Toymods » Tech & Conversions » 3sgte ct26 boost controller help
Hunty
3sgte ct26 boost controller help Sun, 23 January 2005 11:35 Go to next message
got a sw20 mr2, and there are two hoses coming off the wastgate on the turbo, which one should i use for a manual boost controller?? does it matter? they're both a bastard to get to, lol everything in the mr2 is bastard to get to.
Cheers for any help
Joshstix
Toymods Vice President
Re: 3sgte ct26 boost controller help Sun, 23 January 2005 23:30 Go to previous messageGo to next message
You need to get to both of them. The bigger of the two hoses, that points to the back of the engine bay is for the standard boost controller. This must be removed. Disconnect the hose and plug it.
The smaller of the two hoses connects the wastgate actuator to the compressor outlet, this is the boost signal for the actuator. This is the line that you put the boost controller into. Make sure that when you do this the hose isn't stressed at the end of the fitting for the bosot controller as it is prone to tear and then you'll have uncontrolled boost.
Hunty
Re: 3sgte ct26 boost controller help Mon, 24 January 2005 09:50 Go to previous message
Thanks champ
Previous Topic:100kw POWAH
Next Topic:7M-GTE Performance Radiator Ideas?
Current Time: Tue Oct 20 04:55:14 UTC 2026
Total time taken to generate the page: 0.0084969997406006 seconds
