite the fact that it's harder to find. But thanks for the info all the same, makes shit loads more sense now.
Lambolica
Northwestern Sydney
Re: Diff Fri, 28 January 2005 06:42 Go to previous messageGo to next message
Yeah It comes down to weather you have the rims or not.
Generally speaking the stock size rims will still go under the rear, but if you have wider rims you'll run into issues
badboybubby
On Probation
Re: Diff Sun, 30 January 2005 09:58 Go to previous messageGo to next message
Am i gunna need to shorten the tailshaft ? Crying or Very Sad
gold28
Madrid - Spain
Re: Diff Mon, 31 January 2005 02:31 Go to previous messageGo to next message
badboybubby wrote on Sun, 23 January 2005 21:49
LSD's are available for the standard T series diff. You could track one down second hand for about $500 if you looked, but the sprinter guys are always looking out for them so they are getting difficult to come by. I think they are still available new.
Allan
Re: Diff Mon, 31 January 2005 02:52 Go to previous messageGo to next message
Lambolica wrote on Fri, 28 January 2005 16:57
MkIII supras have a G series diff, and i would suggest strad DEFINTLY go G series in his application
Allan
Re: Diff Mon, 31 January 2005 03:07 Go to previous messageGo to next message
G series is good but overkill for a 1G in a light car. F series will be more than up to the task as already mentioned, and has the advantage of being lighter and available in 4-stud.
Allan
Re: Diff Mon, 31 January 2005 04:15 Go to previous messageGo to next message
you would recomend an F series diff in a car that will have a lot of hard launchs and much tire killing from a 1g-gte that has a GT40 stuck to the side of it???
i think a little over engineering in this area would be welcomed
Re: Diff Mon, 31 January 2005 04:23 Go to previous messageGo to next message
Yep, I reckon an F series will be fine. Hard launches aren't such a concern - a 2 litre engine with such a large turbo won't have a lot of torque off the line.
stradlater
Re: Diff Mon, 31 January 2005 04:45 Go to previous messageGo to next message
Thanks Allan, your the man. I knew you'd know. Particularly given the fact that you know the car too. Plus you know how I drive. Heh. Although I haven't taken you for a spin in it yet, I better work on that. Just as soon as I get my new diff. I keep killing this one.
Allan
Re: Diff Mon, 31 January 2005 04:49 Go to previous messageGo to next message
I seem to remember someone with several cars laying around with dead diffs Razz
from memory the RA23 has the narrow diff?? and requires the RN27 hi-lux diff, try contacting richard aka 1978supra?? i think he has done this.
Allan
stradlater
Re: Diff Mon, 31 January 2005 04:54 Go to previous messageGo to next message
An array of them anyhow.heh
Yeah after much searching, it is true, the rn27 is the right diff for it, but try finding one. They are as rare as dogs balls. But yeah, the diffs are narrow. I know of one, but it's miles away and it costs a bit, but I might have to pay for it anyway. You may have read my story here a while ago about it.
gold28
Madrid - Spain
Re: Diff Mon, 31 January 2005 22:11 Go to previous messageGo to next message
Hey Norbie, how much torque was your 2J making on full boost. And you were having axle tramp problems too.
If an F series diff can cope with that kind of torture, then I recon it ain't too bad.
Having said that if you are planning on using a locked diff and running around on race tyres all the time, you may end up snapping the odd axle.
stradlater
Re: Diff Mon, 31 January 2005 22:46 Go to previous messageGo to next message
Hence why I'm going g series and probably with a detroit locker.
Allan
Re: Diff Mon, 31 January 2005 23:58 Go to previous messageGo to next message
http://members.optusnet.com.au/gianttomato/Hilux%20brake%20upgrade/axle%20diameter.JPG
G series axles are a little bigger
and T vs G series center
http://members.optusnet.com.au/gianttomato/Hilux%20brake%20upgrade/T%20vs%20Gseries.JPG
Anyone care to provide F series comparison?
gold28
Madrid - Spain
Re: Diff Tue, 01 February 2005 00:49 Go to previous messageGo to next message
Allan, just looking at your signature, you do realise that the supra owes it's heratage to the "sexuality challanged" celicas Razz
river
Land of Oz
Re: Diff Tue, 01 February 2005 04:18 Go to previous messageGo to next message
I'm sure he meant the LT and ST versions of Celicas. Not the GT version, especially with its wonderful F-series diff! Smile
nyuk nyuk nyuk
seeyuzz
river
Re: Diff Tue, 01 February 2005 05:12 Go to previous messageGo to next message
gold28 wrote on Tue, 01 February 2005 08:11
I don't have an actual torque figure, but in laymans terms it's "a metric arseload".
Yes I was getting pretty bad axle tramp before I replaced the suspension.
Frankly I can't see why anyone would consider the F diff weak when it has been proven time and time again behind 1JZ, 2JZ and yes even 7M turbo engines. I somehow doubt a weenie little 1G is going to create much of a problem.
But hey, it's not my money.
badboybubby
On Probation
Re: Diff Tue, 01 February 2005 05:28 Go to previous messageGo to next message
What does the RA23 have in it? would it cope with a spool?
Allan
Re: Diff Tue, 01 February 2005 05:56 Go to previous messageGo to next message
gold28 wrote on Tue, 01 February 2005 11:49
yes and no, i was more refering to the tarted up coronas IE front wheel drive models that chaged to ST chassis codes, the "celica" died after the RA65 and then become the "sexuality challanged" celicas
and anyway if you compare MA45 to RA40 thay are worlds apart besides floor pan, roof and doors
And the cost of a G series diff over an F series would be minimal anyway!
Allan
stradlater
Re: Diff Tue, 01 February 2005 06:06 Go to previous message
What do you mean would it cope with a spool?
As for what the ra23 has in it, they come standard with an 18rc, which would probably shit itself trying to put the pressure on a spool center, yes.
Previous Topic:how to get gz up to 130kw
Next Topic:Ugently needed, 1G-GE info
Current Time: Tue Oct 20 12:05:01 UTC 2026
Total time taken to generate the page: 0.010309934616089 seconds
